#1 |
Newbie - Busted Taillight and Taillight connector
Hello,
I had a cracked taillight few months back, and few weeks back, my car started behaving werid with tailight warning. I changed the light bulb and after few days, it stopped working again. When I checked, the connector had melted. So I went ahead and ordered these parts: QTY Part Number Description 1 63 21 7 165 865 Bulb Carrier for Taillight Left NOTE: This carrier holds 4 bulbs. 1 63 21 6 946 533 Taillight with Yellow Turn Signal for Fender Left 1 12 52 7 519 956 Connector Socket for Bulb Carrier Fender Taillight Left/Right (2 Per Car) Now that I wanted to change the taillight I searched on how to do it, and found out that this apparently is a known issue. How does one go about changing the connector? removing the wires from the connector and putting it into the new connector? I thought the connector would open up (like a book) where I would align the wires and snap it back in place, but that doesn't seem to be the case. Thought I would start a new thread, as I'm replacing the lens as well as the indicator issue, so could get help on both. Any help, suggestions, guidance, tips? Disclaimer: This is my first DIY |
| Tags |
| burnt, connector, ground, lens, tailight |
