Old 11-23-2015, 02:09 PM   #1
dbarton62
My Ride: 04Z4R VF 12PSI
Boost Limiting
OK so I would like to up my boost levels by throwing on a smaller blower pulley. Thus bringing boost on lower in the RPM range.
I would also like to limit my peak boost to 9.5-10 PSI for obvious reasons.
How would one plumb one of these http://www.928motorsports.com/parts/...mitervalve.php in a MAF system? The valve would need to be pre MAF for metering.
Would the valve not need a boost reference from the pressurized side of the blower in order to know when to bleed off?
I can always call the manufacturer but would like your guys thoughts as well.
04Z4R 3.0 6 speed VF supercharged,Tial BPV,Ceramic coated Bimmerbrakes header, megan motor&trans mounts,42 design catch can, custom intake ducting,2.62 blower pulley,pre and post S/C WMI,CDV delete ,custom strut bar,3.64LSD, H&R anti roll bars, adjustable Hotchkis end links.Eibach Pro Kit,Koni Yellows. Carbon dipped interior.
dbarton62 is offline   Reply With Quote
Old 11-23-2015, 02:27 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
As we already discussed, call Karl, he designed & built that BLV. If anyone really understands it, it's him, he's in the supercharger business.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 11-23-2015, 03:43 PM   #3
dbarton62
Rob43
Rob your help on several subjects has been very much appreciated
I have contacted 928 and have info from them on hand, I do want to see what the guys on his forum have to offer as well.
Old 11-23-2015, 03:56 PM   #4
Rob43
Rob43's Avatar
It was the statement: "I can always call the manufacturer but would like your guys thoughts as well." that was of concern.
That statement implies that you had not contacted 928M at this point & were looking for opinions from the forum instead of getting solid facts straight from the designer himself.
Either way all is good.
Rob43
