Old 04-14-2011, 03:26 PM   #1
wessactor
My Ride: 04 330i
2004 330i w/ 38K mi Hesitation, VANOS?
The car is hesitating under load at 2,000 - 3,000 RPM, intermittently. SES light comes on and off. I've read a lot of posts about VANOS issues and wonder if it could be the issue in my case. Is it probable at 38K miles?
wessactor is offline   Reply With Quote
Old 04-14-2011, 08:00 PM   #2
mrshelley
My Ride: 2004 330i
I suggest running the codes and then post the results. It could be at least 20 different things and we could guess at this for the next few weeks and still be wrong.
Old 04-14-2011, 08:31 PM   #3
wessactor
My Ride: 04 330i
I scanned the codes with an ODBII and they were 2240 and 2237. I cleared them and after another 150 the light came back on again only to go off on it's own a little later.
Old 04-14-2011, 10:53 PM   #4
Steven747
My Ride: 05 330ci
of course you could say clean icv maf this and that change out vanos seals spark plugs air filter idk too many things even though it went away that dosent mean its fixed id say dig deeper
Old 04-15-2011, 12:04 AM   #5
wessactor
My Ride: 04 330i
Yeah, I was just wondering if it's common for VANOS seals to go out that early.
Old 04-15-2011, 07:14 AM   #6
TxZHP04
My Ride: ESS TS2+ ZHP
Your problem isn't vanos seals, those codes would seem to indicate you have a different problem. The codes would seem to indicate a problem being detected at the O2 sensors but it's very unlikely that both have gone bad at the same time and at this low mileage. Further diagnostics will be needed.
Old 05-09-2011, 01:42 PM   #7
M_Power_D
My Ride: 2004 330Ci 6-speed
wessactor, I'm having the same issue. Did you find a cause/resolution?
M_Power_D is offline   Reply With Quote
Old 05-09-2011, 03:16 PM   #8
wessactor
My Ride: 04 330i
not yet. plan on taking it in for diagnostics within a few days. i'll post the results once i get it fixed
Old 07-14-2011, 04:55 PM   #9
M_Power_D
Hey Wessactor, any results from the diagnostics?
Old 07-14-2011, 08:16 PM   #10
wessactor
My Ride: 04 330i
yeah, the ECU needed an update, that's it. I ended up paying $300 to get it done. Good luck
Old 07-15-2011, 10:06 AM   #11
M_Power_D
Great thanks for the quick reply. I assume it was a dealer only fix since they probably need the right computer etc?
