Old 08-20-2011, 02:54 PM   #261
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Originally Posted by zx5rider View Post
Attachment 413721
Sent from my ADR6400L using Bimmer
You want to put the head on with 2 people. The timing chain gets in the way, and it's very difficult to manage it and the head at the same time. Get someone to handle the timing chain while you drop the head. You don't want to slip and scratch, dent, or bend anything at this point.
Old 08-20-2011, 03:26 PM   #262
///power
My Ride: M3
Great work... Looking forward for a video of it running.
______________________________________________
'13 Ford Raptor Black/Black
'95 E36 2JZ Drift car Gray
'06 E60 ///M5 SMG AW/Black - Sold
'02 E46 ///M3 6 Speed TiAg/Black - Sold :(
'98 E36 ///M3 Estoril Blue - History
///power is offline   Reply With Quote
Old 08-21-2011, 02:25 AM   #263
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Exactly how I did it Adam thanks. I'm using the torque sequence of the Bently manual and specs of the raceware instructions.
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 08-21-2011, 05:00 PM   #264
zx5rider
[IMG]https://lh5.googleusercontent.com/-Sv0EUstIfxE/TlFwP_sUqNI/AAAAAAAABGk/n39XvsqkeRE/s128/DSCN5885.JPG[/IMG
The intake is not bolted on and I don't have the exhaust manifold gasket so it wont be done until next weekend
'03 M3
'11 BMW s1000rr
Old 08-22-2011, 02:42 AM   #265
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Great progress!
Are you planning on pulling off the whole front of the car to put the engine back in, or dropping in over the top of the radiator support. If you are going through the top, you'll probably want to remove the A/C compressor.....and the engine mounts.
Old 08-22-2011, 08:43 AM   #266
zx5rider
Taking the whole front off the same way I took it out
'03 M3
'11 BMW s1000rr
Old 08-23-2011, 09:38 AM   #267
cobyK
My Ride: 2001 330i
nice man! great build
cobyK is offline   Reply With Quote
Old 08-23-2011, 10:01 AM   #268
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
you win
Timeless Motor Group
Old 08-23-2011, 04:01 PM   #269
zx5rider
no win still another 2 weeks
'03 M3
'11 BMW s1000rr
Old 08-23-2011, 05:03 PM   #270
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Nice progress. Glad to see her coming together!
Old 08-24-2011, 05:49 PM   #271
zx5rider
Plan now is to be on the road by the 5th......as long as this storm doesn't destroy the car ha. I guess its easier to get a new body then the engine(which is safe) at this point.
but the main delay is because I don't want to get caught in the storm on my bike going home to work on the car.
'03 M3
'11 BMW s1000rr
Old 08-24-2011, 05:50 PM   #272
zx5rider
'03 M3
'11 BMW s1000rr
Old 08-28-2011, 02:20 AM   #273
zx5rider
I have a thing for Royal Purple.
anyone see a problem with this?
http://www.royalpurple.com/manual-tr...ion-fluid.html
yes for the tranny.
'03 M3
'11 BMW s1000rr
Old 08-28-2011, 01:34 PM   #274
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
yes for the tranny.
That's what I ran in the 330Ci
Old 08-28-2011, 05:38 PM   #275
MaverickM3
My Ride: gets badge
Great build bro!!! Get it done already.. LoL
Sow how do you like the bike so far? Any cons to it?
MaverickM3 is offline   Reply With Quote
Old 08-28-2011, 05:38 PM   #276
MaverickM3
My Ride: gets badge
Old 08-28-2011, 08:49 PM   #277
zx5rider
Damn..next weekend if all goes good. About the bike no cons.......cept its too fast
'03 M3
'11 BMW s1000rr
Old 09-04-2011, 05:48 PM   #278
zx5rider
Almost done but tranny won't go on...stops about half an inch out and I can't figure out why
'03 M3
'11 BMW s1000rr
Old 09-04-2011, 06:10 PM   #279
zx5rider
After some trial com error the pressure plate is what's stopping it...any ideas
'03 M3
'11 BMW s1000rr
Old 09-04-2011, 06:55 PM   #280
SweTurbo
Big Pimpin'
My Ride: 323i -98
I dont think the pressure plate is stopping it , more like the bearing as the pressure plate can only be bolted in in one place(as it fits snugly over rivets) , the clutch disk however needs to be centered with a centering tool or the tranny wont hit the bearing right and jam.
A centering tool can be made from wood(grind it down till it goes in the bearing , then grind the rest of it down so it goes snugly in the clutch disk splines)
I used a centering tool on my 420g + HPF clutch and it was still so tight that i ended up using the bolts to "pull" the tranny to the engine the last inch.
