E46 Convertible
Old 04-13-2011, 10:08 PM   #1
JHW330ci
My Ride: '06 M3 vert, '08 X3
Driver's window auto up & top function
Driver's side window goes down partially when putting top down like all the other windows, but doesn't go back up with the top up/down function is finished. Also won't go up with the all 4 switch, although it will go down. the individual switch will raise or lower the driver's window normally.
Just started doing this a couple of weeks ago. Any ideas??
JHW330ci is offline   Reply With Quote
Old 04-13-2011, 10:10 PM   #2
clt330ci
My Ride: 2002 BMW 330Ci
It prolly jus needs to be initialized
clt330ci is offline   Reply With Quote
Old 04-13-2011, 10:44 PM   #3
JHW330ci
are you talking about having to re-initialze the trap protection after disconnecting power? i did replace the battery.
tried that just now. no joy. any other ideas out there??
Old 04-13-2011, 11:32 PM   #4
johnrando
My Ride: '06 330 CIC ZHP
Don't know, I have the same issue. Let us know the resolution.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 04-13-2011, 11:56 PM   #5
steve330
My Ride: '05 330cic
There's a thread here somewhere about retraining your vert windows if you disconnect the battery. From (my hazy) memory, it's something to do with the auto-seal function when you close the door & the roof is on. Think it involves running the window all the way down & then all the way up & then down again without interruption. HTH.
On his deathbed:
Either that wallpaper goes, or I do.
- Oscar Wilde
steve330 is offline   Reply With Quote
Old 04-14-2011, 12:04 AM   #6
mach.schnell
My Ride: 08/2000 330Cic x2
That should be a sticky if it's written well.
And not meaning to hyjack the thread, but when you use the key to open the top, why do the windows wind up closing at the end rather than opening? Am I wrong to think that if you want the top down you'd want the windows down too?
mach.schnell is offline   Reply With Quote
Old 04-14-2011, 08:12 AM   #7
steve330
My Ride: '05 330cic
I haven't tried the key-in-the-door opening method. I'll try it and let you know if the windows are up or down at the end.
On his deathbed:
- Oscar Wilde
