Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 10-28-2011, 01:25 PM   #261
silp3
My Ride: 02 325
For those of you not painting your reflector bowl like the OP had and most others, there is no need to remove the reflector bowl period. Just insert the projector. This will not only save you time, but will have the headlights fairly aligned with minimum adjustments.
silp3 is offline   Reply With Quote
Old 10-28-2011, 02:19 PM   #262
Saintluk2
My Ride: 2000 323i sedan
Also perhaps high temperature paint instead of regular paint. I noticed light smoke filling my headlight for about 1-2 hours of use time, then it stopped. I reopened the housing to find the paint on the reflector/halogen contact points on the inside had very slightly melted. I didn't think it was a big deal but left the lights on with the headlight lens off until it stopped.
Saintluk2 is offline   Reply With Quote
Old 10-29-2011, 03:18 AM   #263
m3unit07
My Ride: 1999 328i
Anyone know where I can get some headlight housings? I don't wanna fack up my halogen assembly, but I want my Sienna Red to be on that next level (I see you Benny )
m3unit07 is offline   Reply With Quote
Old 10-29-2011, 11:26 AM   #264
///Mostarac
///Mostarac's Avatar
My Ride: 370z & Cbr600rr
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 10-31-2011, 10:09 PM   #265
DerRoteBaron
My Ride: 2004 325i
For those of you that did the retrofit, did you all use a wire harness with relay or no? I did not hook up a wire harness, and just connected the connector to the ballast. Now I am having trouble with one of the lights dimming and get brighter whenever I step on the gas. I switched ballasts and it still happens on the opposite side so I have narrowed it to a ballast. I contacted the ballast seller, and they seem to think the ballast is not receiving enough power. Does this sound correct, or are they just trying to avoid replacing my ballast under warranty?
DerRoteBaron is offline   Reply With Quote
Old 10-31-2011, 10:17 PM   #266
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Guys, you still need to have the car coded for xenon lights OR have a wiring harness.
Old 10-31-2011, 10:26 PM   #267
shellback
My Ride: BMW with rear wiper
So we just make an appointment at the local BMW dealer and tell them to flash or code our Xenon lights?
shellback is offline   Reply With Quote
Old 10-31-2011, 10:34 PM   #268
Solidjake
Zero. Leaks.
Solidjake's Avatar
No, because you will pay an insane amount for something that can be done for now more than $30 at a local shop who has the bmw diagnostic tool or a local member with the software as well.
Old 10-31-2011, 11:56 PM   #269
///Mostarac
que? My car doesnt throw any codes.
-Benny
Old 10-31-2011, 11:58 PM   #270
Solidjake
Zero. Leaks.
Solidjake's Avatar
Interesting. Well I know with a 55 watt kit it has to be done.
Old 11-01-2011, 12:00 AM   #271
///Mostarac
why do you say that?
-Benny
Old 11-01-2011, 12:02 AM   #272
Solidjake
Zero. Leaks.
Solidjake's Avatar
My friend installed P46 headlights with a 55 watt kit. His cluster kept flickering. I had to code his car for xenons to get rid of the bulb out warning, but he also needed a wiring harness for the extra current.
Old 11-01-2011, 12:05 AM   #273
///Mostarac
hmm thats weird. could just be the p46's
-Benny
Old 11-01-2011, 12:06 AM   #274
Solidjake
Zero. Leaks.
Solidjake's Avatar
Doubt it, an HID kit is still plugged into the factory wiring no matter what. P46 or retrofit.
Old 11-01-2011, 12:10 AM   #275
///Mostarac
ahh yes, your right. Might have been the HID kit?
-Benny
Old 11-01-2011, 12:12 AM   #276
Solidjake
Zero. Leaks.
Solidjake's Avatar
Maybe o_o
Which one did you get for the retrofit btw?
Old 11-01-2011, 12:16 AM   #277
///Mostarac
well I have a personal supplier in fort lee but I didn't want to get his HID's as I don't like his new ballasts. So I just went ahead and bought a kit from ddmtuning even thought all the bad stuff that has been said about them. I wont lie when I say that they are a great kit so far, very bright and absolutely no flickering. I'm satisfied
-Benny
Old 11-01-2011, 11:34 AM   #278
shadow2132
My Ride: 330i ZHP
Had this happen but DDM error eliminators took care of it
shadow2132 is offline   Reply With Quote
Old 11-01-2011, 12:23 PM   #279
a325h
My Ride: '13 2.5SEL Jetta 5MT
When I didn't have my harness, I had no issues at all with codes or even my simple bi-xenon feature. I don't think this is required.
Now that I have the relay installed.... flickering and bulb out warnings...
TRS 5000K XB Bi-Xenons | ümmitza 6000K Opaque AEs | Metallic Tinting | LED Interior Lights
^2001 E46 325i^ SOLD
Current: 2013 SEL 2.5 Jetta 5MT
2010 E90 335i M Sport in Le Mans Blue
a325h is offline   Reply With Quote
Old 11-01-2011, 12:27 PM   #280
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Ok i read to page 11, please excuse me if these have been answered.
1. So if i get the H1 Bi-xenon mini kit, each projector will have a 2nd pair of wires (or a signle wire?) coming from it that flick the shield to make the Hi beam part work?
1b. Is it a 2nd pair of wires to power the bi-xenon shield, or just a single wire, like a brake light switch or ignition switch?
2. If i do not use the bi-xenon feature, i can just run regular low beams,
3. A325h, am i understanding what you did right, you tapped into the OE high beam wires going to the inner shroud, and made these power the shield? Can u say again, what was the issue you had, and why. So you soldered that same wire tap, or did u remove the tap and splice and then wire?
4. Prefacelift, 99-00 sedan guys, are you getting bulb out warnings, should i buy error cancelers too?
5. If i already have a HID kit here, but H7 or whatever, all i would need is H1 bulbs right, theyre universal right?
6. whats the relay and harness business you guys keep mentioning about giving flicker relay and harness for what?
finally, ive never done angles eyes, how the fuk are they done?
Do you ride a sportbike?
Rate This Thread
