Sponsored by BimmerWorld
Old 04-30-2011, 08:31 PM   #1
Avet4
My Ride: 2004 330i 6spd
how to get rid of raked look?
What would be a recommended method?
I'm gonna be using brandnew ZHP shocks front and rear and I want to figure out which springs I can use with them to keep the car level.
If I get H&R I wouldn't get the Race b/c I don't wanna go that low at any point on the car. The rear ride height of the Sports suits my needs better, but then the front Sports drop even lower. I want the front to be level with the back. Is there a way to raise the height of the front aside from which spring I use?
Sorry if I sound clueless in case there is an obvious solution.
ALSO! I will be using TMS sways front and rear and also want to replace all spring pads front/rear/upper/lower. Are there thicker pads I can use on the front? Would this have any negative effects on ride or reliability?
Avet4 is offline   Reply With Quote
Old 04-30-2011, 09:10 PM   #2
genuity
My Ride: 2001 330iS
I have only seen thicker pads for the rear and it is the upper rear pad from the Xi models; of course that won't help you get rid of a raked look but will increase it slightly.
genuity is offline   Reply With Quote
