Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 534 votes, 4.99 average.
Old 05-09-2011, 12:34 PM   #281
Danoff
My Ride: '04 330i ZSP
I just trying to figure out what's different about your home wifi and your phone hotspot. There can't really be that many things different. Maybe it's some sort of protocol issue? Your phone should be pumping out wireless g, which is what the dynavin wifi dongle says its uses... should be good.
Danoff is offline   Reply With Quote
Old 05-09-2011, 12:35 PM   #282
m3evolution
My Ride: M3
I have the HTC Evo and use wifi tether v2.07 and it works fine. Make sure you only have one password and wifi ssid associated to your phone in Dynavin and no other wifi router/hotspot such as your houses wifi etc. That should work. When I had my phones wifi saved and my house router saved at the same time it wouldnt connect to either one like it was confused which one to choose and gave up and stopped.
Originally Posted by live2ride090 View Post
Anyone been able to get there Android phone tethered to their Dynavin yet? I have tried multiple apps and the 3g mobile hot spot that is on my phone, no luck yet. The Dynavin will see my phone on the wifi set up screen using the mobile hot spot but will not connect to it (I have a Droid X by the way). I have tried all the channels on the my phone and with all the different security levels and no security password, still no luck. I have read through all these pages but it looks like most everyone has an iPhone. Kind of weird that I cant get my Droid phone to work with a Droid unit. The unit connects fine to my wifi at my house but the phone will not work.
Also, I cannot get the Aura offline Nav to work yet but it takes like over an hour to download the CA map, I was just trying to not have to remove and re-download it but that looks like the way I will have to go. I will also try some other ones that were listed on the past pages hopefully get something to work.
Any suggestions would be great. Thank you.
m3evolution is offline   Reply With Quote
Old 05-09-2011, 12:37 PM   #283
Danoff
Oh that's not good.
Old 05-09-2011, 12:48 PM   #284
live2ride090
My Ride: 2002 M3 E46
To use the wifi tether you need to root your phone correct?
live2ride090 is offline   Reply With Quote
Old 05-09-2011, 12:48 PM   #285
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
every wifi setup is going to be a little different but it should all work....on my setup I have the dynavin connected to my house and my iphone, it has no problem connecting to one or the other with both active....although I havent done it with both enough times to determine what criteria it uses to choose between them...
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 05-09-2011, 04:20 PM   #286
singry
My Ride: 2001 BMW 325i
Ok finally. I got everything hooked up and working. Just have to figure out the wifi part. I broke something that appears to be a antenna connection... Will post a pic of it soon.
Here is a pic of what I broke.
That piece sticking out at the end broke off a wire that's attached to the car....
MR. 325i
singry is offline   Reply With Quote
Old 05-09-2011, 04:48 PM   #287
J&T Distributing
My Ride: BMW
if you have an 2001 you shouldnt even be using that ^^^ antenna connection....you car has 2 antenna wires, the one you need to use is the other larger plug with the short little adapter....I assume you used that one instead?
Old 05-09-2011, 05:47 PM   #288
TrickTizzle
My Ride: 325i
installing mine now....
how does the gps antenna connect to dynavin?
cant find the pic that explained it..
Old 05-09-2011, 05:56 PM   #289
J&T Distributing
My Ride: BMW
screw on connector on the back, I see our friends at UPS finally came through.....
Old 05-09-2011, 06:06 PM   #290
singry
Oh yes i did. Any idea what that other one is for?
MR. 325i
Old 05-09-2011, 06:42 PM   #291
singry
Questions
hey
If i'm gonna be using USB 3G data do i still need the GPS i connected to the unit? or will it work with my network? I already have a data USB using when i'm up and about with my laptop. And also where do plug the USB data?
Also when i'm on the android side with the radio playing, when i touch a icon i get a mute in the sound as if i'm suppose to hear something. Any idea anyone. I know this might have been addressed before... I'm sorry if it did but i read through this section and maybe i missed it.
If it is anywhere in here can someone point me to it plz.........
MR. 325i
Old 05-09-2011, 06:54 PM   #292
mtromszc
My Ride: NY
Got mine today....Thanks Jeff
How long does the install usually take? I figured about 2 hours for the unit and another 90 min for reverse cam? I would hate to to be cought in the dark with my pants down...
mtromszc is offline   Reply With Quote
Old 05-09-2011, 06:57 PM   #293
J&T Distributing
My Ride: BMW
2 hours for the head unit is about right but that reverse cam could take you quite awhile.....
Old 05-09-2011, 07:00 PM   #294
TrickTizzle
My Ride: 325i
Originally Posted by singry View Post
hey
You should still plug in GPS because its way more accurate than your network. When you get location off of network it estimates based on your signal, etc. Won't be really good for navigation.
Took me 2 hours. Go slow, and you'll be fine. If you start to rush you won't get anywhere.
My turn...
Ok, so when my ipod is playing on the dynavin, I only get sound out of the passenger side speakers, but radio plays fine through all speakers. Also I am unable to navigate through playlist/music/artist/etc of ipod via dynavin.
Steering wheel controls don't work with the ipod either...
Old 05-09-2011, 07:54 PM   #295
singry
My turn...
I'm using my iphone 4 and it works sometimes. I just now got an error message saying {time out 354}...not sure what that is about.... but i use bluetooth to play music from my iphone.
I'm now realizing when i turn on the unit i hear music from front and back speakers for about 5 sec.... then i only hear it in from the rear ..........wierd.
MR. 325i
Old 05-09-2011, 08:07 PM   #296
J&T Distributing
My Ride: BMW
the GPS antenna MUST be plugged in.
you ipod cable's plug is probably loose, it is a friction fit and it can come loose during the install.
uncheck "Navi Sound" in the radio menu. If you plug an ipod in and your name doesnt pop up in the upper left, press the right side knob (or TEL button on some models) to activate blutooth and then the "back" button in the lower right, this resets the connection and only takes a second.
Old 05-09-2011, 08:28 PM   #297
TrickTizzle
My Ride: 325i
So, I gotta remove the dynavin again?...arghh...
Old 05-09-2011, 08:32 PM   #298
J&T Distributing
My Ride: BMW
depends on where your cable ended up, I always try to keep the plugs above or below the dynavin so I can reach them by pulling the vents or pulling the HVAC control, then I dont have to pull the dynavin out.
Old 05-09-2011, 08:35 PM   #299
singry
Tanks mon.....smh. taking it for a spin now, even tho i haven't figured out the wifi/internet part yet. Think i had enuff for one day....tomorrow i will be playing around with it again.
MR. 325i
Old 05-09-2011, 09:24 PM   #300
DropTopKingM3
My Ride: All German
Can someone post a picture of what the wifi antenna looks like? I searched the entire box and the area where I worked on my car and I cant seem to find it. All i remember was the GPS antenna. Thanks in advance.
..George..
..Is now Alpine White/Cinnamon...
^Don't say my car is topless, say the t!tties is out^
DropTopKingM3 is offline   Reply With Quote
Rate This Thread
