Old 04-30-2011, 03:33 PM   #41
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Ha and PEI I have all of the stuff i think is important inside now. Block, Head, Intake, Turbo + Manifold, Head lights, ECU,
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 04-30-2011, 03:40 PM   #42
STORMER
My Ride: AA SC 98 M3
Nicely done my friend. Its been said but your level of hardcore on this endevor is outta control Hope it all comes together nicely for you Sub'd
360+rwhp
AA Stage 2, Arp2000, Underdrive Pulley, M50 Manifold, Cat Delete, Supersprint Exhaust, M5 Clutch w/ Lightweight Flywheel, Euro Fan, FK Coilovers, AEM Boost Gauge, Zhp Knob, Stoptech Brakes, R1 Rotors
Originally Posted by Sweetness View Post
You sir, just thread jacked the sh!t out of OP.
STORMER is offline   Reply With Quote
Old 04-30-2011, 04:19 PM   #43
zx5rider
Thanks and so do I
'03 M3
'11 BMW s1000rr
Old 04-30-2011, 04:23 PM   #44
zx5rider
How do the cylinders look? Can they be honed and not change the bore?
'03 M3
'11 BMW s1000rr
Old 04-30-2011, 04:47 PM   #45
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
You sir had a very close call with that engine.
Look at the spark plug electrodes....signs of detonation right there, which is the result of the oil contaminating the combustion chamber reducing the fuel octane.
The other stuff on the pistons and cylinder head is just excessive oil/carbon burned on. Nothing really to worry about.
Yes, I would still get the block bored and honed. The proper finish of the cylinder bores is not possible by just re-honing. They are actually oval right now...they need to made round again.
Edit: Oh...and BTW, I paid $900 for my Vanos tools by the time shipping, brokerage, and duties were factored in.
Old 04-30-2011, 05:08 PM   #46
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
They can be had much cheaper on Ebay nowadays.
One slick tool was the little BMW torque wrench that John loaned me to reset the tension on the chain. I'd definitely get my hands on that again if trying to set the tension with the motor in the car.
Old 04-30-2011, 05:11 PM   #47
zx5rider
oh man....my friend just told me it was a big process to put the crank back in is that true?
Should i just bring it to them with the crank on?
'03 M3
'11 BMW s1000rr
Old 04-30-2011, 05:24 PM   #48
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
It's no big deal. The main thing is just making sure the bearing clearances are right when re-assembling, but we can walk you through that with a torque wrench and "plastigauge".
BTW, the OEM main bearing cap bolts can be re-used...pretty much a standard grade 10 fastener.
Do you have new main and rod bearings?
Old 04-30-2011, 06:05 PM   #49
zx5rider
I havnt bought any new parts yet.
Are you saying I can't reuse the rod cap bolts?
Sent from my ADR6400L using Bimmer App
'03 M3
'11 BMW s1000rr
Old 04-30-2011, 06:46 PM   #50
SweTurbo
Big Pimpin'
My Ride: 323i -98
Every book says to replace any cap-bolts except camshaft ones , however i would trust adam on this one
Old 04-30-2011, 08:56 PM   #51
zx5rider
I will definitely.
So where do I start to remove this crank?
'03 M3
'11 BMW s1000rr
Old 04-30-2011, 09:19 PM   #52
SweTurbo
Big Pimpin'
My Ride: 323i -98
I will definitely.
Remove rear gasket
Remove "breastplate"(chaincover)
Remove chain(s)
Remove chain sprocket
Remove main caps
Lift crank up , be careful it's heavy (50pounds)
Old 04-30-2011, 09:38 PM   #53
zx5rider
Remove rear gasket
Remove chain(s)
Remove main caps
ummm my main pulley is still on.
'03 M3
'11 BMW s1000rr
Old 04-30-2011, 09:41 PM   #54
BimmerDude18
My Ride: 1998 528i
Rod bolts are torque to yield, so they are stretched and can't be reused.
Main bolts are not torque to yield, and can be reused, although BMW TIS says to replace them.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 05-01-2011, 11:31 AM   #55
zx5rider
http://cgi.ebay.com/ebaymotors/BMW-M...motiveQ5fTools
Is this worth it or will someone rent me one?
'03 M3
'11 BMW s1000rr
Old 05-01-2011, 11:34 AM   #56
aggieE46
Keep it clean
aggieE46's Avatar
It's nice to have. I'm going to invest in my own kit.
Old 05-01-2011, 12:03 PM   #57
SweTurbo
Big Pimpin'
My Ride: 323i -98
Buy it and sell it to me later
that way none of us loose that much
Oh and for the main pulley one .. you better get your arm grease ready, sucker is in there with 440Nm of torque
Old 05-01-2011, 12:30 PM   #58
zx5rider
WHAT!!! So it is impossible...ok well guess ill bring it to the hobby shop tomorrow.
'03 M3
'11 BMW s1000rr
Old 05-01-2011, 01:14 PM   #59
SweTurbo
Big Pimpin'
My Ride: 323i -98
Well not really impossible , i had a friend help me and we got it by :
1. 2ft breaker bar
2. Flywheel bolts mounted
3. Prybar between flywheel bolts to help lock the engine
4. 200pounds of me holding the engine down
5. Heat , lots of it !
6. Arm grease
7. More grease
8. GAAAAAHH
And then everything was good , until the pulley had to come off, i used a sledge to get it to pop off (not recomended as it might damage the crank / pulley)
Old 05-01-2011, 01:46 PM   #60
zx5rider
Heat? hmm
1. 2ft breaker bar
6. Arm grease
7. More grease
8. GAAAAAHH
'03 M3
'11 BMW s1000rr
