Old 04-20-2011, 12:47 PM   #1
charlesrock
My Ride: 2003 bmw 325i
Car goes to right even after alignment
Hey guys,
I have a bmw 325i that is lowered with Tien lowering springs.
I just did an alignment and my car drives much better but the car still will go to the right slowly... any idea?
charlesrock is offline   Reply With Quote
Old 04-20-2011, 12:50 PM   #2
xavi330i
My Ride: 2004 330i smg
Originally Posted by charlesrock View Post
Hey guys,
A slight pull to the right is considered "ok". Better to drift right than to drift left into oncoming traffic.
xavi330i is offline   Reply With Quote
Old 04-20-2011, 12:52 PM   #3
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Most pulls are from a belt shifted on the tires. Swap the tires left to right see if it pulls the other way
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 04-20-2011, 12:56 PM   #4
charlesrock
Yep, could be the tires.. ill try that. I also get stupid vibration when I first start driving the car, then after its alittle better... the tires are not that old though but arent the best tires
Old 04-20-2011, 01:04 PM   #5
GoingNuts
Just Nuts
My Ride: 2004 330Ci
So, who is considering this OK ? Only you ?
GoingNuts is offline   Reply With Quote
Old 04-20-2011, 02:16 PM   #6
06BMW330ZHP
My Ride: BMW 330ci ZHP
could be a warped rotor?
06BMW330ZHP is offline   Reply With Quote
Old 04-20-2011, 02:31 PM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
First, make sure it really is a distinctive pull and not just because your roads are sloped down to the right for draining water from a rain.
If testing on a highway, make sure you try all three lanes.
Also, very minor tire pressure differences, again, at speed, will cause steering.
Use a good pressure gauge and be as accurate with it as you can be...and use door jamb pressures, not from the tire, not from a fanatic...unless it was me (and I always say 'start with door jamb pressure and then don't stray far from it in finding a balance you like').
JB pretends to be really knowledgeable so well that I'd give great deference to whatever he says. Wish I could say the same for everyone on fanatics!
Failing the basics taking care of things...I'm going to go with--bring back to alignment shop and tell them it's not quite right.
Upcoming comedy shows: Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 04-20-2011, 02:42 PM   #8
jbeurotech
Regional Sponsor
I pretend to be knowledgeable huh?????
Seth Thorson
Old 04-20-2011, 02:46 PM   #9
dmax
dmax's Avatar
I think I pretend much better than you, buddy!
OP, just learn to 'consider the source' before going out and taking anyone's advice around here.
Until I'd learned to do that myself, I'd mistakenly thought that painting my car with housepaint would be fine. What a disaster that was! I'm still glad I put the Range Rover roof on, though. I get comments on it all the time!
dmax on Facebook
Mangofy your E46!
Old 04-20-2011, 03:13 PM   #10
jcns
My Ride: California
did you change any bushings during the install?
jcns is offline   Reply With Quote
