Sponsored by BAVSOUND
Old 11-27-2011, 10:18 AM   #41
radarcontact
My Ride: 2006 330CiC/ZHP
Originally Posted by bimmerdriver1117 View Post
Good job op! Btw, erick do you have a build thread? Im trying to do this with 8's too and an infinite baffle. Any suggestions guys? Thanks
Have you bought the 8" drivers yet? If so, which ones?
radarcontact is offline   Reply With Quote
Old 11-27-2011, 11:41 PM   #42
nicco1117
My Ride: black beauty
Send a message via Yahoo to nicco1117
right now i have 2 kenwood 10's and it's eating up alot of trunk space. im waiting for funds so that i can purchase 2 8" excelon's or RE's. my main concern is how the parcel shelf will look after i do this. and how big should i cut on the rear shelf(metal part)
filipino pride!!!
nicco1117 is offline   Reply With Quote
Old 11-29-2011, 05:23 AM   #43
zYx
My Ride: 2003 325CiA
Here is a link to a similar 8" IB install, you can take a look on approximate space you will need for drivers: http://forums.bimmerforums.com/forum....php?t=1033587
and another one: http://www.diymobileaudio.com/forum/...q-install.html
zYx is offline   Reply With Quote
Old 11-29-2011, 06:34 AM   #44
nicco1117
thanks man!
filipino pride!!!
Old 11-29-2011, 03:49 PM   #45
super98lsc
My Ride: 330i zhp
I think my next plan is going to be to leverage something similar to the rear deck mod that properly encloses my Focal K2 Power 6.5"s for the rear midbass. Currently the Focal's are sitting in the boxes and I am still running the Factory HK 6. whatevers, with the crappy near zero space around them they barely play down to 120. A good 6.5 should be efficient down to 70-80 with solid kick/drive in the bass range allowing my 12" to blend in more smoothly. I did cut the front doors out and have the 5.25 Focal playing nice down to 63hz/18db Q factor on the x-over. One regret i have is not taking the time to mount the 6.5" in the front doors. I just miss the solid midbass the larger seperates can deliver. This car is the most non audio friendly car I have ever possessed when it comes to speaker mounting. Has anyone done a pair of 6.5's boxed in the deck and used a regular trunk sub?
super98lsc is offline   Reply With Quote
Old 11-29-2011, 05:54 PM   #46
Erick Sermon
My Ride: 2000 323Ci
Yeah I'm using the JL audio stealthboxes with the 8IB4s. I just used a passive loc and a really old (circa 90s) Orion XTR250 to drive them with stock deck and fronts. My crossover points and front stage don't work well. And the subs seem to pump with certain Songs and horrible with others. I think a proper front stage will help me lower the cutoff on the subs.
Erick Sermon is offline   Reply With Quote
Old 12-01-2011, 11:40 AM   #47
super98lsc
My Ride: 330i zhp
If I look back through all the phases with this car, the first and best improvement I made was installing my Apline head unit. With factory HK speakers/subs it sounded light years cleaner than the factory Business CD player which has some aweful EQ curves built into it.. The Imprint or Time correction is paramount to getting decent imaging. That thing has some aweful EQ curves built into it. The second largest improvement was adding the Focal 5.25 K2 Powers to the front, I use the passive x-overs that came with them tied and disconnected the midranges in the door (sedan). The FOCAL tweeters are great, not bright but clear vs the 2 cent HK's that were in there. The next largest improvement (wish i had done this from day 1 but didnt want to kill my warranty on the car) was cutout the doors behind the 5.25's and seal them in properly. The change in sound depth was akin to adding a supercharger to the engine, major difference in response/warmth from 300hz on down to 63hz. Then I finally bit the bullet and gutted out the car and changed all the amps, removed the factory HK's and installed a JLw3 12" in a sealed box. I lived with that for a few years, but could never get a clean blend from sub to mids. Finally changed the sub enclosure to a purpose built ported enclosure with Apline 12" and a JL G1700 driving it. Now the sub blends 1000x better, but still wish I had some larger mid bass drivers in the rear deck.
Old 05-03-2013, 01:52 PM   #48
BigDRick323
My Ride: 2000 323i
I've got two 12" JLW3's in sealed spare wheel enclosure facing up (not optimal but gives me my trunk space). Any thoughts on best way to port into cabin. I have an amp rack covering the seat back and crossover rack covering the rear deck access. I have rear armrest and punched out the back to the amp rack, but amp rack blocks most sound coming through. Thinking about ports through the amp rack somewhere but not sure.
THoughts?
Old 05-04-2013, 10:05 AM   #49
Grande D
My Ride: E36 M3
To answer someone else's question unless others are wondering the same thing- the Image Dynamics ID8 hits incredibly hard for an 8. Based on reviews of the original IB4s, I don't think it's even close. I only have one of them mounted IB in my car and it is plenty. Seems to dip into the high 20s with ease as well.
That said, it doesn't sound quite as good as a really, really good 12 like a Peerless XXLS or an IDMax 12, but it does sound better than the Polk MM1240 and Alpine Type R 12" that I used to have.
It will change your life!
Old 05-11-2013, 02:52 AM   #50
TR4G-
My Ride: '01 325xi, '90 325iC
Getting some trunk space back (new system rebuild)
Figured I'd throw this in here, considering this was the inspiration for my work. Ended up going with 2 12s instead of one. Codyfunk, thanks for the tips, they helped me out a lot!
TR4G- is offline   Reply With Quote
