Sponsored by BimmerWorld
Old 04-13-2011, 07:15 PM   #1
CRSmoak
My Ride: 2000 328i
Steering wheel off center, ideas?
I'm positive it's not an alignment issue, I'm guessing something is either worn or bent but don't remember seeing anything. If anyone has any ideas on what is mostly likely the cause, where and what to start checking first I'd appreciated it. Thanks in advance.
CRSmoak is offline   Reply With Quote
Old 04-14-2011, 01:19 PM   #2
jamex
My Ride: 2005 325Ci
I'm off a few degrees as well. I could have sworn it happened after my alignment last year but I can't be 100% sure.
In for some recommendations.
jamex is offline   Reply With Quote
Old 04-18-2011, 02:30 PM   #3
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Mine has been off since the day I bought it and has not gotten any better or worse. I've had a couple of alignments since then. Off maybe 5 degrees to the left.
Old 04-19-2011, 09:34 PM   #4
CRSmoak
My Ride: 2000 328i
Same here but used and to the right, decided to do my own alignment this time to make sure the steering rack is and stays centered (which it was/did), and yet the steering wheel still ended up being off by a few degrees. That said the car drives great, quite a bit better than before. I'll probably put the car on jack stands this weekend though to see what I can find, if anything, will update then.
Old 04-19-2011, 10:55 PM   #5
w0w
My Ride: '02 M3 Vert
random thing to ask but have u ever replaced ur steering wheel? you coulda misaligned it. just thought id mention it
daron
w0w is offline   Reply With Quote
Old 04-20-2011, 03:11 PM   #6
CRSmoak
My Ride: 2000 328i
I haven't but the previous owner might have I dunno, honestly didn't even know you could misalign the steering wheel during replacement/installation but I'll definitely keep it in mind and look into that next, thanks.
Old 04-20-2011, 05:14 PM   #7
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
It's keyed. Can't misalign it. I've checked it.
Old 04-27-2011, 06:49 AM   #8
xdmikey
My Ride: e46 cabrio
after having my local stealerreplace fcabs under warranty(48K iirc)my wheel was cocked pretty good.
i'm glad i traded for my current ride!
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP,f/14 wheels(gone, back to 68s and quickness!)
xdmikey is offline   Reply With Quote
