Old 05-31-2011, 08:17 PM   #161
zx5rider
My Ride: 03 M3 , 03 TT 330,
Send a message via AIM to zx5rider
Originally Posted by sedanpowersc View Post
Y U No update???
Ha nice pic but because I'm not paying extra money to get the pistons sooner.
2 weeks I think.
'03 330 Technique Tuning Stage 2 Turbo. (Parting out)
'03 M3
'11 BMW s1000rr
zx5rider is offline   Reply With Quote
Old 05-31-2011, 08:33 PM   #162
Elvin123
My Ride: 328i
Damn that's fresh, I would love to go turbo. That thing probably sounds amazing.
Elvin123 is offline   Reply With Quote
Old 06-01-2011, 05:14 PM   #163
zx5rider
Is there any reason to replaces my chains? crank to cams, cams to eachother and crank to oil pump?
'03 M3
'11 BMW s1000rr
Old 06-01-2011, 06:32 PM   #164
sedanpowersc
My Ride: 330i 5 speed
it really depends on alot of things, but since you're coming from what 300whp and hoping to get up to 415 it might not be necessary but would probably be advised
sedanpowersc is offline   Reply With Quote
Old 06-01-2011, 06:37 PM   #165
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
No
Unless your dealing with a 200K plus, I wouldn't.
Looking forward to you finishing.
SUMMIT POINT WV 1:24:229 SCCA
Old 06-02-2011, 03:14 PM   #166
zx5rider
Originally Posted by Rob43 View Post
No
Sounds like a solid no.......someone got very upset when I said I wasn't so I though I would ask.
Me too
'03 M3
'11 BMW s1000rr
Old 06-05-2011, 04:27 PM   #167
zx5rider
http://www.jegs.com/i/ARP/070/201-4302/10002/-1
Are these the right studs? If not can someone point me in the right direction...maybe a ARP part number
'03 M3
'11 BMW s1000rr
Old 06-05-2011, 04:27 PM   #168
zx5rider
'03 M3
'11 BMW s1000rr
Old 06-05-2011, 05:08 PM   #169
BimmerDude18
My Ride: 1998 528i
Are you timeserting the block?
Those are the correct M50/M52/S52 studs, but, they have less thread engagement than say the raceware E46 studs. Personally I'd use the racewares.
-Tyler
1998 528i 5-speed Work in progress
1988 Toyota Pickup (4WD 5-speed) daily
2007 San Marino Blue 350z 6-speed sold
1996 328i 5-speed sold
www.e46nonM.com - www.precision-sport.com - www.flyingwindowtinters.com - www.techniquetuning.com
BimmerDude18 is offline   Reply With Quote
Old 06-05-2011, 06:15 PM   #170
zx5rider
No I'm not timeserting but ok i'm looking for some racewares now.
'03 M3
'11 BMW s1000rr
Old 06-05-2011, 08:00 PM   #171
Rob43
Rob43's Avatar
Give a link to the Racewares when you get it.
Old 06-05-2011, 08:04 PM   #172
SweTurbo
Big Pimpin'
My Ride: 323i -98
I thought using studs were bad in the M54 ?
I've heard alot about stripping the block, with lower CR i'm prolly going to trust a new set of OEM's , unless there's a better option
Old 06-05-2011, 08:17 PM   #173
BimmerDude18
My Ride: 1998 528i
One location
http://store.vacmotorsports.com/arp-...-bmw-p114.aspx
-Tyler
Old 06-06-2011, 08:44 PM   #174
zx5rider
Originally Posted by BimmerDude18 View Post
They say use with timeserts....
'03 M3
'11 BMW s1000rr
Old 06-06-2011, 10:15 PM   #175
BimmerDude18
My Ride: 1998 528i
I'll defer to adam, and I know Activ3 has racewares in his car as well.
-Tyler
Old 06-06-2011, 11:38 PM   #176
SweTurbo
Big Pimpin'
My Ride: 323i -98
So...
Go with OEM or Raceware ?
If raceware : Timesert or not ?
Im ready to put my head on but i'd like to keep it on at 30psi, anyone ?
EDIT I was going to order some stuff from VAC so i inlcluded a set of raceware studs , now just to know if to timesert or not ?
Old 06-07-2011, 06:44 AM   #177
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Where did the timecert thing come up!?!?
Just put the 10mm raceware studs in and be done with it.
The problems people see with the studs pulling out are from overheating the M54 block (water pump failure) not from too much power.
I was on the phone with a guy yesterday for nearly an hour discussing this topic....learned a lot about his engine program, and was able to share a bit of my experience. Sad story though...engine did overheat and he's now looking for a new block.
Old 06-07-2011, 11:08 AM   #178
SweTurbo
Big Pimpin'
My Ride: 323i -98
I thought that was the issue(overheating), this is what vac says ;
Aluminum Block Engines Use Raceware Head Stud Kits and must betime serted for proper installation. Inquire about our Time Sert kit or our in house proprietary time serting service.
I guess that's just as a safety ?
Dunno how much thread engagement there is but with a timesert you only get 25mm(longest i found)
Old 06-07-2011, 12:23 PM   #179
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
They are just trying to sell more product in my opinion.
Old 06-07-2011, 04:26 PM   #180
ritos530i
My Ride: 2004 E60 530i 6speed
Send a message via MSN to ritos530i Send a message via Yahoo to ritos530i
I've seen a lot of people say don't do timeserts but not one person has stated why not. What's the issue behind using them and if it's cost that's no real reason since they can't be that much.
530i E60 Custom Turbo/Nitrous (PSI_unknown)
ritos530i is offline   Reply With Quote
