Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.81 average. Display Modes
Old 06-29-2011, 12:00 PM   #81
JDUTHIE
My Ride: 2003 325xi
Bi-xenon=no high beam bowls
blacked out=sexy goodness...
JDUTHIE is offline   Reply With Quote
Old 06-29-2011, 06:02 PM   #82
infinite012
My Ride: White '08 STI
Bixenons definitely do have high beam bowls. They're used for flash to pass operation.
infinite012 is offline   Reply With Quote
Old 06-29-2011, 08:03 PM   #83
SpoonerDee
My Ride: 2005 E46
OP did you set up the bixenon feature, if so how?
SpoonerDee is offline   Reply With Quote
Old 06-30-2011, 01:41 PM   #84
xi_chee
My Ride: ///M3 SMG
Reason why i painted my highbeam bowls was because i really don't use them...i know Im sacrificing light output but its alright...plus if you enabled bixenons then you really have no use for them
Sent from my SGH-T959V using Bimmer App
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
xi_chee is offline   Reply With Quote
Old 07-10-2011, 10:04 PM   #85
a325h
My Ride: 01 325i Sedan
Send a message via Skype™ to a325h
I am highly considering doing this mod in the coming week. I have a pair of 6000K Predator Orion V2's coming in from Umnitza and this seems like a great complement to the AEs. My question is, I have 6000K AEs coming, so I would like to get 8000K HIDs to give the projector a nice blue tint to it. Will this effect night time visibility? Will this look good? Where could I buy a pair of H1 8000K HIDs? Many people have bashed DDM tuning in this thread, but have not listed or advised of other places to buy from.
Thanks!
a325h is offline   Reply With Quote
Old 07-10-2011, 10:12 PM   #86
xi_chee
My Ride: ///M3 SMG
if i were you, id stick to 6000k hid's, i personally think anything above 6k is just for show. and as far as getting the hid's you can get them anywhere. ddm-tuning.com, theretrofitsource.com, ebay.com (but i recommend you not), retrosolutionsllc.com, just to name a few. i would recommend you getting a pair of hid's with some warranty on it.
Old 07-10-2011, 10:17 PM   #87
a325h
Thanks for the quick reply. I think ill stick with 6000K. Now im upset I didn't order 8000K Eyes. My car is blue so I thought the blue might look good. Ill order the parts for this on Tuesday and hopefully can do the mod this weekend!
Sent from my Samsung Captivate running Mosaic V (2.3.3) using Bimmer App
TRS 5000K XB Bi-Xenons | ümmitza 6000K Opaque AEs | Metallic Tinting | LED Interior Lights
Old 07-10-2011, 10:31 PM   #88
xi_chee
My Ride: ///M3 SMG
it wont take long, matter of fact you dont even need to take the headlights apart to do it, i just did it because i wanted to paint my headlights lol
Old 07-10-2011, 10:50 PM   #89
a325h
Well I also need to replace some weather proofing and the lens so I will just take them out like you did!
Old 07-12-2011, 01:01 AM   #90
a325h
Update: Parts have been ordered and should arrive later this week. I will post pictures when finished!
Old 07-12-2011, 01:54 PM   #91
xi_chee
My Ride: ///M3 SMG
Sounds good
Old 07-23-2011, 08:09 PM   #92
jmejiaa
My Ride: 2002 M3
Has everyone so far painted the hi beam housing? I'm think I don't want to paint it, instead keep it OEM. If I don't paint it, should i bother painting the shroud?
What combination would give me more of an OEM look?
jmejiaa is offline   Reply With Quote
Old 07-26-2011, 12:20 AM   #93
xi_chee
My Ride: ///M3 SMG
you dont have to paint anything, its up to you a couple pages back someone did it without painting anything and it looks good
Old 07-26-2011, 02:27 PM   #94
a325h
xi, I was trying this DIY out the other day and I could not get the tightener on the back of the projector to get tight enough with the large white rubber peice on the inside. I know that I could just use the smaller one, but it doesn't let the projector sit far enough up in the shroud.
Do you have any suggestions?
Old 07-26-2011, 11:18 PM   #95
xi_chee
My Ride: ///M3 SMG
use a small needle nose pliers, it should do the trick to make it tighter.
Old 07-27-2011, 09:21 AM   #96
a325h
I was using needle nose and I tightened it to the point that it was starting to peel off plastic from the back of the housing. I should note that my headlights do look a little bit different than yours.
Old 07-30-2011, 02:56 PM   #97
Kubelman
My Ride: 1999 323i
Diy hid
wow and WOW--for a first diy-very ambitious and very beautiful--i have a technical question--don't laugh--do the lights/ballast/etc draw MORE or LESS current thru your electrical system--i know they draw 12 volts but how many amps--am thinking about an install on an antique VW Thing--want more headlight throw but cant afford any more current draw on the system--
Kubelman is offline   Reply With Quote
Old 08-01-2011, 02:07 AM   #98
TerraPhantm
My Ride: 2005 M3 Coupe
FWIW, one can make it so that all highbeam functions including flash-to-pass work off the bixenons with a 2006 or newer LCM and some custom coding. (When the headlights are off, flashing would make the lowbeams turn on and open the bixenon shutters. When the headlights are already on, pulling back will cause the shutters simply open).
I personally like having a ton of light, so I've instead configured it so that the halogens and bixenons always fire together.
Old 08-01-2011, 02:29 AM   #99
i<3my3.
My Ride: 328ci
Send a message via AIM to i<3my3.
will post up pictures soon.
i<3my3. is offline   Reply With Quote
Old 08-02-2011, 05:34 AM   #100
Wassa2016
My Ride: 328i E46
Originally Posted by xi_chee View Post
much thanks! and do post pics when you are done
Completely forgot to post pictures up here >_< I'm just fixing my radiator, will post pics up in the next few days. Must say.. Mini really does hold up; seems brighter than OEM xenon lights haha, the 6000k bulbs add a nice purple flicker when driving, and lights up the road, with or without the bi-xenon function.
I'm really pleased with buying them and recommend TRS for future buys. Matt has great customer service skills.
If anyone else wants i can post more pictures up with installing the lights, if anything is missing
Cars:
2003 320i Sedan
1998 328i E46 Sedan
1997 E36 M3
Wassa2016 is offline   Reply With Quote
