Thread Tools Search this Thread Rating: Thread Rating: 173 votes, 4.93 average.
Old 03-11-2013, 08:34 AM   #761
Japanrot_325i
My Ride: 03 325i
Originally Posted by trippmann View Post
55w produces more heat and increases the likely hood that you will burn your wiring or your projector.
If you paint your highs with yellow tint you will be fine I believe, but something like flat black will ruin the output
Hey thanks I thought the 55w might be a little much appreciate the answer . I'd love to paint my bowls yellow but I can't find metal cast or glass paint anywhere around here. I saw the flat black looked nice but as you said I don't wanna ruin my high beams.
Japanrot_325i is offline   Reply With Quote
Old 03-12-2013, 02:14 PM   #762
ZHPinthe103
My Ride: 325i Black on beige
Just ordered the kit. Got the H1 kit, stand-lone can-bus harness, and XB35 5000K bulbs. My only question is where does the bi xenon solenoid cord from the projector come out the back of the headlight assembly to connect to the high beam harness in a splitter arrangement? Bi xenon cord connection is my nervous fear right now about the kit
ZHPinthe103 is offline   Reply With Quote
Old 03-13-2013, 10:05 PM   #763
325adam
My Ride: 02 330i
I am curious about the bi-xenon connection as well. Can anyone give some insight?
325adam is offline   Reply With Quote
Old 03-13-2013, 11:20 PM   #764
325kev
My Ride: 03 325i 5MT
Going off of my best recollection... There is a red wire coming off the projector. That actuates the bi-xenon functionality. Drill a small hole in the bowl of your halogens and pass the red wire out when mounting the projector. It fits into a y-connector that goes to the high beam and to the oem wiring for the high beam. When you hit your highs, the signal is sent to both your high beams and the projector (via the y-connector) and the projector shield drops for the bi-xenon function.
This is a pretty straightforward DIY once you get in there. You guys shouldn't stress too much. This thread is full of good info and hints, just search through.
325kev is offline   Reply With Quote
Old 03-15-2013, 02:32 PM   #765
TyG
My Ride: 2004 BMW 320i
Hello guys, I have a bit of a problem. I am currently in the middle of "trying" to do this retrofit. I bought everything to specification except the shrouds, I bought the Gatling Gun 2.0's, and they definitely will not fit. So I am wondering if anyone has bought these Gatling Guns and did the cut and fit solution. I could use a little bit of help with it. Also I seem to be having a problem installing the centric rings into these Gatling gun shrouds and I could use a bit of help with that too if anyone has ideas and/or experience on it. Thanks in advance!
TyG is offline   Reply With Quote
Old 03-15-2013, 06:42 PM   #766
ZHPinthe103
Why didnt you buy the mini gaitling gun shrouds?
Old 03-15-2013, 11:24 PM   #767
shannon1
shannon1's Avatar
My Ride: 2001, 318i
or the proper E46 extended ones?
Shannon.
shannon1 is offline   Reply With Quote
Old 03-16-2013, 01:11 AM   #768
ZHPinthe103
I actually ordered the mini gaitling gun shroud that screws onto the projector. Im not trying to deal with glue or that headache. Form follows function, non fanatics would never notice it. Any pics of E46s with that shroud?
Old 03-16-2013, 10:02 AM   #769
TyG
Well to be honest I didn't look into the mini Gatling guns. And the video by solidjake showed the regular e46 ones n he had problems with sizing as well. I actually called TRS about my centric rings and they told me "oh it might be to big just sand or dremel it" and that was a shocker. I would expect if they make a product it should fit properly. But I did cut them and sand them then epoxied them to the shroud and now it's good. The problem now is the shroud itself, I've already cut a portion off the top but I still need to trim more. I'll give you guys an update on it and a photo when I'm done. I'm
Assuming I may be one of the few that fit the Gatling gun 2.0s on lol
Old 03-16-2013, 10:11 PM   #770
ZHPinthe103
^what projector/HID/bulbs did you get? Did you wire the bi xenon solenoid?
Old 03-27-2013, 08:41 AM   #771
Jerzboy21
My Ride: 02 e46 sedan
Hey great job man, I'm gonna do mine but do I need to get shrounds seperate or will the one that comes with the projector work?
Jerzboy21 is offline   Reply With Quote
Old 03-28-2013, 12:30 AM   #772
austinadrew11
My Ride: 2001 BMW 330Ci
I recently did the retrofit and it went fantastic. I coded the car for xenon. Now I have a strange problem. My radio reception has pretty much disappeared, and if I find a station it goes away as well if I turn my lights on. Anybody had this problem?
austinadrew11 is offline   Reply With Quote
Old 03-29-2013, 10:21 PM   #773
effay
My Ride: 323Ci
is it posslbe to tap the wires from bi-xenon projectors to hi beam? so when you flick the stalk the projector flap would open to allow max light output?
do you have to get anything coded for this as well? hoping solidjake can chime in on this..
effay is offline   Reply With Quote
Old 03-30-2013, 02:18 AM   #774
ZHPinthe103
If you buy from the retrofitsource.com, they will provide you with high beam Y splitters that will enable you to tap into the high beam.
I did this retrofit this week and it was far from seamless. If you want the bi xenon function YOU WILL NEED TO DRILL a hole in the back of the halogen bowl. Also it takes alot of effort and forcing to tightening the projector down. Also screwing the headlights back in is very difficult.
Anyone have wiring photos of what they did with all the ballast, harness, etc
Old 03-30-2013, 04:21 AM   #775
austinadrew11
Yeah, there is a thread about that method around here somewhere.
Old 03-30-2013, 10:21 PM   #776
nhat179
My Ride: E46 323i Sedan 5 spd
Nice work guys, you guys made me hate my P46 .
Crappy output
Silly question: Can I put these Mini H1 in P46?
nhat179 is offline   Reply With Quote
Old 03-31-2013, 10:42 AM   #777
effay
My Ride: 323Ci
did this over the weekend, way easier then i thought it would be
Old 03-31-2013, 11:26 AM   #778
sandman512
My Ride: 2005 325I
What shrouds did you go with and did they fit with out any modifications?
Thanks!
sandman512 is offline   Reply With Quote
Old 03-31-2013, 08:29 PM   #779
nhat179
Any output shot bro?
Old 04-06-2013, 09:11 AM   #780
maxi
My Ride: BMW E46 328I, 1999
Hi...I've got an error warning lamp in the dash, more than 3 months since installed and everything was fine.
I got the warning lamp only when the x-noen turnd off, when I light them ON.. the warning lamp go Off?!!
So what the best to do? programing or have a Cancelator.
Thanks,
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Rate This Thread
