Old 09-04-2011, 08:37 PM   #281
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
It starts
Sent from my ADR6400L using Bimmer
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 09-04-2011, 09:12 PM   #282
SweTurbo
Big Pimpin'
My Ride: 323i -98
Just a quick tip ; remove the hood for less frustration
Dropping the engine in was a 1hour process for me with alot of pushing , pulling and aligning the tranny from underneath.. not something id like to do again very soon ^^
Old 09-04-2011, 09:23 PM   #283
Grande D
My Ride: E36 M3
Originally Posted by zx5rider View Post
I have a thing for Royal Purple.
anyone see a problem with this?
http://www.royalpurple.com/manual-tr...ion-fluid.html
yes for the tranny.
A little bit late but YES. Although it is just speculation, the consensus is that there have been a few too many Royal Purple cars with diff and tranny failures within 30k or so miles of the fluid change.
It will change your life!
Old 09-05-2011, 04:19 AM   #284
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Did you paint the exhaust manifold and turbine housing? Or is that a ceramic coating?
Old 09-05-2011, 10:33 AM   #285
zx5rider
Ceramic coating.........starter is dead.
'03 M3
'11 BMW s1000rr
Old 09-05-2011, 12:37 PM   #286
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Ah...not so fast.
Did you connect the ground strap between the right engine mount and the frame rail?
Very common mistake on engine removals....then the starter just clicks...
Old 09-05-2011, 01:43 PM   #287
douglas_ngo
Europrojektz Southeast
My Ride: Hamann Widebody
That's what happened with me. I forget to re-connect the ground strap.
Ah...not so fast.
douglas_ngo is offline   Reply With Quote
Old 09-05-2011, 06:42 PM   #288
zx5rider
Ok that was it ha....fired up for 10 sec them died and wouldn't re start took the vaule cover off to see the timing way off. Gonna re do it and try again. Why would that happen it was perfect
'03 M3
'11 BMW s1000rr
Old 09-06-2011, 12:27 AM   #289
zx5rider
After timing it all over again this is my problem
I cranked it 4 times by hand
1.look at the pics that is after the 4th time.
2. TDC mark is on point
3.arrow on exhaust cam lines up with top of head.
4.Should I worry about the intake cam?(lobes don't seem to where they should be)
'03 M3
'11 BMW s1000rr
Old 09-06-2011, 12:32 AM   #290
zx5rider
'03 M3
'11 BMW s1000rr
Old 09-06-2011, 04:28 AM   #291
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Hard to tell from that picture where that cam lobe is.
Is the locking fixture able to fit back onto the back of the camshafts after you turn the engine over 4 times by hand? That's always the test for me.
Also, which direction are you turning over the engine? Clockwise, or counter-clockwise?
Going to have a look at your chain alignment tool and I'll get back to you. Might be something there that I noticed....
Old 09-06-2011, 05:13 AM   #292
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Maybe this will help?
You can see I've got the locking fixture mounted on the back.
Here's one thing you can get wrong: how you put the chain on these:
You should put the chain on, and push the left sprocket towards the left as far as possible. If the chain is in the right place, you should have equal tension on the top and bottom. See the picture below:
When you transfer this to the engine, the chain position has to stay exactly the same on the sprockets:
Then of course you mount the timing fixture, rotate the engine, and lock the nuts down:
If you are completing this process, rotating the engine 4 times clock-wise, and the cam holding fixture won't fit back on, you need to re-do the sequence. Don't get upset....I had to do it a number of times to get it right myself.
One other possibility, and I hope you didn't do this, is that you took off the cam splines from the camshafts, then re-attached them? If this is the case, you need to get another tool to re-align the cam splines. They are very picky about how they sit. Hopefully this isn't the case....
Edit: How tight are you running the timing chain tensioner tool? I didn't have a torque wrench that measured that low, so I just made it finger tight....where all the slack was gone.
Old 09-06-2011, 11:51 AM   #293
zx5rider
Thanks Adam! Car is running now but woot idle but I'm not worried
'03 M3
'11 BMW s1000rr
Old 09-06-2011, 12:52 PM   #294
sedanpowersc
My Ride: 330i 5 speed
pics & videos!!!!!!!!!!!!!!
sedanpowersc is offline   Reply With Quote
Old 09-06-2011, 01:19 PM   #295
zcchen
My Ride: Z3M/F80M3
pics or didn't happen.. lol.. jkjk.. congrats!!
zcchen is offline   Reply With Quote
Old 09-06-2011, 06:51 PM   #296
zx5rider
Ha will put both up soon I'm back home now so no progress untill Saturday. (Car is in parents garage 2 hours away) just got soaked on my bike wanted to take the car so bad but I need to bleed the clutch I think
'03 M3
'11 BMW s1000rr
Old 09-07-2011, 03:06 AM   #297
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Just to confirm, after you re-did the VANOS alignment, and turned the engine over by hand 4 times, did the Cam locking fixture fit onto the back of the camshafts again?
If the cam timing is still not perfect, this might be part of the reason why it won't idle.
2hrs drive...wow. And I used to complain about living 40 minutes away from my shop from 2008 through 2010 when I built the 330Ci.
Old 09-07-2011, 04:58 PM   #298
zx5rider
yes but ill take the valve cove back off and check again next week.
'03 M3
'11 BMW s1000rr
Old 09-07-2011, 05:02 PM   #299
zx5rider
Is my clutch slave cylinder bad? I accidently hit the clutch not thinking while the transmission was out and its stuck all the way out and I can't push it back in.
'03 M3
'11 BMW s1000rr
Old 09-07-2011, 05:57 PM   #300
McSpeed
My Ride: 2005 ZHP TT Stg 1
seems like this is a clutch disassembly right of passage..you're not the first one to do that...I reassembled mine after bending the teeth on the metal retention plate back to normal and pressing it back in...once that plate is back in place the shaft can do what it wants, until you're bleeding the cylinder- then a special tool is usually used to compress it.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
