Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#361 |
My Ride: TT Turbo 2003 330i
well now that the car is "done" i will go over everything again.
![]() Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around 2011 BMW S1000rr |
#362 | |
I had a vacuum line buried under the intake crack (well the plastic Y I used cracked). I must have damaged it at some point during reassembly, but once I found it my car was fine. Little things can make a world of annoyance.
-Tyler
1998 528i 5-speed Work in progress 1988 Toyota Pickup (4WD 5-speed) daily 2007 San Marino Blue 350z 6-speed sold 1996 328i 5-speed sold www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com |
#363 |
Oh wow i just thought of something the vacuum line going to the(not sure what its called but i think is has something to do with emissions and its on the exhaust side)the line shattered and i left it off and I just plugged it by running the hose that should go to that little black can for the OEM exhaust flap back in to the manifold.
If that makes sense.
#364 |
There should be two vacuum lines running to the back (IIRC - my car does for sure).
The emissions system has the EVAP purge line (with the solenoid on it thats under the intake manifold). The other line on my car runs to the leak diagnosis pump - which also acts as the vent solenoid on the EVAP system. There is also a line that goes to the fuel pressure regulator, you'll need that attached for sure.
-Tyler
#365 |
So I'm about to drive the car home now.
Now it idles and no more smoke out the exhaust. But now at idle the red oil pressure light is on. I checked the oil level its good and the light goes off past 1500 rpm. Sent from my ADR6400L using Bimmer
#366 | |
Banned User
![]() Did you check bearing clearance wasnt too loose when fitting the crank ? |
#367 |
Dumb question but where do I hook up a gauge. The bottom end was put together for me.
#368 | |
Banned User
You take out the OEM oil pressure sensor and screw one in there |
#369 |
OK well the pressure was fine at first this is a new thing.
#370 |
You could tap your VAC oil cap, no? (maybe easier than getting at the stock sensor location)
![]() Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs Turbo Driveability Video Horsepower vs. Torque - updated |
#371 |
My Ride: 2004 E60 530i 6speed
You need to remove the stock oil pressure sensor and add a T fitting(from Lowes) so you could install both sensors.
Be sure to get the cooper washers to seal things back up.
![]() ![]() ![]() 530i E60 Custom Turbo/Nitrous (PSI_unknown) |
#372 | |
Edit: I looked it up it is the one wire plug. Yeah Ill see what I can do after work tomorrow.
![]() Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around 2011 BMW S1000rr Last edited by zx5rider; 10-03-2011 at 02:31 PM. |
#373 | |
Seriously let me know it takes a few seconds and I'll post it up.
#374 |
I understand I said what I did because the wire on that pressure sensor broke off and I soldered it back on
#375 |
The trick most people use is to tap the bolt head (drill hole and use 1/8th inch NPT tap) on the banjo bolt at the back of the oil filter housing, for the line that feeds the vanos assembly.
This is also where your turbo feed line should come from with the TT kits if I'm not mistaken. As a result, you have a nice 1/8th" NPT port that you can buy a T to thread into.
-Tyler
#376 |
wow so much work, this better dyno over 400whp, if not i'll be pissed with you lol.
![]() Stretch + poke = All show, no go!!! |
#377 | |
#378 |
ya, it will be quick, your still faster than an m3 by far. Race a e92 m3 yet? i'm sure your just as quick if not quicker. But hey, if doesn't dyno that much more, you still have a rebuilt engine and the achievement of doing something 95% of people aren't capable of doing
#379 | |
. Although I took it apart and put it back together and it sort of ran I am not satisfied. So I'm also one of the 95% I feel. Anyways its at an Indy shop now they are a lil jammed and won't look at it till next week. Nothing will ever feel like doing 0-60 in 2.7 sec and the 1/4 in 9 sec......this thing is sooo nasty it scares me.Sent from my ADR6400L using Bimmer
#380 |
This was at the shop along with a Diablo.
