E46 Convertible
Old 04-25-2011, 09:48 PM   #1
blackt330i
My Ride: 330i
Vert Rear side window Molding
On my vert the black plastic piece in the image below broke and half of it fell off. My question is Is there a way to replace just the black plastic piece or am i better off going getting an entire window with the black piece intact from Ebay? Im scared of braking the window while removing the plastic piece still connected to the window. Any info or help is appreciated.
Thanks,
blackt330i is offline   Reply With Quote
Old 04-25-2011, 10:22 PM   #2
burntass
My Ride: ///m3 vert, 05 MCS
this interests me as well. bump.
2005 ///m3 cb/cinnamon vert: weekends
2005 Mini Cooper S/jet black hardtop: daily
1988 e30 325ix/gray hardtop: gone
2002 e46 tiag 325ci vert: gone
burntass is offline   Reply With Quote
Old 05-03-2011, 11:12 PM   #3
duhprez
My Ride: 2003 BMW M3 Cabrio
The black plastic molding is replaceable for the rear window. I ordered a pair from Tischer BMW and changed mine out last year.
http://www.trademotion.com/partlocat...72&catalogid=0
Part Number: 51368209421 (left)
Part Number: 51368209422 (right)
I paid $63.59 per side
To remove the original molding, use a hair dryer to loosen up the adhesive then use a little bit of muscle to just pull it out. Then sparingly use silicon to re-adhere the new molding to the window. Don't lower the window and allow 24 hours for the silicon to cure.
duhprez is offline   Reply With Quote
Old 05-06-2011, 10:14 PM   #4
dvendt
My Ride: 2003 325ci vert
Hi, I have a similar issue, and was thinking of changing the whole glass window out. I am assuming you removed the whole window out to replace the moulding, please confirm and do you have procedures on how to remove? Was it difficult, any surprises to be aware of? Thanks
dvendt is offline   Reply With Quote
Old 05-07-2011, 12:41 AM   #5
duhprez
You don't need to remove the entire glass to change out the molding. As mentioned, use a hair dryer to heat it up and it'll be easier to pull off. There's really no procedure.
I brought the parts to a body shop to change. I watched out they did it and it's simply heat up the molding and pull off.
Old 05-09-2011, 11:22 AM   #6
blackt330i
My Ride: 330i
Hey Thanks! I was really close to buying a new window on Ebay.
Old 05-09-2011, 06:04 PM   #7
dvendt
ok, I have seen the window on ebay as well, thinking of buying it, but replace just the rubber moulding and it can be done witout taking the window out? Seems like you need to remove the interior quarter panel to expose that side of the glass, but I guess I'm wrong, anyway, I need to get this done, it is getting annoying now that vert season is here.
Old 05-10-2011, 02:56 PM   #8
dvendt
I found a better picture description and price for those who will need this in the future, I will be ordering it as well. Thanks!
http://bmwfans.info/parts/catalog/E4...ing_mechanism/
Old 05-13-2011, 01:08 AM   #9
Phoenix330ci
My Ride: 04 330Ci Convertible
Did this about a year and a half ago. That moulding was a super PITA to remove from the window. I didn't remove the window from the car. What I ended up doing was cutting the moulding off using a dremel. Once I cut it about 50%, I then was able to pull the moulding off the window. I bought some black window silicone from NAPA that they use to install windshield, 3M stuff. It stuck it back on real good.
Phoenix330ci is offline   Reply With Quote
Old 04-30-2014, 06:38 PM   #10
arnold16890
My Ride: United States
I'm having a similar issue, bought a used window on ebay for $45 with a good condition seal. We'll see how hard it is to change the whole window haha
arnold16890 is offline   Reply With Quote
Old 02-16-2016, 07:39 AM   #11
ikalinin
My Ride: 06 330ci Convt ZHP
waking this thread up. I want to replace my driver side gasket as well.. the window didnt sit right, and damaged/tore the gasket.
any how to w/ pictures would be appreciated.
ikalinin is offline   Reply With Quote
Old 02-18-2016, 08:51 AM   #12
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
same procedure here, at a certain point i decided to remove the window to make the entire work easier...worst decision ever..
TheRiddle is offline   Reply With Quote
Old 02-18-2016, 10:13 AM   #13
ikalinin
I guess i should of read the 'entire' thread
I was looking for pictures
