Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 534 votes, 4.99 average.
Old 05-25-2011, 10:33 PM   #861
m3evolution
My Ride: M3
Anybody notice Google Nav in the Dynavin giving bad directions?
I was going to a store I knew was only 3 miles straight ahead of me. I entered the stores address into Google Nav in the Dynavin and it tells me a weird path to take instead just going straight down the same road that im already on. It tells me to make a left then a right, another right, and then left to get back the same road im on already. I thought that was odd so I pulled out my HTC EVO and used the Google Nav on the phone and sure enough it just told me to drive straight 3 miles to my store without all the stupid turns. If I had followed the direction I got from the Dynavin Google Nav it would have doubled my driving time. This is the first time I have noticed this and will test it out again tomorrow.
m3evolution is offline   Reply With Quote
Old 05-26-2011, 07:34 AM   #862
singry
My Ride: 2001 BMW 325i
Same here. Mine was rerouting when i was on the correct rout, but yeah... mine does that.
anyone know of any good off line nav that works great?
MR. 325i
singry is offline   Reply With Quote
Old 05-26-2011, 07:37 AM   #863
aar0n_91
My Ride: 04 BMW325CI///MSport
igo primo. i use that on my windows dynavin v5
BMW 325 CI ///M-SPORT INDIVIDUAL
aar0n_91 is offline   Reply With Quote
Old 05-26-2011, 08:04 AM   #864
singry
Will it work with ANDROID?
MR. 325i
Old 05-26-2011, 11:00 AM   #865
Danoff
My Ride: '04 330i ZSP
This almost certainly due to your GPS solution rather than nav software.
Danoff is offline   Reply With Quote
Old 05-26-2011, 11:06 AM   #866
jmejiaa
My Ride: 2002 M3
Actually it can be Google maps(Not the unit)... My google maps does it often, and I think they are aware because they very conveniently place a (Not the right location?) button...
I've had it happen a couple of times, dead on gps but google navigation jsut doesn't know where it's taking me, just takes me to a wrong place. I've lost a lot of trust in it and usually look at the route before following it blindly.
This is on my Nexus one.
jmejiaa is offline   Reply With Quote
Old 05-26-2011, 12:25 PM   #867
Danoff
I've had google navigation do it to me too, but only when my location jumped around (also based on my phone). Also I haven't seen a great GPS lock in the E46.
Old 05-26-2011, 02:19 PM   #868
mc4ren
My Ride: E46 320D
Actually, it's using just two satellites for the fix, which looks few.
mc4ren is offline   Reply With Quote
Old 05-26-2011, 02:45 PM   #869
m3evolution
My Ride: M3
Was the latest release_20110517 firmware supposed to fix the double mph gps problem too? I know it fixed the android market and that is working fine now. I dont know if they fixed the double mph problem but if they messed around with the gps I think they might have created some new problems. The gps now seems kind of slow to update my location I would not get notified of my next turn until 1 - 2 minutes after I have already passed it. It then quickly tries to correct it self and find my current location only to then say GPS fix lost and gives up. You would have to exit out of Google Nav and restart it again. Sometimes its a few exit close before it finds the gps fix again.
My GPS antenna is placed on my dash right next to the windshield.
Im not sure if this is because of the new firmware or maybe its just a Google Nav problem. I did a quick google search and it seems lots of people are having similar problems on their phones too using the app.
Old 05-26-2011, 03:43 PM   #870
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
I havent noticed anything different with google nav since the update, in fact I drove all the way to LA and back and it worked great. I have definitely had some intermittent google server issues lately though in other apps. I looked around and saw a lot of people having similar issues issues, seems its google related.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 05-26-2011, 03:53 PM   #871
jneumann
My Ride: 323i, 530i, Z4 3.0i
Send a message via AIM to jneumann
So I'm not the only one who is getting only two satellites and constantly having lost GPS signal issues?
E46 323i Sport/5 speed | 243k miles
E85 Z4 3.0i Sport/6 speed | 117k miles
E83 X3 3.0i M-Sport/6 speed | 130k miles
E39 530i M-Sport/5 speed | 237k miles
Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ
jneumann is offline   Reply With Quote
Old 05-26-2011, 04:06 PM   #872
J&T Distributing
My Ride: BMW
I see 12 / 5 in use on the test unit here in the shop.....
pretty much the same on the unit in my car.....
Signal strength looks stronger on the unit in the shop than then unit in the car. Looks like the GPS antenna being in the dash lowers the reception a bit more than the roof of the building.
Old 05-26-2011, 04:09 PM   #873
Danoff
I've never seen more than 4 satellites locked, but I haven't checked after the new firmware update. So maybe it's better now.
Old 05-26-2011, 05:42 PM   #874
J&T Distributing
My Ride: BMW
I left the unit running for a while and looked at it each time I walked by, pretty much 4 or 5 all the time in the shop.
Old 05-26-2011, 05:48 PM   #875
Danoff
GPS needs 4 to get a reasonable solution. Anything less than 4 is no good. You have to solve for 4 unknowns (X, Y, Z and time), so you need 4 equations (satellites locked). You typically expect between 8 and 10 satellites locked to get a good GPS solution. Extra satellites create an overdetermined problem, which you can apply a least squares fit to blah blah blah. Point is, you want more than 4. I'll try to remember to check again on my way home today to see how many satellites I get.
Old 05-26-2011, 06:43 PM   #876
J&T Distributing
My Ride: BMW
One the drive home today it varied between 4 and 6, was 5 most of the time. Accuracy was about 4-7 feet.
Old 05-26-2011, 07:05 PM   #877
aar0n_91
no idea. i guess if you find an android based version i dont see why not
Old 05-26-2011, 08:34 PM   #878
opey
My Ride: 04 M3 coupe
i updated to the new firmware today off the dynavin site and now im getting that fake TMobile 3g connection too. and also the date didnt update the first time, but the 2nd time it did, ill have to keep an eye on that
IR/IR 6 speed
opey is offline   Reply With Quote
Old 05-26-2011, 11:29 PM   #879
Danoff
I had 3 satellites on the way home today, which is not enough for a decent solution. The GPS knew exactly where I was though, down to a good level of accuracy. My speed readout (which now reads correctly) was also way too accurate for 3 satellites - accurate enough for me to get yet another indication that my speedometer is 3-4 mph high. I think the unit is not indicating how many satellites have lock correctly. I think it has a better solution than it indicates - so I guess it's not really an important issue to resolve.
Old 05-27-2011, 12:05 AM   #880
m3evolution
My Ride: M3
what are you guys using to show how many satellites are locked? Is that a setting in Google Nav/Maps or a separate app?
Rate This Thread
