Old 04-22-2011, 08:48 AM   #1
KohbraxE46
My Ride: E46 328i
Sun shade stuck
My sunroof shade gets stuck about half way. Is there once I remove the window to see inside there? To see if there is something stuck.
Window shade was previously sucked in. Any help pleaseeee
KohbraxE46 is offline   Reply With Quote
Old 04-22-2011, 09:03 AM   #2
darkapollo
My Ride: 2000 328i ZSP
There are some plastic clips that break. Need to pull the glass out to replace them.
DO NOT OPEN THE SUNROOF if the shade isn't able to move! You will snap the gear and drive belt which is not a replacable part.
darkapollo is offline   Reply With Quote
Old 04-22-2011, 11:34 AM   #3
KohbraxE46
My Ride: E46 328i
well i got it fixed this morning.
what happens if the gear and drive belt break. Do you have to get a whole new "sunroof" system? (with rails and all) Do you have to pull apart the whole roof?
i have another e46 and you can hear the motor working but the window doesn't even budge or try to.
Old 04-22-2011, 12:15 PM   #4
darkapollo
It is one whole unit.
Mine was stuck and now if it is open just a little the sunroof catches it and jams.
Old 04-26-2011, 06:58 AM   #5
druggrepp
My Ride: 325ci 2001
You have to drop headliner to get sunroof out. PITA
druggrepp is offline   Reply With Quote
Old 04-26-2011, 09:04 AM   #6
KohbraxE46
My Ride: E46 328i
Is there a DIY to pulling off the headliner ? Is it hard to do? Could this risk my headliner?
Old 04-29-2011, 02:54 AM   #7
AutomanTurk
My Ride: '03 330i, '06 325i
My gear snapped, I just bought a used sun roof motor for $50 and it was good as new. The motor is behind the sunroof control console, easy diy.
AutomanTurk is offline   Reply With Quote
