How hard to remove/replace brakes for painting? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-19-2011, 03:54 PM   #1
radarcontact
My Ride: 2006 330CiC/ZHP
I'm about to replace my rotors and pads. Want to paint the calipers while I'm at it. Would like to take them off, then clean and paint them off of the car. Easier to paint, and therefore better result I would think.
How much PITA is the removal, install process compared to just coat hangering them and doing my best to paint? Consider that I can delete the masking off everything process.
radarcontact is offline   Reply With Quote
Old 04-19-2011, 04:00 PM   #2
CylonRed
My Ride: '01 E46 330i sport
Search for replacing rotors and you should be what it takes to get the calipers off - from my memory not that big of a deal... You can also look on RealOEM.com to see how they are held on.
CylonRed is offline   Reply With Quote
Old 04-19-2011, 06:42 PM   #3
rizwan1377
My Ride: 04 M56,LC 100,RX300
Send a message via AIM to rizwan1377 Send a message via MSN to rizwan1377 Send a message via Yahoo to rizwan1377
I have not changed my rotors and pads yet on my e46. But on average cars, in order to change the rotors and pads, You have to take off the caliper. I am assuming that it would be same for e46 also. People Correct me if i am wrong.
rizwan1377 is offline   Reply With Quote
Old 04-19-2011, 08:06 PM   #4
radarcontact
Well, I can correct you...I have replaced pads and rotors without removing them. I am talking about completely REMOVING them from the car, not just swinging them up and out of the way. I probably wasn't clear enough, sorry.
Old 04-19-2011, 09:29 PM   #5
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
you disconnect the hard line from the rubber line, plug the hard line, and you're done...just look for stainless steel brake line installs...that's all you need to do isn't it?
Chris
dreamdrivedrift is offline   Reply With Quote
