Old 04-25-2011, 02:41 AM   #1
Hobblenobble
My Ride: bmw 320d SE 2003
Unhappy Rough Engine @ 1600-2300 rpm
Apologies if I have repeated this thread but I cannot find the issue in any forum I have a 2003 3 series E46 diesel 320SD. I have had it serviced recently with no error codes on the diagnostics. However, the issue I have got is that if the car is at a standstill and I press the accelerator, the engine seems to misfire between 1600 and 2300 rpm as though the engine is juddering. If I am driving normally, the engine seems to judder at 1600rpm regardless of which gear, but if you keep accelerating, the engine picks up and the car accelerates normally. When I use cruise control and the rpm is in the ‘judder zone’, the speed control hunts. I have used jet cleaner in my fuel to try and clean the injector nozzles, but this has not helped. My mpg has not been affected by this issue, this is normal. Any ideas or suggestions would be more than appreciated. Thank you.
Hobblenobble is offline   Reply With Quote
Old 04-25-2011, 03:18 AM   #2
Ixi640
My Ride: 2000 323i
ignition coil/boot?
http://forums.bimmerforums.com/forum...d.php?t=628626
I'm having the exact same problem, and I ordered a $25 FCP coil off of ebay that should be here tomorrow, I'll let ya know how it goes
Ixi640 is offline   Reply With Quote
Old 04-25-2011, 03:36 AM   #3
Drizzles
My Ride: 1999 BMW 318i E46 4D
A few things, do you have a CAI or any kind of intake mod? If so, replace with stock.
Secondly, check for cracks etc in boots and vacuum lines. They are another possibility ...
Drizzles is offline   Reply With Quote
Old 04-25-2011, 03:38 AM   #4
mack89
My Ride: '02 TIAG 330i 5spd
^Good thinking, but vacuum leak will cause constant rough idle. And it'll throw SES codes as well
mack89 is offline   Reply With Quote
Old 04-25-2011, 03:39 AM   #5
mack89
Originally Posted by Ixi640 View Post
ignition coil/boot?
^As far as I know, diesel engines don't have spark plugs/ignition coils. Glow plugs do their job.
Anyway, I'd check fuel supply system. Pressure might be little bit low, makes judder. Check glow plugs as well..
Old 04-25-2011, 04:27 AM   #6
Drizzles
Ummm ... yeah why didn't I pick that up
Diesel engines use compression and the heat at the top of the cylinder to recombust .. they don't have coils or plugs ................
The only plug they have is a Glow Plug to initially warm the cylinder to operating temp so the engine can start, after this initial warm up, the glow plugs are not used again till the engine cools down.
Old 04-25-2011, 12:09 PM   #7
Hobblenobble
Guys, thanks for your replies. My car is stock and no mods have been carried out. I did clean the ERV today due to the good post on this website. Thought it may help, but unfortunately not. However, when I restarted the engine after the clean i did notice a sucking/blowing sound coming from the rights hand side of the ERV. I could not locate it properly due to the rotating belts ????? How do you check/amend the pressure for the fuel system? Is there a post that would give clear instructions how to do this? Also the glow plugs too! Although, do the glow plugs have any function after the negine has started? Nevertheless, thank you for all the replies.
Old 05-21-2011, 10:19 AM   #8
Hobblenobble
HElp pleeeeez
Old 05-21-2011, 10:45 AM   #9
Drizzles
Glow plugs do not affect the normal running of the vehicle once properly running.
Grab yourself a can of MAF cleaner or Carby Cleaner, remove anything obstructing the engine i.e. Cabin Filter Housing etc (never worked on a Diesel E46 so I couldn't tell you what you have to and don't have to remove.)
Start her running and spray that stuff everywhere, all over the Engine, the Vacuum Fittings and intake assembly etc.
I've also heard a Sucking/Blowing sound can be Secondary Air Pump.
I would get your codes read anyway, as you can have codes without having a CEL.
Old 06-24-2011, 05:14 AM   #10
Hobblenobble
I sprayed every where but no difference. i disconnected the MAF and it seemed a little better. Although the juddering did occur but not as frequently. What i also noticed is that in Cruise Control Mode (CCM), at 80mph/1500rpm the engine pulls the car along in a juddery manner. Also the speed would drop to 76mph and then pick back up to 80mph every two or three minutes. If I ran at 82mph on CCM then the car cruised along perfectly.
Old 06-25-2011, 09:42 AM   #11
Hobblenobble
Today I removed the MAF and EGR Valve. I cleaned both, but it still has the same issue.
Old 07-02-2011, 02:34 AM   #12
Hobblenobble
Well, through luck I think it is cured! Cleaned my MAF with brake cleaner and disconnected the battery for 30 minutes.
I do not think there is a forum out there that can actually pi point the true reason and remedy for this issue
