Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.81 average. Display Modes
Old 09-20-2012, 10:34 PM   #621
tyusha
My Ride: 2004 325i SilverGrey
That gonna be close to impossible. The shrouds are epoxied in. So only a slight room to turn :-/ I will see what I can do though... Thanks again !!
tyusha is online now   Reply With Quote
Old 09-20-2012, 10:39 PM   #622
deadwood83
My Ride: has an iron lung
Send a message via MSN to deadwood83
Ah. Well for future reference... People in this thread told me I was wrong for doing this, but here we go. If you modify the black rings that come with the shrouds, they clip right in and then WILL pressure fit on the projector without epoxy nor silicone. THey're legitimately hard to get off, too.
They also fit around the lens a lot better than the "right way" that everyone does it. Perfectly centered.
AA Stg2+ 325xiA? Are you stupid? Maybe a little.
I can program cars fo' freeee near Salt Lake City. PM for details.
deadwood83 is offline   Reply With Quote
Old 09-21-2012, 08:56 AM   #623
tyusha
Thanks for the pics! That's almost exactly what i did! I epoxied the ring to the shroud first! But it did not fit as snug on the projector as I would have liked... So I ended up putting epoxy on the projector housing as well...
Old 09-21-2012, 09:57 AM   #624
mattfarrington
My Ride: 04 325xi
Ordered the mini hi 5.0 bixenon and the bx35 h1 bulbs. I have crappy DDM tuning slim ballasts for now. But will be grabbing the morimoto ones from TRS!
mattfarrington is offline   Reply With Quote
Old 09-21-2012, 10:04 AM   #625
Solidjake
Mod
Solidjake's Avatar
My Ride: 2002 330i
So I just did this today, and it went really well for the most part. The light pattern is really odd however. Even after adjusting the headlights, the area right in front of the car is completely dark. Not sure what to do. I don't know if this is one of those cases where the bixenon levers need to be bent a bit. Please let me know what you guys think. It looks like this
Nice!
Old 09-22-2012, 07:54 PM   #626
tyusha
Deadwood83 or anyone else, if you get a chance, could you post a pic of your light output like it did in my post 615 where you can see the front of the car, and the dark area in front of the car. I just want to compare it too mine... i will try to get back in there and adjust the angles. i hope it will work... otherwise i will need to order some new shrouds and centering rings....
Old 09-22-2012, 08:07 PM   #627
mattfarrington
My Ride: 04 325xi
Hey, I haven't done this, but I do know that with projectors, you want EXACTLY what you have. The light to be thrown ahead of the car.
When in the car, I'm sure you don't notice the dark spot as much, correct?
This is exactly what you want.
Old 09-22-2012, 11:12 PM   #628
tyusha
Yeah that's exactly what deadwood83 said, and it makes perfect sense. I think most of the funkiness of my light pattern comes from the slight angle of my projectors. I gotta adjust them!
Old 09-22-2012, 11:18 PM   #629
mattfarrington
My Ride: 04 325xi
Yeah you could adjust them a little bit, but for the most part, you have that DEAD ON. The cut off wouldn't be more perfect if you ask me.
I get mine on MOnday, sadly I work second shift, so I'll probably do all the work when I get home at 11:30pm.. I may wait till the next morning but idk.
Not sure how long it takes to install, roughly, so I don't wanna risk getting half way through, and being screwed for driving home at night.
Old 09-23-2012, 12:06 AM   #630
deadwood83
I don't have your exact angles, but I have a pic of my cutoff as well as a pre-lowering pic of the car where you can see that the only illumination in front is the angel eyes.
Remember I have custom cutoff shields, which meant I had to form them by hand, so they are by no means perfect.
And what I consider a money shot. You can see the light start to pick up at the very bottom of the image, but pitch black before that.
Old 09-23-2012, 10:59 AM   #631
tyusha
Ok cool! Thank you very much! That helps once again. I will try to tweak angles a little this week!
Old 09-25-2012, 11:07 AM   #632
mattfarrington
My Ride: 04 325xi
Okay we'll I did this last night. And this is what I have so far, without any adjusting.
I know what I would want, but how ba does this look?
Old 09-25-2012, 11:35 AM   #633
trj
My Ride: 325Ci
It needs a little more adjusting.
May be a aim the projectors a touch more higher.
But how far are you from the wall?
I guess you should first come really close to the wall then mark the hot spots. And reverse 20 or 25ft straight and alight the hot spots again. There is a little guide floating here with pictures which shows you exactly how to align the HID projectors.
Old 09-25-2012, 11:39 AM   #634
mattfarrington
My Ride: 04 325xi
Yeah I didn't adjust at all. My hood release cable just stretched, so I can't open it yet.
But it was daytime so I was about 3 feet away. I need a lot f adjusting to the middle I think?
I'm hoping I cn see tonight... Haha
I'm screwed with my hood being stuck closed into I can get to the deals to he them open it.
Old 09-25-2012, 11:42 AM   #635
trj
My Ride: 325Ci
Hmmm. from 3 ft distance it looks OK. Doesnt look facing too much to the ground. But you never know until you are in the actual viewing distance which is 20/25ft.
You should be fine at night. Just drive a little carefully till you can get your hood open.
Old 09-25-2012, 01:27 PM   #636
mattfarrington
My Ride: 04 325xi
Well thy makes me feel better. I'll grab a night shot after I get off work at 10:45.
Talked to a brothers friend who works at BMW.. Said he goes in through the grill and messes with the latches to open it.
Old 09-25-2012, 01:55 PM   #637
trj
My Ride: 325Ci
Here are a couple of threads to get you started.
http://www.e46fanatics.com/forum/sho...d.php?t=633010
http://forums.bimmerforums.com/forum....php?t=1169487
Old 09-25-2012, 10:45 PM   #638
mattfarrington
My Ride: 04 325xi
I'll just have a shop open te hood for me. Lol
But I got other pictures. Seems OK. But needs adjustments.
Also the light only shoots out maybe 20 feet. I feel that's way too short.
ID:	471010   Click image for larger version
Old 10-02-2012, 11:21 AM   #639
TyG
My Ride: 2004 BMW 320i
Thats awesome, I am on budget so this helps a lot haha. Thank you
TyG is offline   Reply With Quote
Old 10-02-2012, 09:58 PM   #640
Chilton88
My Ride: 325ci, 325xi
Hi, I'm curious. I know how to adjust the beam up and down, but it seems my beam is too narrow in the middle and the lateral illumination seems very limited especially on the right side. Is there a way to adjust the beams laterally to allow more illumination on the side? It seems I have most of the output into the middle. Kind of like a narrow cone...
Thank you
Chilton88 is offline   Reply With Quote
