Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 03-24-2012, 10:08 PM   #541
Erikx559
My Ride: 2002 325i
Originally Posted by jmejiaa View Post
Thanks to everyone on this thread and especially Erikx559 and deadwood83 today for helping out. I was able to complete this and I have to say it's a great mod. I'll get my angel eyes next week hopefully so I'll have it look even better.
Here are the final pics, I need to adjust the beam so it's a bit lower.
Looks good. I need to adjust mine too, but I've to lazy to take out the headlights. Mine are slanted like a V shape, but ever so slightly. Plus I fkn hate the headlight washers. Gets in the way and it makes just a little hard for one person.
Erikx559 is offline   Reply With Quote
Old 03-24-2012, 10:09 PM   #542
jmejiaa
My Ride: 2002 M3
Oh, I just need to adjust with the knobs. Turns out a 6mm hex makes it much easier to do..
But I do need to take apart again for the angel eyes
jmejiaa is offline   Reply With Quote
Old 03-24-2012, 10:23 PM   #543
Erikx559
My Ride: 2002 325i
Your not going to align the cutoff? With the knobs your talking about, only adjusts up and down. Yours look like they need to be rotated on its axis just a little bit. So it's something like this.
Old 03-24-2012, 10:37 PM   #544
jmejiaa
My Ride: 2002 M3
Attachment 443475
Oh, I see what you're getting at. Problem is I glued the shroud so moving the projector means the shroud would move, because of the issue I had I won't be able to move it much...
I'll adjust it up/down and see how it is. I hadn't even noticed it so if I can adjust to my liking it may stay like this..
Old 03-24-2012, 11:18 PM   #545
Erikx559
My Ride: 2002 325i
Yea, mine doesn't bother me much, but I'll most likely fix it during spring break when I have time. Your going to love these projectors.
Old 03-25-2012, 07:56 AM   #546
maxi
My Ride: BMW E46 328I, 1999
I almost finish the lights , I have to start wiring now.
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Old 03-25-2012, 07:58 AM   #547
maxi
Originally Posted by deadwood83 View Post
the bulb is held in the projector with the bulb mounting clips. I took a picture for you of how they mount. Obviously I have run the bixenon wires because why not? Having a quad high beam with the width of the projectors and the distance throw of the MH1s and halogen highs means I can light up everything in front of me. The light output is ridiculous. My friend has a 335is with factory bixenon and when highs are engaged, my cheapo retrofit is the definite winner for distance and brightness, though his low beams have some serious distance throw.
I'm not sure how much of my output is related to custom work and custom shields though. It's certainly different from most factory shielded MH1s I've seen. (the low beam bit anyway)
ETA: Hurr durr I forgot the picture.
Yes.. this is what I was looking for...
thanks a lot
Old 03-25-2012, 11:55 AM   #548
jmejiaa
My Ride: 2002 M3
Also, in case it helps I got my HID's here:
http://aggracing.com/store/index.php...&product_id=73
Old 03-25-2012, 12:00 PM   #549
mq124
My Ride: slow and sorta low
Here is a pic i snagged during the processClick image for larger version
mq124 is offline   Reply With Quote
Old 03-26-2012, 09:55 AM   #550
jmejiaa
My Ride: 2002 M3
Originally Posted by mq124 View Post
Here is a pic i snagged during the processAttachment 443515
Nice, were you able to complete it?
Old 03-26-2012, 05:03 PM   #551
mq124
Yup. Actually this was taken my second time doing it. I Had already installed angel eyes before the first retrofit. When I did the retrofit the angel eye clips broke so I had to put everything together with the clips messed up leaving the angel eyes hanging awkwardly. So I called EUropean Auto Source and they sent me a new set of clips an now all is good. And the high beams are hooked up now as well
Old 03-26-2012, 05:21 PM   #552
jmejiaa
My Ride: 2002 M3
Anyone on?
Doing my angel eyes now, the clips don't seem to hold on too tight.. Will they be moving at all?? hmm
Old 03-26-2012, 05:25 PM   #553
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Anyone on?
They will move. I put sticky tape between the clip tops and the housings and my high beam eyes still managed to migrate behind the trim.
If your lights are apart just save yourself the time and fasten them to the bowls (at least the high beam) with double sided tape or glue. The low beam try holding the clips with the foam tape on top of the bowl somehow and put one piece of foam tape in the bottom center of the ring (on the back of course).
I need to take mine apart and redo them. Such a pain in the butt.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 03-26-2012, 05:31 PM   #554
jmejiaa
My Ride: 2002 M3
Also, aren't the projector side rings supposed to be smaller than the high beam? They might have sent me the wrong kit...
nvm, called them up, said they should be the same
Old 03-26-2012, 05:55 PM   #555
deadwood83
On mine the projectors were smaller than the highs. Brand of kit? Did you get halogen or xenon? If Orion V2 then they will be the same because umnitza likes the high beam rings to be smaller so that the risk of them being covered by the trim is less. Personally I'm too OCD to tolerate that.
Old 03-26-2012, 05:58 PM   #556
jmejiaa
My Ride: 2002 M3
Orion lite, Xenon
I'm also not liking how the wires come out of the dust cover, doesn't leave it 100% on....
Old 03-26-2012, 06:54 PM   #557
jmejiaa
My Ride: 2002 M3
Got one done, will need to leave the second fro tomorrow since I promised I would go to dinner. Once everything is on it feels much more secure...
I gotta stop making this my personal thread lol
Old 03-26-2012, 07:04 PM   #558
Jmhockey1920
My Ride: 2002 325i
This thread is awesome!! I am going to order my kit here soon.
Bi-xenon: Morimoto Mini H1 4.1
- Bulbs: H1: Morimoto 3Five 6000K
- Shrouds: 1) Mini Gatling Gun
- Version: LHD (North American Standard)
E46-R Projector Shroud
- Premium
Then some 6000K Orion V2 Angle Eyes. Sound good guys?
Jmhockey1920 is offline   Reply With Quote
Old 03-26-2012, 07:05 PM   #559
jmejiaa
My Ride: 2002 M3
- Premium
Give them a call, you don't need the gatling gun shrouds and they will give you $15 credit for getting the e46 shrouds instead.
Old 03-26-2012, 07:07 PM   #560
Jmhockey1920
My Ride: 2002 325i
Ah, that is good to hear!
Rate This Thread
