Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 02-15-2013, 11:00 AM   #741
sandman512
My Ride: 2005 325I
Solid, which harness coming from a stock 2005 e46?
sandman512 is offline   Reply With Quote
Old 02-15-2013, 11:00 AM   #742
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Not too sure but I think 9006.
Old 02-15-2013, 08:07 PM   #743
trentcdrums
My Ride: BMW 323i Sedan
^^yeah 9006
Old 02-16-2013, 06:57 PM   #744
sandman512
My Ride: 2005 325I
Solid,
Do you really need to take the headlight apart to put a projector in the low beam? I didn't think you did in your video.
Thanks!
EDIT: Just watched the portion in your video and figured it out. Thanks!
Old 02-21-2013, 10:39 PM   #745
Bandit4077
My Ride: 330i SuperVeloce
jake, did you need to change out your angel eye rings for your high beams, or is the fitment the same? thanks.
Some say, that inside his helmet, there is another helmet. All we know is...
Check out my interior: http://forum.e46fanatics.com/showthread.php?t=1055263
Bandit4077 is offline   Reply With Quote
Old 02-22-2013, 12:36 AM   #746
prisonerofdoom83
My Ride: E46 E30 Tacoma
does anybody offer this service here in So-cal . i dont think i can handle this and wouldnt want to start the project only to leave it half done
prisonerofdoom83 is offline   Reply With Quote
Old 02-22-2013, 03:49 AM   #747
Solidjake
Zero. Leaks.
Solidjake's Avatar
The V2's that I have are the same size so it didn't matter for me.
Old 02-26-2013, 08:51 AM   #748
effay
My Ride: 323Ci
do you apply glue on the shroud and projector. ( centric ring to black area of projector) or the edges of the projector to the edges of halogen housing??
effay is offline   Reply With Quote
Old 02-26-2013, 09:34 AM   #749
antc101
My Ride: 323ci (2000)
Personally I wouldn't, what I did was wrap a couple of layers of thin black electrical tape around the perimeter of the projector. This provides a snug fit for the shroud centric ring and is not permanent.
antc101 is offline   Reply With Quote
Old 02-26-2013, 06:48 PM   #750
effay
My Ride: 323Ci
thanks illgive it a try
Old 02-28-2013, 12:15 PM   #751
nickyatm
My Ride: 2002 330CI
what ballast did you use for the retrofit?
nickyatm is offline   Reply With Quote
Old 02-28-2013, 01:53 PM   #752
antc101
Personally I used the morimoto 3five ss's. They start up and achieve full brightness in about 5-7 seconds, and start up fine if the lights are already on when starting the engine.
I hear oem is the way to go though, not sure how much of an improvement the denso ballasts from TRS would be.
Old 02-28-2013, 09:05 PM   #753
ZHPinthe103
My Ride: 325i Black on beige
I have a 2003 325i with halogen headlights. After doing the retro fit is there any coding needed? Is it literally plug-n-play the wires from the mini morimoto projector into the halogen/car harness?
Last 7 of my VIN(if it helps): PD00993
ZHPinthe103 is offline   Reply With Quote
Old 03-04-2013, 07:53 PM   #754
ZHPinthe103
Originally Posted by SpoonerDee View Post
Did mine on sunday
Did you buy the E46 R shroud? That looks like a different one
Old 03-04-2013, 08:52 PM   #755
beattie_03
My Ride: 2002 318i
Hey All,
So I have had my quads hooked up for a while now but the wiring isnt done properly and am getting around to fixing it this weekend. (This is super easy by the way to the people who dont want to do it themselves, you literally just need to know how to turn a screwdriver/socket).
Anyway, I have the projectors in my low beam (Outers) hooked up to my low beam wiring (9006-9006), and the projectors in my high beam (Inners) hooked up to my high beam wiring (9006-9006). Works simple enough, 2 projectors on with 'lights on' and 4 with high beam on.
As far as im concerned, the ideal set up would be:
Outers to Parker Wiring (1st turn of dial, dual projectors as OEM)
Inners to Low Beam Wiring (2nd turn of dial, quad projectors)
High Beam solendoid to High Beam Wiring.
This means:
9006 - (2825?)... adapter, or easier to splice wires together?
9006 - 9006... plug and play
Single wires to 9006...use T-Tap connectors.
Just thought I would run this buy anyone who has done it to point out any errors I have overlooked, as well as if anyone has used an adapter from the parker (2825?) to 9006 transformer output.
Cheers!!
beattie_03 is offline   Reply With Quote
Old 03-08-2013, 09:33 AM   #756
Waggonpuller
My Ride: e46 wagon e30 325is
I did this retrofit, but can't seem to figure out how to put the bulbs in. I know that sounds dumb, but the spring wants to bend when I try to install the bulb. Also the bulb is not sealed when installed. Where the three indentations are in the back of the projector where the three screws are, are wide open. Is this normal? Anyone have any pictures of the back of the projectors with the bulbs installed?
Waggonpuller is offline   Reply With Quote
Old 03-08-2013, 09:37 AM   #757
Solidjake
Zero. Leaks.
Solidjake's Avatar
Check my vid, skip to 10 minutes
Old 03-08-2013, 10:02 AM   #758
Waggonpuller
Cool, thanks! I see about the spring, but still can't see the bulb. It seems like there should be some sort of gasket to seal the base of the bulb. As it sits now, water, moisture and dirt can get in through the back.
Old 03-11-2013, 06:11 AM   #759
Japanrot_325i
My Ride: 03 325i
Two questions should I go with 35 watt or 55 watt. Also does painting your high beam bowls make them completely useless I would assume so but I figured I'd ask. Thanks a lot
Japanrot_325i is offline   Reply With Quote
Old 03-11-2013, 07:05 AM   #760
trippmann
My Ride: E30
Send a message via AIM to trippmann
55w produces more heat and increases the likely hood that you will burn your wiring or your projector.
If you paint your highs with yellow tint you will be fine I believe, but something like flat black will ruin the output
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Rate This Thread
