Old 04-19-2011, 05:41 PM   #21
waxman
My Ride: 02 330xi
Originally Posted by JJR4884 View Post
lk
Wow, you guys have officially clogged my thread with rhetoric!
2002 Steel Gray 330xi
2003 Explorer XLS
2006 H-D 1200XLC
waxman is offline   Reply With Quote
Old 04-19-2011, 05:42 PM   #22
waxman
My Ride: 02 330xi
Somebody please call Roto-Rooter!
2003 Explorer XLS
2006 H-D 1200XLC
Old 05-20-2011, 03:50 PM   #23
Dedney
My Ride: 325i
Going to Autozone tonight to see what I can find.
2001 325i
Dedney is offline   Reply With Quote
Old 05-20-2011, 03:59 PM   #24
spencers
My Ride: 2006 330i
$12 for the replacement rubber from the dealer, can't beat it...
+1
OE refills FTW
spencers is offline   Reply With Quote
Old 05-20-2011, 04:04 PM   #25
tks
My Ride: slower than yours
dmax go write a book.
as for the OE refills, next time I am going to make sure I receive the right ones because when I went to install my inserts they were about 4 inches longer on both sides and I had to cut the rubber and metal in order to fit them.
tks is offline   Reply With Quote
Old 05-20-2011, 04:12 PM   #26
Dedney
My Ride: 325i
What are the sizes? 22 & 23?
2001 325i
Old 05-20-2011, 05:04 PM   #27
Mr_325
My Ride: 2007 X5 3.0Si
in the fact that i put on some shitty rain-x aftermarket market blades and i believe the oem have been tossed will i be able to purchase new OEM blades?
whenever i look i only see inserts
or... should i just stay with aftermarket blades?
Mr_325 is offline   Reply With Quote
Old 05-20-2011, 05:55 PM   #28
DBrown
My Ride: BMW 325 Ci
Just take off that clip on the driver side wiper arm and use whatever blades you want. I just use the Michelin ones from Costco and throw em out. My opinion, no need for the fancy wiperblades, they all wear out around the same time anyway. They're just wiper blades, it's not like they are crucial to how the car functions.
2001 325 Ci
DBrown is offline   Reply With Quote
Old 05-20-2011, 06:03 PM   #29
cityjohn
My Ride: 2001 M3
That's how the OEMs are supposed to work. Dealer stocks one length and tech cuts to fit. That's why the metal strips have little cutlines pressed into them -- you'll see there's one that matches your car.
cityjohn is offline   Reply With Quote
Old 05-20-2011, 06:05 PM   #30
xavi330i
My Ride: 2004 330i smg
I need to stop my wipers from skipping across the windshield.
xavi330i is offline   Reply With Quote
Old 05-20-2011, 06:08 PM   #31
miggitymike
My Ride: e46 SEDAN
dmax do you like bacon?
miggitymike is offline   Reply With Quote
Old 05-20-2011, 06:21 PM   #32
GoingNuts
Just Nuts
My Ride: 2004 330Ci
He does if you promise to disconnect your battery and check the fuses.
GoingNuts is offline   Reply With Quote
Old 05-20-2011, 06:26 PM   #33
OrientBlau
My Ride: 2003 330i
Bacon is freakin awesome.
All truth passes through three stages. First, it is ridiculed. Second, it is violently opposed. Third, it is accepted as being self-evident. - Arthur Schopenhauer
OrientBlau is offline   Reply With Quote
Old 05-20-2011, 06:29 PM   #34
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Eggs,eggs,spam, eggs, and spam...and F1
Migg, I'm curious what interest it is of yours...trying to run through the possibilities here.
If this was somehow a lead in to a joke, you'll have to explain it. If this meant I should render my writing and boil it down...you could have just made that request.
But otherwise, I'll say that in a wiper blade thread, I don't feel particularly compelled to be particularly focused or on target. The answer is so easy, it's painful. We have a devoted wiper blade guru here and I just put on whatever he says...and it's always OE. Only thing on the car that's cheaper and better than all others.
This is a wiper blade thread; another in a long line, and not nearly as important to our cars as oil threads.
And, now that I'm off the phone, I'll admit I really do like bacon. Do 'you' like bacon?
I'm off phone so if I wrote something stupid, it was probably was still the phone!
Facebook.com/DMAXstandup
Mangofy your E46!
dmax is online now   Reply With Quote
Old 06-07-2011, 12:59 PM   #35
TwiztedTD
My Ride: 2000 328i
Hi everyone, I replaced my wipers on my car with a rainx brand. I also cant find where I put my oem ones.
But my driver side wiper skip a lot. Especially when on the highway. I noticed a plastic clip thing that looks like it holds the wiper down, but it seems like its interfering with the new wiper from fully staying on the windshield.
Should I take off the plastic clip/ I cant really see an easy way of taking it off without breaking it lol.
TwiztedTD is offline   Reply With Quote
Old 06-07-2011, 01:18 PM   #36
mad_polo
My Ride: E46 320
I've got the Evo wipers from BMW and they look pretty sweet and theyre good at getting rid of the water...
mad_polo is offline   Reply With Quote
Old 06-07-2011, 03:30 PM   #37
Zell
Zell's Avatar
My Ride: so turbo wow
Yes, that will fix it.
Can you help me locate this clip? I've had mine skip a few times, too.
Edit: Figured it out. It is a small clip right where the spring is for the wiper arm. Just push it forward towards the wiper blade with some force and it'll pop right out. Discard it unless you ever want to go back to non-uniform blades.
http://forum.e46fanatics.com/showthread.php?t=819640
This thingy.
Old 06-07-2011, 03:36 PM   #38
mad_polo
My Ride: E46 320
Theres a metal bit from the wiper arm that fits inside the plastic bit... I removed mine as i had the same problem as you, its fixed it... and i havnt had any issues! (removed it two years ago...) its difficult to take off btw... i ended up using a small terminal screw driver and a lot of patience...
