Thread Tools Search this Thread Rating: Thread Rating: 44 votes, 5.00 average. Display Modes
Old 09-02-2011, 07:51 PM   #81
SweTurbo
Big Pimpin'
My Ride: 323i -98
Originally Posted by zx5rider View Post
Looks good!!! This all makes me sad I wish I was at this point.
I think you're gonna beat me
Getting sad and angry with the wastegate made me do something really stupid
I ordered myself a m3 rear, as i needed new brakes and not having to make a custom driveshaft..
Old 09-09-2011, 10:13 PM   #82
SweTurbo
Big Pimpin'
My Ride: 323i -98
Well the wategate tubing arrived a few days ago with the LSD and tranny support.
Here's a few pics i took today , plan is to have it out of the garage by the end of next week(need to weld exhaust and get rotors for rear)
Then finish up the electrical and whatever outside and try and get it running.
Space is an issue..
Notice the small airfilter i have on , looking to buy a BMC filter in the future..
ID:	416240   Click image for larger version
ID:	416241   Click image for larger version
ID:	416242   Click image for larger version
ID:	416244   Click image for larger version
Old 09-09-2011, 10:49 PM   #83
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Well I plan on tomorrow morning what did you do?
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 09-09-2011, 11:00 PM   #84
bimmerguy055
My Ride: M3
Send a message via AIM to bimmerguy055
Space is an issue..
Wow thats amazing how you didn't have to cut a hole in the firewall/frame for the WG piping to fit. nice to have pre-bent tubing. is that Nick G's manifold? WG position is different from mine. your charge pipe is exactly where mine was, keep away from dips in the road My air filter was there as-well, got wet easily, especially in non-avoidable puddles.
Is that the final position for the center-core of turbo? thats kind-of extreme for oil drain.
Without Failure There is No Success
bimmerguy055 is offline   Reply With Quote
Old 09-09-2011, 11:22 PM   #85
SweTurbo
Big Pimpin'
My Ride: 323i -98
Yeah, at first i thought about pulling the engine and either cutting or hammering the sheetmetal to get an inch or so clearence, ended up modding one of the elbows i bought so it just fitted .. no more than 1-2mm of play there(same goes for the 3" downpipe ^^) i bought 3 units of 90degree small radius bends made for manifold-making, thought i would only have to use one or two ... now i wish i had 1 more ^^
The manifold is the SPA Turbo manifold for the e36.
I'm looking into having a "U" pipe made so i can have my charge pipe beside the inlet pipe to the turbo , i will still have a small pipe underneath the subframe so idk..
I've been driving with the filter in the same place, only driver side with my supercharger setup and i've managed to keep it dry , going to install a water-resistant sock though.
It's the final position , not really happy about it but it's the best i could do.
When i get my precision turbo i will install a pump and lead it back to the dipstick
Old 09-09-2011, 11:24 PM   #86
SweTurbo
Big Pimpin'
My Ride: 323i -98
Ordered the LSD prices in sweden are insane .. i ended up paying $4k for the complete rear(no rotors or swaybar though)
Old 09-09-2011, 11:38 PM   #87
zx5rider
woha ok
'03 M3
'11 BMW s1000rr
Old 09-15-2011, 10:21 PM   #88
SweTurbo
Big Pimpin'
My Ride: 323i -98
Rear is complete now , having exhaust welded tomorrow.
Then i just need to run a new power wire to the fuelpump(as the Link will be controlling it and no the stock dme)
Also got a base tune so it should be good to start in a few days
Old 09-18-2011, 12:41 AM   #89
Dreikraft
My Ride: slow m3
damn thats snug. how'd those quad projectors come about? i miss mine.
Dreikraft is offline   Reply With Quote
Old 09-18-2011, 02:10 AM   #90
SweTurbo
Big Pimpin'
My Ride: 323i -98
They were made by lightwerkz , i like them ALOT
Got everything bolted up now , just need to weld 2 seams and wire up the fuelpump.
Oh and i might have messed up the brake bias with the m3 rear , going for a BBK once my cash reserve is back up ^^
Old 09-18-2011, 03:48 AM   #91
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
I have to ask: Did you try to fit the V-band clamp over the exhaust flange with the downpipe installed?
That looks mighty tight in there......
Old 09-18-2011, 10:16 AM   #92
SweTurbo
Big Pimpin'
My Ride: 323i -98
It fits, doesnt go on without "sliding" it on but that was planned
Wish i had another v-band so i could split the dowpipe between the cat dp and cat, but welding will have to do
Old 09-21-2011, 03:40 AM   #93
SweTurbo
Big Pimpin'
My Ride: 323i -98
Well the new FP is in and wired with 10gauge wire, tested it out without bolting down the fuelrail/old FPR .. garage still smells like gas ^^
Having "washers" made for the fuelrail tomorrow , car is going to be rolled out of the garage today hopefully
Getting close
Old 09-21-2011, 09:01 AM   #94
sedanpowersc
My Ride: 330i 5 speed
I'm excited to see what this E85 beast makes
sedanpowersc is offline   Reply With Quote
Old 09-21-2011, 11:30 AM   #95
SweTurbo
Big Pimpin'
My Ride: 323i -98
Im excited about alot of things lol , engine sound , exhaust sound , bov sound , whp etc.. im a nerveous wreck atm ^^
Bolted down abit more stuff today , now all that's left is 1 c-clip and to have 3 seams on the exhaust welded...
Old 09-22-2011, 09:19 AM   #96
SweTurbo
Big Pimpin'
My Ride: 323i -98
Started for a sec or two today when i was configuring the trigger setup... excited
Old 09-22-2011, 05:46 PM   #97
SweTurbo
Big Pimpin'
My Ride: 323i -98
TPS unset (meaning the link saw 12,5% of throttle when it actually was closed)
And MAP set to 7 bar (4bar installed)
Really rough running(Around 10 AFR) , uploading another video of it corrected and around 12 AFR
Just found out my radiator has been cracked by my dad's brother when he was cleaning the garage..(rad replaced 1 year ago )
Anyways tomorrow i'll have the exhaust welded and ill get some tuning done
Old 09-23-2011, 03:57 AM   #98
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
I bet just hearing she started up was such a wonderful sound
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 09-23-2011, 08:09 AM   #99
SweTurbo
Big Pimpin'
My Ride: 323i -98
You bet
Old 09-23-2011, 12:25 PM   #100
SweTurbo
Big Pimpin'
My Ride: 323i -98
Turns out the joy of getting it started wasnt that much of a high, after idling it around 1500rpm for 3min the engine temp shot up to 110C dunno how accurate that sensor is as it isn't calibrated but it cant be good.
However when checking the oil later i noticed water in the oilfilter and a milky residue on the oilcap.. pretty depressing to say the least
Im thinking now to either retorque the head (can someone give me the Raceware torque specs as i've lost mine) or to go emo and cut myself and disassemble the engine and put in a stock HG or a thicker cometic one.
Any tips would be greatly appriciated.
Atleast now i know the BOV is insanely loud
