Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#141 |
Banned User
#142 |
Banned User
I feel bad for not updating enough but here's a sneak of what i've been doing
#143 | |
looking GOOD! I just took off my turbo, seriously considering going to bottom mount now. I had heat issues with my turbo on top, even though I double raped downpipe, with turbo blanket. coil pack plastic dividers caught on fire, luckily I had a fire extinguisher, I recommend one! . . What mani is that? TCD like mine? I'm curious how you ran the downpipe, does it run into the corner, then drop down? I had a hell of a time getting 3" from the turbo back. it would rub on firewall and mani. I say good luck keeping the heat down!
Without Failure There is No Success
352whp@ 10PSI stock 2.5L internals! @ 20PSI with unknown power ![]() Last edited by bimmerguy055; 07-26-2012 at 03:40 PM. |
#144 | |
Banned User
![]() I'll be coating the DP/mani and wrapping it along with a turbo hat.Manifold is as custom as it gets ![]() Hope this will help along with having a vented hood ![]() Going to fabricate a divider between the VC and turbo to help it from melting , gonna make it bolt on top of the coilpacks aswell since they tend to pop up when doing some hard driving. The DP runs down by #6 header, it's a 3" DP |
#145 | |
running a intake will be fun I had put a stuby air filter on mine, i know it was not helping my performance.Side note: I got a 6266 on the way I was wondering how you got away with the oil drain like it was with your old turbo? Even when mine was top mounted, I had issues blowing the seals, I'm contemplating weather to tap higher than the oil pan, the block below is my car running with no timing sync was off ![]()
352whp@ 10PSI stock 2.5L internals! @ 20PSI with unknown power ![]() Last edited by bimmerguy055; 08-08-2012 at 02:18 AM. |
#146 | |
Banned User
![]() Well the manifold is at my fabricator( i made one out of spare tubes i had laying arond so he'll make a copy of it with awesome welds) The DP looked really spacey, only thing is it might run too close to the VC or the drug bin, gonna need to work on it abit ![]() I need the "intake" as to help with the brake booster and the head ventilation. The china one was 4" yes , i could just sqeeze some flex turbing on it between the mount and inlet, a silicone hose would never have worked ![]() The adapter is a RUFF one, i bought it from streetpower here in sweden ![]() I cant remember what size restrictor i used ![]() Your car runs great |
#147 |
Nice build. Did you run into many problems with the G4?
#148 |
Banned User
#149 |
Damn that's too bad. Do you think it's a software issue or related to the vanos, are you seeing any voltage from the solenoid?
#150 |
great build
![]() www.E46Turbo330Ci.com WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter |
#151 | |
Banned User
thank you
![]() Quote:
All i get is either missing pulses or too many pulses in the link error report. But like i said harware is what im focusing on now(fittting m3 brakes in the front and building a topmount + need to find out why my hpf clutch has failed at 1k miles) |
#152 | |
#153 |
Nice build site read through thread cool I am scared to even work on my car I still need to get fuel injector O rings. and other miscelanious bolt and parts. I then need to kit all my parts with the realoem.com drawings and double check all the parts. I bought a printer just for such a task I just would hate to start a project and not have every part I need.
#154 |
Sub'd!
#155 |
About how much was your original setup?. Parts wise not labor or tune.
#156 | |||
Banned User
![]() Not sure if i'll buy another hpf clutch if this is an issue Quote:
![]() Thanks alot ![]() Quote:
Car was $10k in 2008 Supercharger was $4k in 2009 New engine(well used one but machnined)+parts... well i've got reciepts of $20k in front of me yet alot of reciepts are missing ![]() Labor is done by me and maby a friend helping out, tuning is done by me aswell |
#157 |
Cool build! I like seeing this.
- BMW Master Certified Technician - '02 530i - PTE6262 - MegaSquirt3X - E85 fuel 392whp/344ft-lbs @ 10.5psi ![]() |
#158 |
Banned User
Need to update you guys abit
![]() So for i've converted the car to M3 front brakes(man what a PITA unless your car has the ASC in the drug bin already) I've torn down the engine to replace the lifters,chestplate and oiltray along with replacing the clutch. Clutch is on the way from HPF (got a stage 2), once it's here ill start to push for the exhaust manifold to be complete , if it isnt by the time the clutch is in already. Some pics : Cost me abit but better to replace all of them ![]() Not how i wanted the engine to sit but since i have no garage at the moment it has to do. Good thing i decided to do this, turns out all the vanos screws were loose ![]() The camshaft bolt that stripped held the cap by itself, maby it was me fearing to damage it that i didn't torque it properly ? My new chestplate ![]() And my IAT sensor adapter ![]() Now I'm waiting on a new oilpan gasket |
#159 |
Banned User
Turned some more bolts today , found this :
ATI Dampener has been moved upquite abit on my "to-buy" list... and yes that's the greg oilpump with all of it's bolts hanging on by a few threads(loctited now) |
#160 |
My Ride: ZHP Custom Stage 3.5
hmmmmm
..::|TrippinBimmer's Boost Build with Cool Parts|::.. 4**whp/3**tq SAE Corrected |
