E46 Convertible
Old 02-06-2014, 12:09 AM   #21
JoeRoundel
My Ride: E46 330xi
Drew - I am using the same cable as you. Its a 6 inch adapter cable made by Apple, I bought it at Target. Try this: Get to a point where you are starting all over... unplug everything, flip all the switches on the unit around and then set them where they go, make sure the CD player works, just get everything back to normal. Then plug everything back in and set it up the same way you did when you got the 30 pin working. I use my iPhone 5 with this thing every day, there's gotta be something out of place in the setup.
JoeRoundel is offline   Reply With Quote
Old 02-06-2014, 11:12 PM   #22
werdstrave
My Ride: 2001 330ci
This is getting crazier by the minute. I took the cable back to apple store. They tried it on a 5, 5s, and 5c and it gave the same not compatible error on all screens. The cable was defective. We opened up another cable from the store and the same thing happened. Apparently apple is selling crap cables. We looked online and have seen some reviews stating the same errors from those cables. Maybe you got a lucky one from target or maybe target is carrying special ones made by apple. It won't hurt to try so I think I might head to target and try this weekend. So bizarre. If the ones from target won't work, I may have to start picking off some 3rd party ones and see if they work. Unreal.
werdstrave is offline   Reply With Quote
Old 02-09-2014, 12:15 PM   #23
AquilaBMW
My Ride: 325i Convertible
Hi Guys - I was searching for this adapter for my car and came across one on Amazon. It states it "iSimple ISBM72 iPod Interface for BMW without DSP 5-Volt Cable", here is the link: http://www.amazon.com/iSimple-ISBM72...P+5-Volt+Cable.
Do I need something additional with this kit?
AquilaBMW is offline   Reply With Quote
Old 02-09-2014, 10:10 PM   #24
werdstrave
My Ride: 2001 330ci
UPDATE on my issue. I returned apples cable and bought the exact one from target. The difference, the one from target actually worked! No error on my screen and when I plugged it into the isimple, nothing but sweet tunes came out with steering wheel controls. So pumped. Thanks for sticking with me on this one Joe. If anyone is in the same boat as I was, try the adapter first by plugging it into your iphone before you buy. If you get an error on screen it will not work with the isimple. Apparently target has ones that work. Apple store is a no go.
To AquilaBMW. I have not installed this system, my car came with it. Hopefully someone chimes in for you.
-Drew
Old 02-09-2014, 10:42 PM   #25
JoeRoundel
My Ride: E46 330xi
-Drew
Awesome Drew! Glad I could help, enjoy the tunes!
Old 02-09-2014, 10:50 PM   #26
JoeRoundel
My Ride: E46 330xi
That is the same cable I ordered and use. It comes with the 30 pin iPod connector, so if you want to use an iPhone 5 you need an adapter. Werdstrave had a tough time with the ones from the Apple store. So far both of ours are working with the adapter you buy at Target.
Old 02-13-2014, 01:27 AM   #27
AquilaBMW
My kit just arrived today... wish me luck. I will hopefully be able to install by this weekend or sooner and will report back.
Old 02-14-2014, 11:56 PM   #28
AquilaBMW
I installed my kit today. It worked / works great. I decided to route my cable on the Left Side / Driver's to the trunk area running with the car's harness on that side.
Old 02-15-2014, 12:02 AM   #29
werdstrave
My Ride: 2001 330ci
Nice!
Old 02-16-2014, 01:04 AM   #30
JoeRoundel
My Ride: E46 330xi
Cool man, enjoy the tunes!
Old 08-16-2014, 11:25 PM   #31
JoeRoundel
My Ride: E46 330xi
Just wanted to post an update to this thread as it may be helping people that are finding it in their searches.
I have had a few instances where my iSimple stopped recognizing my iPhone 5 with the adapter and no music would play. I have fixed this by using a small piece of wire, or a paperclip even, to pick out the lint from inside the lightning connector slot on the phone. As you put the phone in and out of your pocket, lint inevitably builds up within the connector slot. Carefully extract the lint and you should be good to go.
Believe it or not, I don't work for iSimple, I just really dig what this product does.
Cheers,
Joe
Old 05-02-2015, 10:48 PM   #32
2006bmw330cizhp
Account closed.
I know this is a old thread. My question is. What's the dsp. My radio has a dsp button and the mode button. Do I need something different?
2006bmw330cizhp is offline   Reply With Quote
Old 05-31-2015, 07:35 PM   #33
werdstrave
My Ride: 2001 330ci
Joe,
I know we spoke about this a little while ago but my iphone 5 has recently had issues when plugged into the lightening cable here. If it gets jostled when driving, it will disconnect itself, sending the stereo mode to radio and iphone streaming music to cease (Super annoying)! It seems to have the same "loose" connection when I plug it in to charge at home (won't charge sometimes unless jiggled). I'm wondering if my port is getting worn out or if its the same lint issue you had. I'll try cleaning it out but just wondering if anyone else is having this poor connection problem with the lightning cable....supposedly and upgrade by apple but personally, the 30 pin design was a lot more solid, especially back in the iphone 3 days when that sucker was locked in with those clips you had to push on from either side!
Old 05-31-2015, 07:35 PM   #34
werdstrave
My Ride: 2001 330ci
Joe,
Old 05-31-2015, 08:19 PM   #35
werdstrave
My Ride: 2001 330ci
Ha, dug the lint out and it totally did the trick, perfect connection!
Old 08-19-2015, 04:31 PM   #36
BruceN
My Ride: 330i
Problems with the output of audio from the ISBM72
After reading this thread, I made the decision to purchase an ISBM72 for my 2003 330i. Its fitted with a CD35 head unit and 6-CD changer. The install is pretty easy, and all seemed to work ok apart from the audio. It was at an extremely low level - and nothing I did seemed to resolve the issue (no problems controlling the Ipod). So, after some technical support discussions, it was recommended that I return the unit as it was probably faulty.
I received a replacement, and sadly, I have exactly the same fault. Interestingly, I've discovered that I can make the unit work ok by temporarily removing then replacing the small connector from the cable harness. But, this is fine when the car is not running, as soon as the engine starts it reverts to the low audio level - buried in amongst a heap of electrical noise/static. I believe the head unit is ok, as it works fine with the CD changer. Would appreciate any thoughts or ideas! Cheers
BruceN is offline   Reply With Quote
Old 08-19-2015, 04:43 PM   #37
werdstrave
My Ride: 2001 330ci
It sounds like you have an interference issue from other wiring. If your unit is like mine, it's in the trunk next to the CD changer. I'm running the long black cable under the back seat and up the side of the center console. There are a lot of wires for various things (including the amp I believe) under or near that seat. Try different routing methods and see if that clears things up.
On the topic of sound quality, I've noticed that my 2001 330ci convertible stock stereo has TERRIBLE sound quality. Especially when compared with my buddy's 2004 330ci. I'm not sure if anyone knows whether BMW upgraded the system between these years or if my amplifier is just on its way out, but PLEASE let me know. My buddy's stock system sounds so crisp and hits hard while mine sounds like music is playing in a box. Forwarding me to another thread about this would help a lot. Thanks!
Old 08-19-2015, 05:45 PM   #38
BruceN
My Ride: 330i
Thanks, I'll have a look at re-routing the cable but I'm dubious about whether that will have any real impact. It seems to me to be an issue with the compatibility between the ISBM72 and the head unit.
Old 08-30-2015, 03:34 AM   #39
BruceN
My Ride: 330i
Well, after a lot more testing I have given up and returned the unit as it isn't going to work with my head unit. Very frustrating!
