Old 10-25-2011, 01:47 AM   #401
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
1.) You need to find out the main bearing clearances MEASURED by the shop that put your engine together. They should have documented the clearances for all 7 main bearing caps.
2.) If you used Raceware main bearing studs, confirm with the shop that assembled your engine that they cut 2 of the studs down to clear the oil pump. If the oil pump were to hit these studs, even slightly, you'd have a leak between the pump and the block, as well as a drive chain miss-alignment. I've also heard of a case where the oil pump pickup was bent too close to the bottom of the oil pan, and it literally starved the oil pump. (low pressure at idle, and max of 45 PSI at 6k RPM)
FYI, I used OEM main bearings on my engine build, the main caps were align honed, and we arrived at 17 thou of clearance as an average. My engine will run 5W30 oil.
Old 10-25-2011, 01:51 AM   #402
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Originally Posted by zx5rider View Post
btw this .82 a/r made me a lil sad I don't feel it good untill 3700rpm it was like 2200rpm before.
The difference between the 2 housings is very small. Talk to Nick...he's tested this. I can't post exactly what it is, because it's his info, but he does have this info...
He's also done some other very interesting testing that he may talk to you about. If you know about it, please keep it to yourself. Again, it's his info.
Old 10-25-2011, 04:49 AM   #403
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Well maybe I don't remember very well but I know I can feel it.
Sent from my ADR6400L using Bimmer
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 10-25-2011, 07:01 AM   #404
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
This is the choice you have to make when changing turbine housings, turbine wheel sizes, compressor wheel sizes, and compressor housings. The bigger you go, you give up some lower RPM response for top end power.
In this case, the better breathing 0.82 exhaust housing doesn't breath any better than the 0.63 exhaust housing at 7 psi. Nick has tested this....he didn't see more power until above your current boost level.
In my case, I might see even more lag, as I've got a larger compressor wheel as well as the 0.82 A/R exhaust housing. But....I've also improved the VE of the engine significantly over OEM, so I might have balanced that off with higher exhaust flow at lower RPM to help spool the turbo up similar to the stock setup. We'll just have to wait and see....
Old 10-25-2011, 12:02 PM   #405
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Videos!!
Old 10-25-2011, 03:02 PM   #406
SweTurbo
Big Pimpin'
My Ride: 323i -98
What is this .. Adam using FI ? Blasphemy ! (i know its for the grocery getter .. but in my mind adam = NA )
Old 10-25-2011, 05:04 PM   #407
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I've been seduced:
Old 10-25-2011, 05:56 PM   #408
zcchen
My Ride: Z3M/F80M3
I've been seduced:
That a HTA 76? 82? 86? 94?
seems like u would put a HTA76 in there
zcchen is offline   Reply With Quote
Old 10-25-2011, 06:25 PM   #409
MaverickM3
My Ride: gets badge
67?
MaverickM3 is offline   Reply With Quote
Old 10-26-2011, 03:23 AM   #410
zx5rider
ok so i was told for the main bearings .0018 the machine shop also says I should try using 15w-40 .
'03 M3
'11 BMW s1000rr
Old 10-26-2011, 05:56 AM   #411
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Those wouldn't even start to spool by the time I hit redline. LOL
Well...maybe a little bit, but they are too big.
Originally Posted by MaverickM3 View Post
67?
Smaller. I still might change turbos again, but it's not for something bigger, just different design.
You are golden on clearance, basically OEM specs. You can run that oil, but I still think that you might have an issue.
With OEM clearances, and OEM oil weight, you shouldn't have a low pressure light come on at idle.
Do you have an independant oil pressure gauge you could video while driving the car?
Old 10-26-2011, 11:30 AM   #412
MalibuMafiaV
My Ride: E60 M5 & 335i ST
Probably a dumv question but the picture kinda looks like it...
Did you remove your bumper completely to fit that intercooler and then just put the plastic back on?. Or did you get through the bumper and leave some parts of metal still there?.
TheMalibuMafia.com
Instagram
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i - ST Precision 6266
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
MalibuMafiaV is offline   Reply With Quote
Old 10-26-2011, 04:32 PM   #413
zx5rider
No just the red light.
Just this short video.
'03 M3
'11 BMW s1000rr
Old 10-26-2011, 05:44 PM   #414
SweTurbo
Big Pimpin'
My Ride: 323i -98
How big is the oil inlet hose on the kit ?
Since the pressure sensor is probably where you draw oil from the turbo that's my second guess.
But really , we shouldnt be guessing if you're scoring your crank or not , get a gauge hooked up ASAP
Old 10-26-2011, 05:52 PM   #415
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
I think you need more info...like the actual oil pressure versus engine RPM.
You can get this with a good scanner like the AutoEnginuity scan tool with advanced BMW functionality. Here's an example of what it can do:
Basically, you can get oil temp and pressure without adding more sensors or gauges...as well as watch a lot of what is going on in the rest of the engine.
If I were you, I'd get the data I suggested above with the engine oil you have now, and then try changing to the oil that your machine shop recommends and compare.
Old 10-26-2011, 09:10 PM   #416
zx5rider
I have a tool I'm going to go out side with my laptop right now and see if i can do this.
'03 M3
'11 BMW s1000rr
Old 10-26-2011, 09:34 PM   #417
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
Good stuff and you got the right guy leading you in the right direction.
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
Old 10-26-2011, 10:14 PM   #418
zx5rider
Yeah this is the most I can get.
'03 M3
'11 BMW s1000rr
Old 10-27-2011, 03:40 AM   #419
zcchen
My Ride: Z3M/F80M3
I think you may have mistaken what I refer to.. lol.. it is not the diameter of compressor in mm.. HTA is the line of turbo developed by Forced-Performance in Texas.. HTA76 is a GT30R, HTA82, 86 are GT35R, HTA94 is GT37R.. Hope you are not running anything smaller than the GT3076HTA.. Oh well, if you are interested, you should look more into that turbo.. I can say that the EVO community has somewhat proven the HTA turbos outspools the Precision counterparts that makes the same hp.. We should keep this thread back to track.. Let me know if you want more info on those turbos.. Or I'm sure you have got more than enough research skills
Old 10-29-2011, 07:25 PM   #420
zx5rider
If everything goes well dyno next week.
'03 M3
'11 BMW s1000rr
