Sponsored by BimmerWorld
Old 04-21-2011, 07:03 PM   #1
z4legacy3.0
My Ride: 3.0 Z4
Suspension Questions
Hey do any of you know if there is a difference in suspension for the 2003 z4 3.0 and the 2003 e46 330i? If nothing is different would that mean I would be able to use an e46's coilover set?
z4legacy3.0 is offline   Reply With Quote
Old 04-26-2011, 01:11 AM   #2
z4legacy3.0
My Ride: 3.0 Z4
bump
Old 04-26-2011, 02:24 AM   #3
SL Blak Soldier
My Ride: 3 Pedal SG S54B32
Send a message via AIM to SL Blak Soldier
suspension forum would be a good place to ask, or bfc
SL Blak Soldier is offline   Reply With Quote
Old 04-26-2011, 03:18 AM   #4
z4legacy3.0
My Ride: 3.0 Z4
E46 to E85 comparison
Old 04-26-2011, 11:59 AM   #5
NoVaDreier
My Ride: 2001 325i
The E85 struts and shocks are more expensive and have different part numbers.
NoVaDreier is offline   Reply With Quote
Old 04-26-2011, 02:11 PM   #6
z4legacy3.0
My Ride: 3.0 Z4
So would that mean they wouldn't work if you swapped applications? Because I found a set of springs that is made for the E46, but it says that it can fit the E85. This stumped me, why spend the additional money to buy an E85 set if an E46 is exactly the same.
Old 04-30-2011, 07:54 PM   #7
erfont
My Ride: 02 325ci
i'm pretty sure both suspensions have the same fitment of parts but obviously the Z is much lighter. any quality manufacture of shocks and spring would take this into consideration and adjust valving/spring load accordingly. if someone sells a kit that could be used in either vehicle its probably junk.
erfont is offline   Reply With Quote
