Old 04-16-2011, 05:00 AM   #1
Jayp07
My Ride: E46 3.18i, E30 3.20i
2000 E46 3.18i - Horrible engine ticking but no Vanos?? See video!
Hi all,
My engine is making a horrible ticking sound as you will see here...
I had something similar not too long ago which turned out to be the water pump but this is definitely something else.
Any help would be much appreciated. Cheers.
Jason
Jayp07 is offline   Reply With Quote
Old 04-16-2011, 09:58 AM   #2
colo330xi
My Ride: 01 330xi
Does the sound follow the engine RPM? It sounds kinda stupid, but wouldn't hurt to check that the spark plugs are torqued and that the plug wires are on tight. I've had a similar noise on motorcycles from spark plugs vibrating their way loose.
colo330xi is offline   Reply With Quote
Old 04-16-2011, 03:05 PM   #3
Jayp07
Thanks for the post mate, yeah the ticking gets faster as i accelerate, what are you thinking it could be? ... with regards to the spark plugs i'll take a look at this stage i'll try anything quick to eliminate a possible cause.
Old 04-16-2011, 03:44 PM   #4
Andy2108
My Ride: SpecE46 & E46 M3
How many miles?
Injectors also make a ticking noise, but would only be that loud if they were destroyed.
De gustibus non est disputandum.
Old 05-28-2011, 05:30 PM   #5
Jayp07
UPDATE: Right I took the plugs out to check for any oil... Nothing! The plugs looked very healthy. So that eliminated scored cylinders for me but that didn't provide a solution to the problem. Then I got a stoke of luck.. while the plugs were out i turned the engine over to blow out the cylinders then cleaned and replaced the plugs... NO MORE KNOCKING... whether it was the plugs or the heat shield knocking i cant be sure (im thinking one of the plugs) either way its been a full week and no more problem. Happy Days!
Old 05-28-2011, 05:40 PM   #6
new//M3fan
My Ride: 77' 924 87' E30
Nice! I've actually seen spark plugs that when tightened the ceramic end becomes loose which may let pressure out of the cylinder through it.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 05-28-2011, 05:53 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
First thing I would have said is to make sure the plugs were torqued properly, but I'm glad you fixed it.
Old 05-29-2011, 07:33 AM   #8
Jayp07
Thanks Lads! You live and learn... (i've never owned a torque wrench... i know i know, don't say it - it's a must have!).. I will repost if it comes back. For now i have to figure out why i'm losing so much water!?
Old 11-25-2012, 07:21 PM   #9
Jayp07
Hi All,
Thought I'd come back and update my thread.
The ticking came back and continued on and off for the next year or so... it got worse and worse. Thankfully I finally got it sorted:
PROBLEM SOLVED!! - 2000 E46 BMW 3.18i Saloon - Ticking Noise
I bought the following parts:
Hydraulic***65279; Tappits
Oil filter + plus the O rings etc
Oil
Rocker Cover gasket
Oil Filter case Gasket
Total 130.00
This noise has conclusively STOPPED!!! Finally!!! Happy Days!! The work took a day to do... The bad tappit that came out had about 7mm play on it meaning that you could pull it in and out with your fingers. You cannot do the same with the new ones nor the other ones that came out. That's where the noise comes from. I left the car over night then started it in the morning with fingers crossed...... No more ticking! Job Done! - 140 labour
2000, 3.18i, e46, ticking
