Sponsored by BimmerWorld
Old 04-15-2011, 07:52 PM   #1
trippmann
My Ride: E30
Send a message via AIM to trippmann
Drivers side rear clunk
Ok really simple, installed h&r cup kit on my 2000 323i, shock mounts are "new" bought them last summer, after cupkit install I've got a clunk from the drivers side rear when ever I go over a bump, most any bumps really. Also my rear swaybar endlinks are new just installed them today, thoughts or ideas?
Sent from my DROIDX using Bimmer App
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 04-16-2011, 03:50 PM   #2
trippmann
My Ride: E30
Bump for advise?
Old 04-16-2011, 07:22 PM   #3
Stealthwagen
My Ride: '00 323iT / S54 6Spd
noises
I had an H&R kit on my 323 wagon and had this problem. The H&R springs were shorter than the OE springs and under certain conditins, the suspension would unload (say, going diagonally up a driveway ramp) and would lift off the perch on the shock, thunk clunk when recompressing the suspension.
Jack up the rear of the car. If the rear trailing arm droops to the point where you can easily move the spring, this is probably your noise source.
BMW sells several rubber spacers in different thicknesses that can help keep the spring from becoming loose and banging around. GL
Grocery Getter
Stealthwagen is offline   Reply With Quote
Old 04-17-2011, 12:43 PM   #4
trippmann
My Ride: E30
i orignally suspected this also, but the problem only happens when the rear drivers side spring is compressed is when it clunks. i tested this by backing up my driveway making my drivers side hit the lip first, and it clunked. i had a friend back the car up again with me in the trunk so i could watch the shock mount, and its not the shock mount. so im thinking it could be the rtabs. probably go with powerflex with limiters.
Old 04-18-2011, 12:21 PM   #5
trippmann
My Ride: E30
before i buy anything, would the rtabs cause this?
Old 04-19-2011, 07:03 PM   #6
slixx1320
My Ride: AW ///M3
Send a message via AIM to slixx1320
Has the RTAB's ever been replaced? What about the RSM? If they are both stock I would recommend replacing both if you have the extra cash. If not start with the RSM first. Same thing happened to my brother's car. Looks fine from the outside but when he went over bumps (how you described) it clunks. He replaced both his RSM and problem solved. Though the week prior to that he also replaced his RTAB's so that ruled out the RTAB problem. Only option left was his RSM.
slixx1320 is offline   Reply With Quote
Old 04-19-2011, 10:23 PM   #7
trippmann
My Ride: E30
RMS's were replaced last summer, had a few hundred raceland miles on them, then went back to the stock suspension with the broken rear springs, then went to the h&r cup kit.
the clunk i believe had began before the H&R kit was installed but was not as prevalent due to the softer springs. so it could be the RMS's but i doubt it. im probably going to pick up a set of RE shockmounts at eurofest if they have them
All bushing in the rear are stock to my knowledge. i bought the car with 89,000 miles and it now has 115,000 miles. this summer all bushing are going to be replaced with powerflex's.
Old 04-19-2011, 11:12 PM   #8
w0w
My Ride: '02 M3 Vert
check your rsm's and make sure the rubber bushing isnt all chewed up. take a pic so we can see what it looks like. ive had brand new oem rsm's wear out in less than 3k miles. besides that you might have an issue with your endlinks as well
daron
w0w is offline   Reply With Quote
Old 04-20-2011, 07:41 AM   #9
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
My Meyle HD mounts only lasted about a year. Check them (easiest), replace your RTABs, and check your differential mounts and subframe mounting points.
Old 04-20-2011, 08:12 AM   #10
SiLVeR_E46
My Ride: 2003 325i sedan
I'm having the same problem with my H&R cup kit
SiLVeR_E46 is offline   Reply With Quote
Old 04-20-2011, 08:21 AM   #11
K Cuv
My Ride: Z32 & AW E46
see if your strut came through the mount or if its giving and is about to - without the proper washer on the underside of the mount, that little rubber bushing in the mount wont last a day. good luck man
K Cuv is offline   Reply With Quote
Old 04-20-2011, 09:59 AM   #12
trippmann
My Ride: E30
pics for everyones enjoyment.
Struts dissasembeled
Top of RSM
Bottom of RSM
Up close view of top of RSM
Assembled shock
Top of assembled shock
Up close of assembled shock
The right side is exactly the same. all pictures are of the left side where the problem sounds like its comming from
Old 04-20-2011, 10:02 AM   #13
trippmann
My Ride: E30
Just to clarify, i replaced both endlinks last week and are both in good condition as of today.
The rest of the rear bushings are stock.
And the shock mounts are OEM, non HD
Old 04-21-2011, 01:27 PM   #14
trippmann
My Ride: E30
bump
Old 04-21-2011, 11:59 PM   #15
trippmann
My Ride: E30
Bumpage
Old 04-22-2011, 05:53 AM   #16
aggieE46
Keep it clean
aggieE46's Avatar
Did you check your differential bushings and subframe mounting points?
You'd be wise to do a full rear bushing overhaul.
Old 04-22-2011, 06:58 AM   #17
TxZHP04
My Ride: ESS TS2+ ZHP
Have you verified that the sway bar isn't contacting either the control arm or half shaft (or maybe even the diff cover if your rear diff bushing is in really bad shape)?
Old 04-22-2011, 10:42 AM   #18
trippmann
My Ride: E30
this summer im doing a whole rear end overhaul. so i may justhave to live with it for awile
Have not checked that yet, ill give that a look today.
Old 04-23-2011, 04:39 PM   #19
trippmann
My Ride: E30
bump. not the sway bar.
Old 04-24-2011, 05:53 PM   #20
trippmann
My Ride: E30
last bump before i let the thread die for a few months. in june, or july i will be upgrading the swaybars, doing the rtabs, diff bushings, subframe bushings.
