Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 534 votes, 4.99 average.
Old 10-31-2012, 07:25 PM   #2861
sconnors
My Ride: '02 330i sedan
Originally Posted by live2ride090 View Post
Haha I have seen so many of these on here I guess I did miss it, my bad.
All in good fun. It's pretty comical to read this start to finish. Amazing how many times the same questions get asked and answered.
sconnors is offline   Reply With Quote
Old 10-31-2012, 10:43 PM   #2862
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 11-10-2012, 10:03 AM   #2863
Steve-O-727
My Ride: Lexus ISF, E46 M3
Originally Posted by E46er75 View Post
I'm having the same issue.. I have to reinstall the firmware to get it to work? I have my wifi usb stick plugged directly into the back of the unit. Every time I go to scan network it times out. Any other suggestions?
Another issue I have is when it boots up in defaults to the back up camera screen. I don;t have one so it is just a blank black screen with an error? Any suggestions?
+1, help!!!
If your not first, your last!! Shake and Bake!!
Steve-O-727 is offline   Reply With Quote
Old 11-11-2012, 12:04 AM   #2864
willy3000
My Ride: BMW 2001 E46 320ci
im also having the same problems with me unit. wifi doesnt connect. also is the android d99 orange lights suppose to dim when you dim the rest of the car? i saw it somewhere on youtube but it doesnt work on my unit....
willy3000 is offline   Reply With Quote
Old 11-11-2012, 12:05 AM   #2865
willy3000
also with whilst using the ipod function do you guys get static noises?
Old 11-11-2012, 03:30 PM   #2866
sonny31
My Ride: VW Passat 3BG
Firmware upgrade problem
Hello guys,
I readed hundreds of post, i tried 4 types of sd cards, usboot 1.7, easeus, with windows 7, windows xp, different card readers, i just can't make a bootable sd card.
I'm getting a lot of errors on the android side and i'm despered to upgrade it to the new official dynavin rom.
I have also tried factory reset.
it's shutting down, but after boot-up, no change, same apps, same settings.
Please help me.
sonny31 is offline   Reply With Quote
Old 11-13-2012, 11:33 AM   #2867
al-djazair
My Ride: E46 E34 E30
Originally Posted by sonny31 View Post
Hello guys,
I readed hundreds of post, ...
Hi Sonny31,
I had the same problem. But I finally succeed.
I used EaseUS with a 2GB SD Card :
File system FAT(16)
Cluster size 64KB
Primary and Active partition
Don't forget to click on "Apply" after setting all these parameters.
'01 E46 330xi
'94 E34 525i
'87 E30 325iX
2 x '86 E30 323i sold for parts
al-djazair is offline   Reply With Quote
Old 11-13-2012, 12:19 PM   #2868
Steve-O-727
Originally Posted by al-djazair View Post
Hi Sonny31,
File system FAT(16)
Cluster size 64KB
Don't forget to click on "Apply" after setting all this parameters.
So this should fix the wifi problem, etc.?
Old 11-13-2012, 12:29 PM   #2869
sonny31
Hi Sonny31,
File system FAT(16)
Cluster size 64KB
i allreasdy tried, and after that? with the unit turned off, insert de sd, turn on the unit, wait a lil' bit and then press the nav button and installation should begin, no? these are the steps?
Old 11-13-2012, 12:49 PM   #2870
al-djazair
i allreasdy tried, ...
Hi,
when I tried without success, I just reformat my card and then "apply" before setting the partition "active".
When I succeed, I deleted all partitions, create a new one, set it active and then apply everything. And I copied only the firmware files in the empty card.
'01 E46 330xi
'94 E34 525i
'87 E30 325iX
Old 11-13-2012, 04:20 PM   #2871
sonny31
Hi,
I did just what you told me but now, I start the unit with the sd in, turn it on, wait a couple of sec and then, when i press nav but nothing happens. Black screen. I leaved it for 15 min wating for something to show up but nothing...
If i remove the sd card android boots up.
What i did wrong?
Why the installation doesn't start?
btw, thank you very much for helping me so far.
Old 11-15-2012, 05:49 AM   #2872
willy3000
Do you have a micro sdhc. The android might not be able to read it.... or can it?
Sent from my Galaxy Nexus using Bimmer App
Old 11-16-2012, 09:53 AM   #2873
dizzeedazza
My Ride: 316i se E46
same problem as sonny, my android side wont factory reset and it wont let me remove the current user, so i have someone elses gmail account on my unit, can someone please send me a step by step of how to re install the rom, including links to anything i will need to download.(i already have downloaded the download from the dynavin website, unzipped it and put the new folder on an sd card but it does nothing)
thanks
dizzeedazza is offline   Reply With Quote
Old 11-16-2012, 04:25 PM   #2874
sonny31
thanks
Thanks to al-djazair I managed to install the rom.
What will you need:
- usb card reader
- 2gb micro sd card
- pc running windows xp, vista or 7
- EaseUs
1. Insert the sd intro your usb card reader and plug it to your computer.
2. Open easeus
3. select the sd card and delete the partition then click apply.
4. create a new partiton , set it as primary but choose unformated and click apply.
5. make the partion active (righ click and "make partion active").
6. format the partion with FAT, 64 KB cluster size (right click and format partion).
7. copy the content of the right rom that you will download from dynavin official website. ( you need to download the rom that matches your dynavin menu. Be carefull to download the corect one (see the pictures). the content of the archive must be copied straight to the root of the sd card, no folder.
8. With the dynavin unit turned off, insert the sd card in navigation slot then power on the unit.
9. wait a couple of seconds then press the "nav" button.
10. the message "reading ubi... must appear, wait couple of minutes, then "writing data", and finally "dial out the sd card and press the reset button"
11. remove the sd card and press the reset button, and this should be all.
al-djazair, thanks again. I owe you big time. Drinks on me when you will visit Romania
* easus partition master - http://www.softpedia.com/get/System/...-Manager.shtml
* dynavin rom download - http://www.dynavin.com/android.php
Old 11-16-2012, 04:39 PM   #2875
al-djazair
Thanks to al-djazair I managed ...
Hi Sonny31,
happy to see you succeed.
I'm drinking a beer, cheers.
'01 E46 330xi
'94 E34 525i
'87 E30 325iX
Old 11-20-2012, 09:01 PM   #2876
jwbeck17
My Ride: 2005 330xi
Dynavin E46 D99 Android Wifi/Bluetooth Help
I just recently bought an E46 BMW that had the Dynavin E46 D99 installed with Android, I have spent the past several days trying to get to understand how the system works on both the Dynavin side and the Android side (I have never used Android before). Currently I am having trouble with Wifi and Bluetooth.
The wifi connection has been finicky, having difficulty connecting to my home network, but I have been successful in connecting it from time to time. However, now when ever I start the unit, the wifi is turned off, and when I turn it on, it scans and states that it cannot search for networks or it kicks out an in-process error. Can't seem to get connected.
I have also tried to tether it to my iPad hotspot and that has failed, as it can't find it.
And whenever I turn Bluetooth on in Android, it tries and never turns on. The bluetooth in the Dynavin part seems to work fine, however.
I have used the reset button on the front, which reset the time and settings, but did not change the Android portion. Not sure if there is a way to reboot the android service.
Also, the Android settings claim to have T-mobile, but I don't have service for it, and not sure i want to pursue a 3G connection route. It also looks like the 3G is running, though I don't know how without service.
Any suggestions?
Thanks!
jwbeck17 is offline   Reply With Quote
Old 11-22-2012, 11:51 AM   #2877
jwbeck17
My Ride: 2005 330xi
Haven't pulled out my Dynavin yet, but I want to check the wifi connection. The reset button didn't fix wifi, so I'm thinking wifi element could be bad. Should I expect to find a USB wifi dongle connected to a USB wire in back of the unit?
Old 11-25-2012, 04:17 AM   #2878
ccc
My Ride: BMW 320D '02
Can I use 4GB SD card?
My device is D99 +, but Android does not work - only flash words "Dynavin" and can not run
ccc is offline   Reply With Quote
Old 11-28-2012, 08:37 PM   #2879
vartman
My Ride: BMW M3 2003 SMG2
Well if you want to flash the ROM you need a 2Gb SD card... or partition it to 2Gb... and make it bootable... fat... 64kb clusters works fine... and get the M3evolution ROM... much better..... but still having wifi problems.
vartman is offline   Reply With Quote
Old 11-29-2012, 04:46 PM   #2880
ccc
I did that. The device is working now
Rate This Thread
