E46 Convertible
Old 04-22-2011, 03:02 PM   #1
Mulatto325
My Ride: 325ci convertible
Vert owners can you identify this part?
Just curious how savvy you owners and do it yourselfers are. I just replaced this part on my bimmer. Not really a part that you would think needs replacing. See if anybody can figure it out and then ill tell you why I had to replace mine and how you will know if yours needs replacing.
My tops down, its upset.
>>>Mulatto325<<< Build thread
http://forum.e46fanatics.com/showthr...087&highlight=
Mulatto325 is offline   Reply With Quote
Old 04-22-2011, 03:12 PM   #2
stilurkingabout
My Ride: 2011 335i
Is that one of the two plastic covers located forward of the top assembly, roughly where a C pillar would be?
stilurkingabout is offline   Reply With Quote
Old 04-22-2011, 03:30 PM   #3
Mulatto325
You sir are correct. The reason i had to replace mine is because the drivers side was not closing. I checked it and thought the spring broke or came off. Well it did come off because the plastic piece where the spring connects broke. Took me all of 5 minutes to fix. The part was 9 bucks and 9 to ship it so it was about $18 to replace. Whats up with BMWPartsSo***8203;urce.com shipping costs???
Old 04-22-2011, 04:42 PM   #4
GuitarmanTT
My Ride: 1999, E46 328i
HAHAHAHA just bought two last night! and the little piece next to it.
GuitarmanTT is offline   Reply With Quote
Old 04-22-2011, 07:15 PM   #5
alibusoul
My Ride: 04 330Ci
How do you fix it? both of mine have been missing since I bought the car so I don't know exactly how to install them
alibusoul is offline   Reply With Quote
Old 04-22-2011, 07:17 PM   #6
Gheybe
Gheybe's Avatar
My Ride: F80 M3
Mine wouldn't go up, on the driver's side.
I fixed it.
Gheybe is offline   Reply With Quote
Old 04-22-2011, 11:12 PM   #7
mach.schnell
My Ride: 08/2000 330Cic x2
If I understand correctly, the two "caps" might be in the car, but slid down under if the closing spring is missing.
So if we're not talking about #10 here:
http://www.realoem.com/bmw/showparts...87&hg=51&fg=50
Sorry...
mach.schnell is offline   Reply With Quote
Old 04-22-2011, 11:17 PM   #8
cityjohn
My Ride: 2001 M3
Try installing it without the springs at first, to get a feel for how to snap the tabs into the right tracks.
Then take it back out and reinstall with the springs.
cityjohn is offline   Reply With Quote
Old 04-23-2011, 12:03 PM   #9
BavLar
My Ride: 330Cic 5spd & 330i
Both of my covers are sitting in the glove box until I order the springs and rods. With the top down those holes give it a sort of trailer park vibe . Gotta fix it soon.
BavLar is offline   Reply With Quote
Old 04-25-2011, 02:01 AM   #10
GuitarmanTT
Did that part happen to come with the springs sleeve and cam follower?
Old 04-25-2011, 04:41 AM   #11
Mulatto325
No but the spring and the plastic follower i think are both under 2 bucks
Old 04-25-2011, 08:43 AM   #12
mach.schnell
13 TENSION SPRING (up to 09/2003) 51438163692 $2.43 list $1.61 http://www.bmwmercedesparts.com
14 PUSH ROD (up to 09/2003) 51437029018 $0.57 list $0.40 http://www.bmwmercedesparts.com
(Hmmm... wonder what they did with the facelift model? RealOEM shows some confusion.)
Old 04-25-2011, 02:06 PM   #13
alibusoul
My Ride: 04 330Ci
what's all this rod business though? or is it apparent where they go/what they do when I get the tracks cleared up?
Someone should definitely post a video of the latch while its going
Old 04-25-2011, 04:00 PM   #14
Julian Moore
My Ride: 2002 M3 Vert
I spent 10 minutes yesterday trying to get that sucker back in to place after I accidentally put my hand on it. Good quality...not.
Julian Moore is offline   Reply With Quote
Old 04-26-2011, 05:02 PM   #15
sakumaxp
My Ride: 02 M3 convertible
was this a hard fix? i need this for my driver side
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 04-26-2011, 05:26 PM   #16
cityjohn
My Ride: 2001 M3
I think the assembly is put together off the car including the large panel at the factory. Reassembling this way would be the easiest. But rather than take off the whole panel you CAN stick the cover and spring back in; you just have to bend and twist the plastic a bit more.
Old 05-15-2011, 02:16 PM   #17
sakumaxp
ok, heres my problem with this part, i have the actual part in my car, but when the top is down it doesnt go where its supposed to cover up the gap. does anyone know how to fix this? i think the spring is either broken or it fell off or something
SMG II
Verttttt
VCSL Front Bumper
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
Old 05-15-2011, 07:42 PM   #18
Mulatto325
On mine the actual cover broke where the spring connects to it. I thought it was the spring or the rod was broken. I actually bought a new rod thinking mine was broken . When I bought the new rod it was the same size as the original one. Opon further inspection I discovered the broken cover. When I installed mine ( with the topthe half open position)I put the spring and rod on the cover then installed the cover. It took me a couple of tries to line it up in the tracks right then I hooked the spring up.
Old 02-15-2012, 08:18 PM   #19
Jnyce718
My Ride: M3
2 broken caps
Well at first i didn't even notice i had a broken cover on the drivers side, and today the passenger side has seem to snap... Both springs are still attached to the frame and the plastic covers can still slide up/down, so no problem there... Im missing the small hook/hole under the cover that attaches to the spring... So all i need is the plastic covers on realoem #10 ???
How did you get the old covers off?
thanks
Jnyce718 is offline   Reply With Quote
Old 03-12-2012, 11:11 AM   #20
tbear325
My Ride: 2002 325Cic
Anyone have a close up shot of this and how to pull out? Mine appears to have fallen down inside the whole (ie it doesn't spring up).
tbear325 is offline   Reply With Quote
