Homemade Fan Nut Tool (water pump pulley holder) w/Pic - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 04-16-2011, 07:12 PM   #1
gsbmw
My Ride: 2000 323i
There are a number of methods to immobilize the water pump pulley when loosening the fan nut with a 32mm (or 1-1/4”) wrench. I tried "hammering-the-wrench", screwdrivers, etc but nothing worked for me, so I easily made this tool, which some may find useful. The nut loosened easily right away.
It’s just a piece of aluminum bar (1” x 1/8” x 36”) with a 1/2“ diameter hole drilled near the end (approx 1/8“ from one side of the bar) for fitting over one of the 10mm water pump bolt heads.
I bought the bar at Home Depot for about $6. Aluminum is a soft metal, so it was easy to drill through it with a standard 1/2” drill bit. Just took a couple of minutes to make. It’s best to aim at having the hole about 1/8“ from one side of the bar, so that it fits easily between the bolt and the axis of the water pump behind the nut. (My drill bit drifted a bit, so the hole in mine was almost in the middle of the bar [~1/4” from the sides]; it still worked but closer to the side is better.) The aluminum bar is softer than anything it will press against, so nothing will be damaged by it. And the bar can be flexed outward to avoid the thermostat if needed. This long bar gave a lot of leverage, but shorter bars are also available at HD if you prefer. Below is a picture of how the bar fits over a bolt (of course, the fan with nut was removed to allow this picture).
gsbmw is offline   Reply With Quote
Old 04-30-2011, 07:34 PM   #2
jazzyjeff
My Ride: 05 325cic
While the "hammering the wrench" trick always works for me, this is a great DIY. I love cheap little ideas like this that can save people a lot of headaches!
jazzyjeff is offline   Reply With Quote
Old 09-27-2011, 05:23 PM   #3
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
good stuff!
B is offline   Reply With Quote
Old 09-28-2011, 12:42 AM   #4
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
awesome! thanks for sharring
Old 10-02-2011, 09:11 AM   #5
gsbmw
My Ride: 2000 323i
Smile
Thanks to all! Happy to help.
Old 11-15-2011, 07:38 PM   #6
sonnybobiche
My Ride: '99 323i
FYI for anyone who attempts this... if you make it 1/8" from the edge as advised, the aluminum WILL break. (I used the exact same bar of aluminum from Home Depot and that's what happened this morning. Best to aim somewhere around the middle.
sonnybobiche is offline   Reply With Quote
Old 11-17-2011, 06:57 PM   #7
dino71
My Ride: 2003 BMW 330i
What happens when you bend one of those bolts and throw the pulley out of balance and then run the possibility of ruining the engine, isn't it better/cheaper to go buy a used 32mm (even used on Ebay) open end wrench and a hammer?
dino71 is offline   Reply With Quote
Old 12-19-2011, 09:23 AM   #8
gsbmw
My Ride: 2000 323i
The problem is that the hammer method doesn't work for everyone (like me), even after many many tries. I used the 32 mm wrench together with two heavy duty nailing hammers strapped together for more mass (also tried a heavy mallet), but could not get the nut to budge. The hammer method has other drawbacks, such as needing to pad carefully any plastic that the wrench will bang into on the driver's side (for example the air filter box, radiator hose couplers, etc). I damaged my air filter box using the hammer method when the force of the hit made the belt slip on the pulley. I even tried tightening the belts by depressing them between pulleys to prevent slippage, but none of these attempts worked to loosen the nut over at least an hour of trying. (Of course, I was hammering in the correct direction for this reverse-threaded nut—toward the driver's side (USA).)
The aluminum bar tool worked surprisingly easily on the first try by just pushing the bar and the wrench in opposite directions by hand—no hammering necessary. The length of the aluminum bar gave a lot of leverage and uses the same principle as the commercial steel water pump holding tools that cost $30 or more. The soft aluminum is much gentler to the water pump bolts than the commercial steel tool. There was absolutely no damage to the bolt(s) or the pulley after using the aluminum bar, even after establishing that the nut was unusually well-seized. In contrast, you may see a bolt indentation in the aluminum bar, which effectively spreads the force over a wider area of the bolt so as to be less likely to damage it.
By the way, the bar is long, and if your first drill hole does not work well for you for some reason, just move up the bar an inch and drill another in a better spot. Takes 10 seconds. Because the fan needs to be removed for so many engine diys, it just makes sense that people should have some sort of nut tool available at all times. This is just one of several out there, but to me it's the best combination of effectiveness, ease-of use and low cost, and any diy-er can make one easily and quickly.
Old 01-09-2012, 11:19 PM   #9
trj
My Ride: 325Ci
Use of proper tool is always the best, whether you make it or buy it.
Don't use the hammer, because when you combine hammer with anger and frustration of that fan clutch nut being so tight and seized, bad things happen. Like the upper radiator hose breaks, the pulley bolt snaps Ask me how I know.
Old 01-01-2013, 11:50 PM   #10
Westrace
My Ride: 06 G35, 04 M3 Coupe
Great DIY. I need to replace my water pump and I was going to use the hammering away technique to remove the fan but this seems like a perfect low cost solution.
Westrace is offline   Reply With Quote
Old 01-15-2013, 06:47 PM   #11
t60
My Ride: Not a BMW anymore :(
Great idea but it only works on paper. The metal is too soft and pretty tough to get the correct measurement. For how often you will work on our car, I say go OEM all the way for this.
t60 is offline   Reply With Quote
Old 01-15-2013, 07:13 PM   #12
Westrace
I was going to try the DIY method here over the weekend, but I thought I would try just banging on the 32mm wrench. Much to my surprise, after a banging couple of times, I was able to get the nut loose. I think it depends on whoever tightened it the last time.
Old 06-08-2013, 12:19 PM   #13
CORVAIRWILD
My Ride: Diesel Subrban 325xi
I guess I can make a 32mm opening in a piece of steel. I was here yest...
In a junkyard, under a Teeruk!
CORVAIRWILD is offline   Reply With Quote
Old 06-09-2013, 04:55 PM   #14
trippmann
My Ride: E30
Send a message via AIM to trippmann
I was able to pick up a set of BMW fan nut and pulley holding tools for $20 on here. Search guys, good deals are floating around.
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 06-09-2013, 09:52 PM   #15
CORVAIRWILD
anybody got one for me? and a LR shock?
Old 07-24-2015, 09:15 PM   #16
TMiller e39'er
My Ride: 03 525i
Thanks to gsbmw! I followed his instructions and it really works! $6.50 in 1"x1/8"x36" aluminum strip; $3.50 for 1/2" drill bit; $12.00 for 1-1/4" wrench. Inexpensive! Only suggestion might be to drill a smaller pilot hole in the aluminum, helps keep the 1/2" bit from drifting.
TMiller e39'er is offline   Reply With Quote
