Suspicious Coolant Leak!!! - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-28-2011, 12:55 PM   #21
Penguin Koolaid
Banned
My Ride: Inline Six
My water pump exploded while driving on the highway this Monday. It unloaded coolant everywhere .
$125 for a new pump and $435 ($145/hr) for labor later... back on the road. A few ****s were given, but otherwise could have been worse I guess.
Penguin Koolaid is offline   Reply With Quote
Old 04-28-2011, 01:30 PM   #22
Guest021715
Account closed.
Originally Posted by BimmersGarage View Post
If it only seem to leak overnight (and not while driving) then the leak is caused by a failed/failing seal > more than likely due to heat pressure... the location of the "weakest" seal in our E46 cooling system is here:
Lower Radiator Hose > the Auxiliary fan/temperature sensor.
Check this tiny O-ring (green in photo) but it could be brown in some year models.
You may have found my problem.
Old 04-28-2011, 01:55 PM   #23
enfini-fc
My Ride: 02 325ci
just did a expansion tank,upper radiator hose,fan sensor....noticed coolant down the side of the block from head gasket area;nice. engine swap time.
enfini-fc is offline   Reply With Quote
Old 04-28-2011, 02:47 PM   #24
cyberkaa
My Ride: E46 332i,M3;E30 325i
Ramin, you've got a leak somewhere (obviously, haha), but it's only opening up when the pressure gets high enough. I've seen a similar situation when a plastic flange on the radiator had cracked and would occasionally gush coolant some time after the car was parked, but would be fine or leak almost imperceptibly at other times. Can't rule the new cooling system parts out (especially ET) even though they're pretty fresh. Look for tell-tale signs of dried coolant in the engine bay around the hoses, et, etc.
-Kalim
(klx photo studio)
Old 04-28-2011, 03:27 PM   #25
josephmech
My Ride: 2001 325i sedan 5m
Also I have seen before where you pressure check it
josephmech is offline   Reply With Quote
Old 05-03-2011, 01:45 AM   #26
DJ RaMiN
My Ride: 02 325I,03 M3
alrighty!! today I went under the car again, had to open lots of ****, so i can see the whole thing, and guess what!!! the f****** expansion tank(which I installed less than a year ago) had a hole in it!!! I dont know how and why but there was a small hole on the right side of the tank...so Im gonna pick up the part for it tomorrow morning and do the job!
DJ RaMiN is offline   Reply With Quote
Old 05-03-2011, 02:41 AM   #27
cyberkaa
Could have been worse. Good thing it isn't. Remember to avoid overfilling it, too.
-Kalim
(klx photo studio)
Old 05-03-2011, 08:01 AM   #28
xavi330i
My Ride: 2004 330i smg
Coolant leaks are not hard to diagnose. You have to get dirty and get under the car.
xavi330i is offline   Reply With Quote
Old 05-03-2011, 09:18 AM   #29
GRIFFIN
NWS
GRIFFIN's Avatar
My Ride: fast
Glad to hear you found the problem.
*NWS GIF REMOVED*
*GIF REMOVED*
**You make me so horny.- Tim330i **
Old 05-11-2011, 12:33 AM   #30
russco-pico
My Ride: e46
Excellent Post, I just wish It was up last week as I have been having the same problems with the cooling system on my wifes e46 wagon. It would loose some water while driving, and after being shut down for an hour or more it would loose a gallon or more. I got under the car and took of the splash pan and noticed the water dripping off the lower crank pulley. I figured it was the water pump gone bad, I then noticed after removing the centrifical fan and belts that the pump bearing was a bit loose but not leaking. I then noticed some yellow/brown rust water below the thermostat housing, after removal it appeared that the housing o-ring style gasket may have been the cause of the leak but after reading this post I went back out to the car and checked the o-ring gasket/seal in the upper slipfit radiator hose that connects to the thermostat and noticed that the real cause of the leak is not the thermostat housing gasket but the upper radiator/thermostat o-ring gasket seal inside of the radiator hose, it actually looks like the seal actually got so hot that it is slightly melted and burnt and cracking which would cause the leak when cooling down and drip water on the underside of the hose which made the water marks under the themostat housing and on the engine block which caused me to think the housing was at fault. Thanks to this post I have found the true cause of the leak and now will not have to worry about the water pump and thermostat as I will continue to replace them as they are out, once again thank you all!
mahalo
Russco
russco-pico is offline   Reply With Quote
Old 05-11-2011, 12:44 AM   #31
russco-pico
My Ride: e46
TO AZBLKBLK and BIMMERSGARAGE As I just posted, my success with the help of this post. Credit where credit is due thanks to the two of you and the others for your knowledge again Thanks
mahalo
Russco
Old 05-11-2011, 07:18 AM   #32
BimmersGarage
My Ride: E46 330i
mahalo
Russco
Always nice to be able to help out a fellow bimmer. Glad you were able to diagnosis and fix the problem.
BimmersGarage is offline   Reply With Quote
Old 08-03-2011, 07:21 PM   #33
Mark325i
My Ride: '03 e46
Hey, how hard is it to change that o-ring? Am I going to have a gusher of coolant when I try to unplug the sensor? Thanks.
Mark325i is offline   Reply With Quote
Old 08-03-2011, 07:34 PM   #34
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I did it, but when the hose was empty. Everyone just seems to plug it with finger somehow while replacing new o-ring. If it's the whole sensor you're replacing, I don't think you should lose much at all--just pay attention to how it comes out, so you can put it back in easily.
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
dmax is online now   Reply With Quote
Old 08-03-2011, 09:15 PM   #35
BimmersGarage
My Ride: E46 330i
Not difficult at all, just have the new one handy... be careful not to over stretch it while you put it on.
And, no there won't be a gusher (just a tea spoon at most) if you keep the radiator cap on, our cooling system is sealed so it creates a vacuum.
NOTE: Just Don't try to change it when the motor is still hot!
Be safe, wait til it's cooled off completely.
Old 08-04-2011, 07:24 AM   #36
Mark325i
My Ride: '03 e46
Thanks, all, for the terrific advice. One more thing -- this sensor simply unclips and pulls out, correct?
Old 08-04-2011, 08:32 AM   #37
BimmersGarage
My Ride: E46 330i
Yes.
Disconnect wiring harness first, then squeeze the retaining clips on the sensor housing and wiggle it out.
Old 08-04-2011, 08:46 AM   #38
Mark325i
My Ride: '03 e46
Yes.
Excellent. Thanks again!
Mark
Old 08-04-2011, 11:57 AM   #39
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Thanks for the link.
We have the part you need.
Tom
Old 08-04-2011, 12:12 PM   #40
Mark325i
My Ride: '03 e46
Done. Picked up the $2.39 pack of assorted O-rings from Autozone and all's well. Thanks for the valuable info.
Mark
