Old 04-14-2011, 02:23 AM   #1
BluBMW330ci
My Ride: 01 330Ci
Angle eye problem
Anyone have this problem with angle eyes...that everytime I turn on my lights they randomly have some dim and some bright? For instance first tried them out 3 were bright 1 was dim, turned off let sit turned back on then 2 were dim 2 were bright, sit turned back on 3 bright 1 dimmm then again a 1 bright 3 dim. So every time i turn them on there diff! Can any1 help me or that has had this problem and corrected?
BluBMW330ci is offline   Reply With Quote
Old 04-16-2011, 12:53 PM   #2
scottie46
My Ride: 2001 330i
are these ccfls?
scottie46 is offline   Reply With Quote
Old 04-16-2011, 01:29 PM   #3
infinite012
My Ride: White '08 STI
If they're CCFL, it's just the nature of the beast. You could try replacing inverters or even the rings, but you'll likely end up with this same problem eventually.
infinite012 is offline   Reply With Quote
Old 04-16-2011, 07:40 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
They are CCFL, you can see the ballast up top.
OP just get LED ae's
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 04-17-2011, 10:35 AM   #5
davidmic
My Ride: 2003 M3
could be moisture in the ballasts..happened to me and I had to replace them ($13 for 2), but try giving it a couple of minutes when they are on, the need to warm up because they are ccfl. They usually will all be the same brightness after a few minutes. Or like solidjake said get the LED angel eyes.
davidmic is offline   Reply With Quote
