Sponsored by BimmerWorld
Old 04-21-2011, 09:28 PM   #1
prematureapex
My Ride: E46 M
Ground Control Spring Question, 7" Up Front
E46 M3 with GC/koni setup:
Anyone ever run a 7" (#430) spring up front? I know ride height may be an issue...
prematureapex is offline   Reply With Quote
Old 04-21-2011, 09:48 PM   #2
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
i think that'd be too high. I run a 6" spring in front, my collar is dropped to the lowest setting and it's not close to low. I think a 7" on the lowest setting would be higher than stock.
SL Blak Soldier is offline   Reply With Quote
Old 04-21-2011, 10:32 PM   #3
FTWeisse
My Ride: has no hip-hop rimz
7 is a bit tall - especially with that spring rate.
Old 04-26-2011, 09:39 AM   #4
prematureapex
My Ride: E46 M
Bump for more info.
Now that I"m thinking about it. Lowest perch height and tophat position are fixed, regardless of the spring height.
So, all it comes down to is preload.
No one running a 7" spring up from on a Koni/GC setup?
Old 04-26-2011, 02:46 PM   #5
Many330i
My Ride: e90 M3
Why do you want a 7"? Comfort? Aren't your dampers adjustable?
Many330i is offline   Reply With Quote
