Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 534 votes, 4.99 average.
Old 08-03-2011, 02:03 PM   #1701
johndddd
My Ride: 02 m-3
Originally Posted by johndddd View Post
Is there anyone running SLINGBOX app from the ANDROID market place? If so are you on the Verizon 3g network and or have an Iphone 4.
just asking again,
johndddd is offline   Reply With Quote
Old 08-05-2011, 05:22 AM   #1702
m3evolution
My Ride: M3
Has there been any updates or ETA from TXROB about the new firmware he is working on with Dynavin?
m3evolution is offline   Reply With Quote
Old 08-05-2011, 07:52 AM   #1703
Mattbuyshouses
My Ride: 2006 330i
Now that I've gotten my unit installed and completely functional, (Thanks Jeff! ) I'd like to know the same. I now see what everyone was talking about with the IPod controls and searching for music, that -is- definitely a pain.
I'm setup with Pandora but I'm looking for suggestions on an MP3 player to run music off the flush-mounted USB drive. What's everyone's best suggestions that works bug-free so far?
Anyway, so glad I'm now finally part of the revolution. I'm merrily thumping down the street now, just need to 'pretty' everything up and build the box for the trunk to house the sub and amps.
Mattbuyshouses
Mattbuyshouses is offline   Reply With Quote
Old 08-05-2011, 08:12 AM   #1704
m3evolution
My Ride: M3
For those that are having lots of FC problems and have Pandora installed try disabling the bluetooth option in the Pandora app. The bluetooth option being on in the Pandora app has been known to cause lots of problems.
Old 08-05-2011, 08:28 AM   #1705
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Matt, all of us with android units can use the android music player. Just get a big micro sd card and copy your iTunes library to it. No more iPod!
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 08-05-2011, 08:30 AM   #1706
Dictato
My Ride: 318d
This thing is driving me mad. Contacted Dynavin about the update. They send me instructions to reformat the provided sd and update the unit. At first it didn't work, but once I disconnected the unit from power and reconnected it. It started to update. When it was finished I got a message like:'ok, dail out the sd and reboot'. Did that more than 10 times, but still the same message and no android or anything else. It's not going away. Anyone fimiliar with this?
Btw my front speakers also stopped working. Checked cables behind the unit, but couldn't find anything broken.
Dictato is offline   Reply With Quote
Old 08-05-2011, 10:34 AM   #1707
J&T Distributing
My Ride: BMW
sooo......did you take out the sd card, turn the car off for a few seconds and then turn it back on? The front speakers stopped working because android currently is trying to use them....fix issue number one and issue number two will fix itself.
Old 08-05-2011, 11:36 AM   #1708
Dictato
My Ride: 318d
Ok, I opened it all up again. Disconnected the wires and reconnected it. Now I put the SD in and start the car. I get a message like: "Updating system, Reading image". Waited more than 20 mins nothing happend, still the same message. Turned the car off and on , still nothing. Turned the car off and removed SD. Then turned back on again and now just turned the unit off. Put SD in and start unit again. Still nothing, same message. Tried these several times, but didn't work. I will try it again and this time wait for as long as it takes, see what happens.
Btw. thnx for the replay!
Old 08-05-2011, 02:10 PM   #1709
Mattbuyshouses
My Ride: 2006 330i
I'll do that!
Tried hooking my phone into the flush mounted USB today, waited 30 minutes and it was only about 35% complete. How long does it take to scan your SD card for your music and how many files do you have on it? I'll start with a 4GB card that I have and put a few hundred songs on it from my collection. Even if I have to "rotate" music now and again, it is so clean and beautiful it's 100% worth moving music around.
I am so digging this unit!
Mattbuyshouses
Old 08-05-2011, 02:36 PM   #1710
J&T Distributing
My Ride: BMW
Originally Posted by Mattbuyshouses View Post
I'll do that!
I dont know of anyone using the android usb for music but i suppose its possible, 4GB is OK for the SD card but Im using a 32GB. IT takes a little while to scan and index everything the first time...maybe 5 minutes...but after that there is no load time for the SD card as it only loads changes after that.
Old 08-05-2011, 06:00 PM   #1711
Dictato
My Ride: 318d
Thanks jeff !! I've managed to update my unit. Front speakers work again and I've a feeling that the android side has better sound now. Front speakers are 100rms 200 watts, but still it deforms alot if I go above 20 in the volume scale.
Old 08-05-2011, 08:57 PM   #1712
J&T Distributing
My Ride: BMW
For best results make sure that the android volume is set around 2/3 on the media volume setting (press the little speaker icons on the android status bar)
Old 08-06-2011, 06:42 AM   #1713
fixjets
My Ride: 02 325Ci, 08 650i
WTF? So I try to start up IGO yesterday and get the "cannot load because you suck" message, along with a Gmail error message. So based on what I read here before (and no, I am not going to spend time to find it again) I am looking forward to reloading Android? Why why why? This is unacceptable.
fixjets is offline   Reply With Quote
Old 08-06-2011, 07:27 AM   #1714
fixjets
ttt
Old 08-06-2011, 09:11 AM   #1715
J&T Distributing
My Ride: BMW
Originally Posted by fixjets View Post
Maybe someone should come up with some kind of central FAQ that one can actually find a solution quickly instead of wasting hours searching hundreds of posts.
I did, its on my website. Android stuff is at the bottom of the page.
Old 08-06-2011, 10:38 AM   #1716
fixjets
Opey, Yes, I had an idea about what I had to do, and yes, I do know the issues. I have reloaded the system (3rd time in the past month) and it is solved, but it gets old. I was venting out loud and hoping someone might have come up with a different solution that was not posted. And yes, my description was not really accurate, but blame that on frustration.
Hopefully Dynavin will soon get us an update to prevent this kind of problem.
Old 08-06-2011, 03:50 PM   #1717
singry
My Ride: 2001 BMW 325i
So I got this yesterday with no apps installed. (the application google services framework (process.comgoogle.process.gapps) has stopped unexpectedly. Please try again.)
Then below that it says force close.
I have no apps installed.
MR. 325i
singry is offline   Reply With Quote
Old 08-06-2011, 04:00 PM   #1718
fixjets
Singry, I see you had the same problem with Igo that I did. For the record, I got the same Igo error you has in your photo, along with "Sorry, The application Gmail has stopped unexpectedly". It gets frustrating, doesn't it?
It appears that the OS somehow gets corrupted. Each time, I had to reinstall the OS to get it working properly. 3rd time this morning. Posts here were talking about how it could be from the shutdown process. That is where I think the problem is. Is Dynavin listening?
I know others are working on a new ROM and hope it helps this out.
Old 08-06-2011, 06:08 PM   #1719
Mattbuyshouses
My Ride: 2006 330i
I wonder if anyone who has/is experiencing this issue could try the 'fix' that's been suggested on multiple phone/android forums:
Go to "Settings", select "Manage Applications", select "Google Apps" then Clear all Data. The same actions should then be performed for GMail and any other Google applications that experiences the same issue. Upon the completion of the above steps, you will likely need to re-enter your account information for those services but should now sync without error.
Of course, if you get this error and aren't currently connected to WiFi, I'm not sure of the results.
If anyone tries this I'd be very interested in the results. I've yet to get this error on the system I just installed, but then, I'm always connected to my Evo hotspot as soon as the car is turned on. So far, so good. ---> knocking on wood
Mattbuyshouses
Old 08-06-2011, 11:14 PM   #1720
grain
My Ride: 03 330Cic
im curious how everyone has all these problems.
Ive been running the dynavin for a good 2 months now, and have not once gotten a force close message. im running the igo and i might have pandora installed. that's it. i have my mp3s that i play with the android player.
i just don't know why everyone is having problems with theirs.
grain is offline   Reply With Quote
Rate This Thread
