Old 04-19-2011, 01:14 PM   #1
adame46man
My Ride: 2005 330i ZHP
272 cam?
I'm in the market for a cam and I see you can buy 272s instead of the 264 s I'm wondering if anyone has tried them yet?
Sent from my Droid
Bimmerbrakes Headers, Magnaflow Catback Exhaust, Rogue Power Pulleys,Active Autowerke Software, Clear corners, side and tail lights, APEX ARC-8 wheels
adame46man is offline   Reply With Quote
Old 04-19-2011, 01:35 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Sent from my Droid
They're made to run in a higher RPM band, that your M54 motor was not designed to operate in. Also you'll loose some low end torque. That's why we
all run the Schrick 264 degree (10.5mm lift) intake and 248 degree (10mm lift) exhaust cams.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-19-2011, 01:38 PM   #3
adame46man
Alright finally a straight answer. The 264/248 worth it then?
Sent from my Droid
Old 04-19-2011, 02:35 PM   #4
Rob43
Rob43's Avatar
Sent from my Droid
YES.
But realize that you need to do quite a few things to your motor to really get the benefit from your cams.
1) Cams
2) Header & full exhaust
3) CAI
4) AA software, group buy
5)Pulleys
Options, no WHP, but feels great.
1) LTW flywheel
2) 3.46 Diff
3) LSD
Good Luck
Old 04-19-2011, 02:56 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
He'll still notice a nice difference from the cams, even if the car is otherwise stock. But you're right, to get the most out of them, headers and tuning.
Old 04-19-2011, 03:04 PM   #6
adame46man
I've got all those and the TB and I'm on the group buy for the software!! Thanks for the info!
Sent from my Droid
Old 04-20-2011, 12:14 AM   #7
Rich V
My Ride: BMW
Aggie, I've read your dyno thread; good info. Kudos for the time and effort you put in to record everything.
I have a 2001 330i as my daily driver and my only gripe is lack of power. I was planning on Schricks, Headers, and software only. I have no intention of putting an exhaust and will likely do a BMW performance intake. Seems to me that cams, headers, and software are the biggest bang from a performance stand point; would you agree based on your experiences?
Rich V is offline   Reply With Quote
Old 04-20-2011, 06:02 AM   #8
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
A light weight flywheel has a huge affect as well.
Old 04-20-2011, 06:59 AM   #9
aggieE46
Keep it clean
aggieE46's Avatar
This was one of my favorite mods.
Old 04-20-2011, 07:14 AM   #10
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
You're up early! What a surprise.....
Old 04-20-2011, 07:33 AM   #11
aggieE46
Keep it clean
aggieE46's Avatar
Haha always. My most favorite mod wakes us up right at 5AM every day. He has good pipes!
Old 04-22-2011, 09:53 PM   #12
adame46man
Headers.... worth every hour!
Sent from my Droid
Old 04-23-2011, 02:09 PM   #13
adame46man
Just wondering if anyone can give me an install time on the cams... not shop in my garage with a mechanic that has done cams before but not on a BMW.?
Sent from my Droid
Old 04-23-2011, 03:39 PM   #14
Rob43
Rob43's Avatar
Sent from my Droid
PM sent.
Old 04-23-2011, 10:12 PM   #15
Cruzader
My Ride: Alpinweiß facelift
264 is a good choice. Made a nice difference in my friends car
Cruzader is offline   Reply With Quote
Old 04-23-2011, 10:14 PM   #16
Steven747
My Ride: 05 330ci
just wondering but i thought i heard somewhere that pulleys with a lwf can mess some stuff up?? maybe it was just pulleys that underdrive the crank shaft + the lwf?
Old 04-23-2011, 10:26 PM   #17
adame46man
You don't underdrive the crankshaft ...
Sent from my Droid
Old 05-08-2011, 11:21 PM   #18
Steven747
My Ride: 05 330ci
Sent from my Droid
ok cool and i havent seen any dynos to this date showing + hp from pulleys maybe 1 or 2 but i deem not worth it.. id say best bang for buck would be 3.46 diff and headers.. the lwf and tune
Old 05-09-2011, 11:37 AM   #19
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I don't think pulleys are worth it. Has anyone else tried the 264/256 schrick setup?
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 05-23-2011, 02:37 PM   #20
sgtghost69
My Ride: 2003 BMW 330i
i dont know if its been asked already but how much do the schrick 264/248 cams go for?
sgtghost69 is offline   Reply With Quote
