DIY: hid retrofit on a budget! (for halogen lights) - Page 12 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 10-14-2011, 02:11 PM   #221
///Mostarac
///Mostarac's Avatar
My Ride: 370z & Cbr600rr
if it were me, i wouldnt have bought the 55watt bulbs.
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 10-14-2011, 02:27 PM   #222
silp3
My Ride: 02 325
When DDM delivers my kit, is it possible to just swap bulbs for 35w h1s or is the ballast suited for 55w only?
silp3 is offline   Reply With Quote
Old 10-14-2011, 08:19 PM   #223
///Mostarac
ballasts are universal so any bulbs will fit. Since you already ordered it, you might as well go ahead and try it until you get replacement bulbs
-Benny
Old 10-14-2011, 08:35 PM   #224
domcreates
Banned User
My Ride: Jet Black 1999 323i
If you go with a 55W set up i'd love to know the outcome. That would be cool if it worked.
domcreates is offline   Reply With Quote
Old 10-15-2011, 04:03 AM   #225
silp3
My Ride: 02 325
I'll post some pictures when I finish it up. I'll even park next to my e90 with OEM D2S bulbs to compare the light output
Old 10-17-2011, 12:11 PM   #226
KohbraxE46
My Ride: E46 328i
So excited !!!!!! ( girls accent )
This is what I should have done from the start. Now all I need are my ballast!
KohbraxE46 is offline   Reply With Quote
Old 10-17-2011, 12:42 PM   #227
domcreates
Banned User
Perfect but i'm also more concerned about how they affect the headlight as far as melting it.
Let us know, thanks.
Old 10-17-2011, 01:40 PM   #228
cobyK
My Ride: 2001 330i
anyone want to share where they mounted their ballasts?
cobyK is offline   Reply With Quote
Old 10-17-2011, 02:29 PM   #229
sillieidiot
My Ride: '06 AW 330ci
Question: Can you do the exact same thing to the inner headlight bowls?
yes
Old 10-17-2011, 04:06 PM   #230
Saintluk2
My Ride: 2000 323i sedan
My ballasts came with mounting plates. Drivers side I mounted the plate on an unused .75" long .25" width rod sticking out, between the strut tower and headlight assembly.Then secured it with a small amount of epoxy. Passenger side wasn't that easy due to the wiper fluid reservoir. I mounted the mounting plate on the plastic tire fender, above the tire, with two .5" screws.
Anyone have problems with brightness on their projector ? I think the problem might be the cheap replacement bulbs i bought on ebay. One of them has yellow residue on the spherical part of the bulb. covers about 30% of that little area shaped like a sphere.
Saintluk2 is offline   Reply With Quote
Old 10-17-2011, 04:58 PM   #231
Saintluk2
Is the outside supposed to be sealed from the inside of the headlight ? with the bulb clipped in there seams to be a gap around the bulb holder plate where moisture could leak into the headlight. is that normal ??
Old 10-18-2011, 12:25 PM   #232
cobyK
My Ride: 2001 330i
i noticed this too. for now, i am going to rig something to seal it up. lmk if you figure anything out on this...
Old 10-18-2011, 12:25 PM   #233
cobyK
My Ride: 2001 330i
anyone else on ballast mounting. pics???
Old 10-18-2011, 10:10 PM   #234
Saintluk2
found this on ecstuning bulb cover hmmm who wants to try it
Old 10-19-2011, 05:38 AM   #235
maxi
My Ride: BMW E46 328I, 1999
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Old 10-19-2011, 05:38 AM   #236
maxi
I have ordered the Mini Gatling shroud by mistake, Is that ok, or I should get the E46-R's .... ?
Old 10-19-2011, 10:37 AM   #237
chen.nijmegen
My Ride: 98 328i
I mounted the ballast at the rear bottom side of the high beam.
It is difficult to describe... though.
At rear bottom side of high beam (you have to remove the headlight of course) you can find 2 (or 3?) mounting holes.
My ballast comes with 3 mounting holes but they are not alligned with the headlight. But anyway I use 1 screw to mount it. And I use tie up for the 2nd. Also, I used 2 tie ups to put angel eye converter above the ballast.
So far they are quite stable staying there.
chen.nijmegen is offline   Reply With Quote
Old 10-19-2011, 10:52 AM   #238
silp3
My Ride: 02 325
DDM Tuning has been taking WAY to long to even SHIP my kit. They give some crap tracking number from some bogus site coming from Singapore.
In the meantime, I ordered a kit from The Retrofit Source. 35w this time. I noticed my high beams were a 55w halogen bulb. When I was test fitting, I had left my high beams on and noticed a smell. I could see through the lens cover smoke.
I am assuming the burning is OK, and it is just burning off debris, dust and any hand oils from handing the housing. I really hope it is not due to paint I chose to spray with.
Old 10-19-2011, 11:54 AM   #239
kvinal
My Ride: 323i
I ordered the whole kit from andrew at TRS and he was very helpful. I also add angel eyes and e46 shrouds.I installed like in diy but I drilled a 3/8 hole (hidden behind shroud) to run the two bi xenon wires through which appears OP didn't run this feature. Also used same home to run ae wires. Paint I chose was krylon fusion flat black Wichita looks nice but definitely kills the use of halogen high beams function. I will try to get pics up asap if atone has questions how I did mine hit me up.ps I chose to order bulbs and ballast from TRS so I had everything needed in one box.
Sent from my DROID2 using Bimmer
kvinal is offline   Reply With Quote
Old 10-19-2011, 11:55 AM   #240
kvinal
My Ride: 323i
Sorry damn DROID auto correct lol
Rate This Thread
