Sponsored by The Tire Rack
Old 04-29-2011, 08:41 PM   #1
500rwhp
My Ride: 03 Cobra < FRC < 330
9.5"s up front on a sedan?
With a moderate offset and a somewhat stretched tire do you guys think I'd have any issues fitting a 9.5" wheel up front? I know its less than ideal... So please dont flame me, but would appreciate any help.
UPDATE:
I have a pair of ET 43 19x9.5's on the way!
Already have a set of 235/35 Michelin PS2s.. I know they run a little wide for 235/35s..
Talked to a guy at H&R and the sport cupkit was made to oem specs, so it shouldnt be any more likely to rub on the inside
From what Im hearing I should probably aim for around ET33... Hoping that with a 10mm spacer Ill end up just inside the fenders, but far enough away from the suspension...
Really not trying to run negative camber and Im keeping my fingers crossed that it doesn't rub..
Thanks to everyone for their help... I will keep you guys posted!
500rwhp is offline   Reply With Quote
Old 04-29-2011, 09:21 PM   #2
gawa
My Ride: 01 325xi
Depends on the offset and tire.
Gunmoto was running an 18x9.5 +35 before with 255/35R18 (Michelin Pilot Sports iirc) with no rubbing problems, I tried the same set up but with diff tires (Yokohama S.drives) and I rub the coilover spring perch. Have to run a 5mm spacer to clear. It's pretty tight fitment, I don't have any experience with running a higher offset but I get the feeling the wheel might end up rubbing with the suspension.
gawa is offline   Reply With Quote
Old 04-29-2011, 09:45 PM   #3
mimalmo
My Ride: 04 330i ZHP 6MT
Definitely possible. Try a 9.5" ET33 and a 235/35 tire
mimalmo is offline   Reply With Quote
Old 05-02-2011, 01:42 PM   #4
500rwhp
Thanks for the pointers guys.
What if I went with a 19x9.5 ET 43 up front?
You guys think I might have any issues rubbing the against the strut? Have no problem running spacers to get them close to flush with fenders if necessary
Old 05-02-2011, 01:47 PM   #5
w0w
My Ride: '02 M3 Vert
youre gonna rub on the inside
daron
w0w is offline   Reply With Quote
Old 05-02-2011, 02:01 PM   #6
500rwhp
If I ran a spacer to get the ET43 flush with the fender would I still rub?
Old 05-02-2011, 02:16 PM   #7
w0w
ya you would need to run a spacer to go down to 30 offset or so for it to clear IIRC
daron
Old 05-02-2011, 10:10 PM   #8
BartenderPlease
My Ride: '03 540i/6 M-Sport
my et30 has a little room to go inward.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 05-02-2011, 11:08 PM   #9
500rwhp
9.5's up front?
Old 05-03-2011, 11:41 AM   #10
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
If you were to go with a 9.5 up front I'd recommend going with something lower offset than that. I've found that our 9.5 ET33s can fit, but even then it may require a spacer to clear some suspension setups. As for a tire, it depends really. A 235 that is stretched would probably be your best bet, but it's tough to say since there are so many variables that affect how the wheels will fit.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 05-04-2011, 11:52 AM   #11
BartenderPlease
Originally Posted by 500rwhp View Post
9.5's up front?
9.5 yes
Old 05-04-2011, 06:42 PM   #12
500rwhp
9.5 yes
Sweet. Did you do any camber adjusting or fender rolling?
is the et30 your total offset with spacers or the original et of the wheel?
Going to try to find pics or if you can point me in the right direction Id appreciate it
Old 05-05-2011, 10:35 AM   #13
BartenderPlease
I rolled the front fender lip and have about -2 of camber as well. They were originally et45 wheels and I added a 15mm spacer. Since my car is so low and soft, and my shocks are in bad shape due to the roads, I rub a lot. I could use some smaller spacers.
Click the picture in my sig!
Old 05-05-2011, 11:00 AM   #14
Penguin Koolaid
Banned
My Ride: Inline Six
8.5 et35 will sit flush with the fender. 9.5 et30 will be pushed out another 18mm.
Penguin Koolaid is offline   Reply With Quote
Old 05-12-2011, 08:43 PM   #15
500rwhp
going square!
UPDATE:
Old 05-12-2011, 08:58 PM   #16
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
i ran 19x9.5 et38 with 255/30 19 no problems
/_________\
O==[][]==O
Old 05-13-2011, 12:04 AM   #17
mimalmo
Interesting because I ran that same offset in a 9" wheel for a while with a skinnier tire and it rubbed a little on the inside under full-lock of the steering wheel.
Old 05-13-2011, 09:28 PM   #18
BartenderPlease
It's because your car and his car have different spring rates, ride heights, and most likely camber specifications.
Old 05-13-2011, 11:35 PM   #19
mimalmo
I should have been more specific. It wasn't a rubbing that was from a tire. I believe it was the inner lip of the wheel on the coil spring of my KW coilovers.
I really could only replicate it in a parking lot at low speeds where I could turn the wheel to full-lock. Day to day it was not a problem. In fact I drove it like that for a month and just remembered not to fully turn the wheel. The current 19x9 ET28 I'm running doesn't rub at all.
Old 05-17-2011, 05:56 PM   #20
BartenderPlease
Oh no my bad, I misread your statement.
