Sponsored by BimmerWorld
Old 04-22-2011, 04:48 PM   #1
dudeck14
My Ride: 2002 325ci
Rattling control arm.... Help!
So I was changing the front brake pads on my 325ci this morning when I found the culprit to the rattling in my suspension. The part of the control arm that connects closest to the wheel is loose. I'm guessing my bushings are bad as they haven't been replaced yet, but I was wondering if I could loosen the nut there and tighten the bolt with an allen head just temporarily until I can afford to replace the control arms, bushings and all..... Any help would be very much appreciated!
basically stock 2002 325ci, smoked corners and k&n filter
dudeck14 is offline   Reply With Quote
Old 04-22-2011, 06:15 PM   #2
Majorp
My Ride: 2000 328i
I am not sure that you can tighten this nut and solve your vibration problem. The nut merely maintains the connection whereas the vibration you are experiencing is normally dampened by the worn out ball bearings in the joint. I am in the exact same situation that you are in dudeck14 and if anyone here thinks I am wrong on this and that tightening the bolt would help please let us know. Sorry I didnt have a more positive opinion for you dudeck14. I am just going to bite the bullet and replace mine if I find a set for a good price I will update.
"Its hard to make a man understand something when his salary depends on him not understanding it" --- Upton Sinclair
Majorp is offline   Reply With Quote
Old 04-25-2011, 12:26 PM   #3
GA-e46
My Ride: 2001 325i
I'm pretty sure you are correct. You will have to replace the whole Front Control Arm since the ball joint is connected to the FCA.
Side note: if you use Meyle FCA's they have separate ball joints that you can replace without replacing the whole FCA again.
GA-e46 is offline   Reply With Quote
