E46 Convertible
Old 04-12-2011, 08:54 PM   #1
fayraree
flock killer
fayraree's Avatar
My Ride: 04 M3 vert
Car Solution eOpen top module - anyone install this?
The thing available for $129 at eas:
http://www.europeanautosource.com/pr...oducts_id=1866
anybody install this? I'm worried about putting the top up/down at 15mph when the mechanics weren't built to take the extra wind resistance...mind you if the wind is blowing already (at a stop) it still opens and closes just fine...but not as often I guess... hmmmm
fayraree is offline   Reply With Quote
Old 04-13-2011, 01:23 AM   #2
steve330
My Ride: '05 330cic
Go with your original gut feeling - the soft top mechanism is a complicated piece of engineering and is designed to be put up/down when stationary for a good reason.
On his deathbed:
Either that wallpaper goes, or I do.
- Oscar Wilde
steve330 is offline   Reply With Quote
Old 04-13-2011, 12:34 PM   #3
SMUUUUUV
My Ride: 330 VERT-4.4 X5-S550
Originally Posted by steve330 View Post
go with your original gut feeling - the soft top mechanism is a complicated piece of engineering and is designed to be put up/down when stationary for a good reason.
+1
SMUUUUUV is offline   Reply With Quote
Old 04-13-2011, 12:41 PM   #4
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
i am pretty sure that can be programmed into the GM5 with the proper BMW software, a laptop and the proper OBD port cable
/_________\
O==[][]==O
Old 04-13-2011, 09:03 PM   #5
Herbalicious
My Ride: 330ci, M3, Z06
Sounds a little risky...
Herbalicious is offline   Reply With Quote
Old 04-13-2011, 11:58 PM   #6
DropTopKingM3
My Ride: All German
You can ditch the itop module and find someone who can code your car. This will allow your top to open and close with the key.
Heres a video I made last fall using my car right after it was coded.
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Old 04-15-2011, 12:57 PM   #7
jason330cic
My Ride: 2001 330cic
I read that these eOpen modules are sent out with no installation instructions and it's a mystery how to install them. The function can be programmed but most shops won't do it because it's actually illegal in the US.
Jason330cic
jason330cic is offline   Reply With Quote
Old 04-17-2011, 09:48 AM   #8
fayraree
flock killer
fayraree's Avatar
My Ride: 04 M3 vert
I can already open/close with the key...I'm talking about doing so while moving.
Old 04-19-2011, 06:41 PM   #9
M3man2001
My Ride: 03 M3 vert
Do you know how/where this coding is located? Trying to get my local shop to find and activate it for me. Any info would be greatly appreciated.
M3man2001 is offline   Reply With Quote
Old 04-19-2011, 09:25 PM   #10
mach.schnell
My Ride: 08/2000 330Cic x2
Curious as to why you would want to do this.
mach.schnell is offline   Reply With Quote
Old 04-19-2011, 10:09 PM   #11
DropTopKingM3
My Ride: All German
Even if I were able to I would never open/close my top while the car is in motion. Just the wind and air pushing against it while its halfway through would scare me.
..George..
Old 04-21-2011, 02:51 PM   #12
roofless e46
My Ride: e46 323ci
Does anybody know if there's anyway of changing my key so I only need to press it 3 times instead of having to hold it to put the roof up or down?
roofless e46 is offline   Reply With Quote
