Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 10-02-2012, 11:48 PM   #641
nissan00b
My Ride: 323 Ci
Nice thread, I noticed a few people with stock (bi)xenons added the morimoto's in their high beam for quads. For anyone that has done this or has any info on a quad setup...
How does the light output compare to the stock single-xenons?
Would it be difficult to wire a set of minis to the stock xenons to have all four as low beams and just the minis for the high beam? I would assume you could tap into the lows or fogs and tap into the high beam for the solenoid on the bi-xenon. But won't that throw a bulb error light if i dont get it programmed or add a resistor?
How would you go about aiming the projectors if they were mounted in the high beam bowl? Could there be a way to adjust them after they have been mounted?
This looks like a fun project but Im not sure if I can justify the price for performance considering I have the stock xenons. Otherwise I think my best bet would be to just go all out with some FX-R's.
nissan00b is offline   Reply With Quote
Old 10-30-2012, 03:26 AM   #642
blksab65
My Ride: 323i Touring
i HATE how you can still notice theres halogen bowls were the hids are mounted into, heres a pic of mine vs oem, i wish i could make it look oem but i guess the only way to make it look better is paintin them black and or adding angel eyes...
any suggestions?
ID:	476057   Click image for larger version
blksab65 is offline   Reply With Quote
Old 10-30-2012, 10:35 AM   #643
Erikx559
My Ride: 2002 325i
any suggestions?
Why didn't you add the shroud? Mine doesn't look like that.
Erikx559 is offline   Reply With Quote
Old 10-30-2012, 05:46 PM   #644
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 you need the shroud and you can also plasti-dip that bowl black.
Old 10-30-2012, 06:43 PM   #645
Erikx559
My Ride: 2002 325i
This. Or just paint the shroud black and avoid damaging your halogen bowls, I've heard they are delicate and ruin easily.
Old 11-01-2012, 08:28 AM   #646
daewon774
My Ride: 2002 330xi
Got all my parts!!!
Hi everyone,
Great thread. I read through the entire thing and ended up ordering the TRS H1 Minimoto retrofit kit with e46-r shrouds, and XB35 5000k bulbs. Also have a set of Umnitza Orion V2s on the way.
I have a question. I will be splicing the HIDs into the high beams so that I can have a high beam function with the HIDs. I'm assuming that I am leaving the halogen ballasts in place to allow for the halogen highs to kick on as well? Therefore, run both ballasts when running it this way?
2002 E46 330xi
Active Autowerke Stage I Supercharger
Magnaflow 11378 exhaust
Bilstein shocks/struts + H&R springs
Style 71s
Soon to be installed Bimmerbrakes headers + LC1...
daewon774 is offline   Reply With Quote
Old 11-03-2012, 04:25 PM   #647
Erikx559
My Ride: 2002 325i
Originally Posted by daewon774 View Post
Hi everyone,
That's correct.
Old 11-03-2012, 05:47 PM   #648
daewon774
My Ride: 2002 330xi
Alright I did the retrofit. I got 5000k xb35 bulbs with the Hi minimoto 35 watt retrofit kit. Hooked the ballast straight to my halogen plug then the ballast to the 5000k bulb. Everything looks great. I drove the car tonight for about 20 min then started smelling something funny. I lifted the hood and the smell was coming from each of my new hid ballasts. Is this normal break in, or is something wrong? Anyone else have this happen to them? The smell wasn't a burning smell, and it didn't smell like it was electrical. Not sure how to describe it.
2002 E46 330xi
Style 71s
Old 11-04-2012, 11:48 AM   #649
jinxie
My Ride: 2000 BMW 323ci
if you use plasti-dip, you can remove it later on, incase you change your mind.
any suggestions?
to me, it looks like he has the shroud on there.... i recently did mine like 2 weeks ago, and until now, i never noticed that you could still see the halogen bowl a little outside the shrouds. the halos kind of block it and i only saw it from looking up close. maybe i should have gotten the e46-r extended shrouds? i'm not sure what the difference is, but now i'm perhaps thinking of making some custom shrouds myself
jinxie is offline   Reply With Quote
Old 11-04-2012, 12:36 PM   #650
Rumplemenz
My Ride: 05 330i zhp/15 335i
Originally Posted by cobyK View Post
here's the plastic "o rings". the e46 shrouds come with clips on the inside that theoretically should mount to something but they don't so you hould break them off...
hope this helps!....
Thanks for the recommendation. I do however believe the rounded edges should face into the shroud
If anyone wants to take this a step further---
The black plastic o-ring (at least mine - may not be the same for every ring) attaches to my projector more snug when applied with round edges of the o-ring facing away from projector. Therefor if you pull out your dremel tool and file away those 3 pointed triangles on each shroud in addition to shaving away some parts of the o-ring than the ring will fit perfectly into the shroud (round edge facing shroud). Glue the o-ring onto the shroud and than the shroud will fit very snug over the projector without the need of glue or silicone. Just an idea. Worked great for me and will allow me to disassemble the projectors etc in the future without any permanent glue or silicone in the way
UPDATE
Post #461 looks like a brilliant idea.... i think this is the best way and by sure the easiest... i'd definitely try that way first before you entertain my way. However, i did modify my oring the way he did (but my way you need to shave off the sides on both top and bottom b/c the oring will fall further down into the shroud when you remove the tabs and triangles)
BUT no matter which you choose the o ring rounded side should face into the shroud not away from it. So when your looking down into the shroud you dont want to see the rounded edges.
Rumplemenz is offline   Reply With Quote
Old 11-04-2012, 10:56 PM   #651
Erikx559
My Ride: 2002 325i
Yes, the e46-r extended are the ones you want if you want to cover the bowl.
Old 11-11-2012, 06:18 PM   #652
Solidjake
Zero. Leaks.
Solidjake's Avatar
I MIGHT buy a set to do a quad setup...
Old 11-14-2012, 05:33 PM   #653
drlph25
My Ride: 04 m3, 05 zhp
Where did you get the part that screws onto the back of the projector(the round silver nut type thing)?
Instagram----> @dylanrlph
drlph25 is offline   Reply With Quote
Old 11-22-2012, 11:17 AM   #654
Solidjake
Zero. Leaks.
Solidjake's Avatar
If you guys are debating if to do the retro buy the parts now since some are on sale.
- HID Kit (another member here has this kit, no bulb out warning, no dash flickering) - $32 shipped US
http://www.ebay.com/itm/260561192283...84.m1439.l2649
Then from TRS
Morimoto mini version 5, e46 shrouds and centric rings for $115.
You can use coupon code TRSgiving10 and it will be $103.50 + shipping which is $10 for USPS.
$146 for an entire projector retrofit...
Old 11-23-2012, 07:34 PM   #655
trippmann
My Ride: E30
Send a message via AIM to trippmann
just placed order at TRS, 113 to them and ill probably pick up the h.i.d's you posed jake, thanks for the simple walk through! pictures to come as parts arrive!
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 11-23-2012, 10:55 PM   #656
Solidjake
Zero. Leaks.
Solidjake's Avatar
Awesome! I just got my parts in, just waiting for my bulbs/ballasts. Quad projectors here I come!!!
Old 11-24-2012, 02:44 PM   #657
Erikx559
My Ride: 2002 325i
What's the difference between the 4.1 and the new 5.0 version?
Old 11-25-2012, 11:44 PM   #658
blksab65
i do have a shroud glued in there is it the wrong one?
Old 11-25-2012, 11:49 PM   #659
blksab65
theres a shroud in there? is it not the right one or something? others on here posted pics and you can still see there bowls as well
Old 11-26-2012, 01:20 AM   #660
Erikx559
My Ride: 2002 325i
Which one do you have on? I have the E46-R extended.
Rate This Thread
