Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 4.81 average. Display Modes
Old 09-20-2011, 12:55 PM   #141
Jelly335
My Ride: 2001 bmw 330I
Send a message via AIM to Jelly335
I have a question. I still have my halogen headlights. I got depo brand headlights on the car but the part that adjust the headlight is broken making my light aim towards the tree.can I switch over the projector to my halogen and make it work like this?
E46 330i retired
E92 335 current
<3 my one wheel wonder
http://www.cardomain.com/ride/2269710/1
-Jeremy
Jelly335 is offline   Reply With Quote
Old 09-21-2011, 09:35 AM   #142
jmejiaa
My Ride: 2002 M3
I'd like to see pics of people that AREN'T painting the housing and shrouds black please. Anyone?
jmejiaa is offline   Reply With Quote
Old 09-21-2011, 09:49 AM   #143
xi_chee
My Ride: ///M3 SMG
Review last couple pages friend
Sent from my SGH-T959V using Bimmer App
ex: 2002 TIAG 325xi (sold), 2007 suzuki gsxr (sold)
current: 2002 carbon black ///M SMG
halogen headlights? want hid projectors? on a budget? maybe i can help! go here!!
http://forum.e46fanatics.com/showthread.php?t=840919
xi_chee is offline   Reply With Quote
Old 09-21-2011, 11:45 AM   #144
a325h
My Ride: 01 325i Sedan
Send a message via Skype™ to a325h
All my pictures are silver shrouds and original reflector housings. Check them out on page 5 I think.
@JEL: Switch back to the Halogens with the working adjusters and do this retrofit. These need to be aimed correctly in order to see (because of the cutoff) and not to blind oncoming drivers.
TRS 5000K XB Bi-Xenons | ümmitza 6000K Opaque AEs | Metallic Tinting | LED Interior Lights
a325h is offline   Reply With Quote
Old 09-21-2011, 09:30 PM   #145
Sanchjer
My Ride: 323i e46 SOLD!
I have a question. I'll be doing this DIY once I order the parts (friday) and was wondering how you guys got the HID kit bulbs to stay in the projectors? I already have an HID kit so don't wanna order another. The thing about them is they look just like the ones you can get from DDM, they have no real way of mounting them to anything, just a black rubber that comes off the bulbs.
Sanchjer is offline   Reply With Quote
Old 09-21-2011, 10:11 PM   #146
a325h
The Morimotos come with retaining clips to hold the bulb in.
Old 09-21-2011, 10:19 PM   #147
Sanchjer
Thanks for the response. Can't wait to see what these will do for the appearance of the front end.
Old 09-23-2011, 10:59 PM   #148
mp333
My Ride: 2003 325XI
OP - You said the setup looks "somewhat ghetto". How different is it from the oem?
E46 Rocks
mp333 is offline   Reply With Quote
Old 09-24-2011, 10:57 PM   #149
eu teo
My Ride: 325xi
Thank you for the diy
eu teo is offline   Reply With Quote
Old 09-25-2011, 08:15 AM   #150
maxi
My Ride: BMW E46 328I, 1999
I'm planning to go with this setup since I have Halogens in my car,
how about buying the whole set from THE RETROFIT, does it need any thing to change or to add? Or just buy it as it's and everthing will fit fine?
http://www.theretrofitsource.com/pro...roducts_id=227
Mr. xi where did you purchase your angel eyes? ( Are they CCFL OR LEDS? )
http://forum.e46fanatics.com/signaturepics/sigpic64570_1.gif
maxi is offline   Reply With Quote
Old 09-25-2011, 08:23 AM   #151
Steve330ci
My Ride: 2003 325ci, ZSP, 5MT
Send a message via Skype™ to Steve330ci
Wiring Diagram
For those who have done the Morimoto retrofit DIY, can you post a diagram or write-up of how you connected everything together with the wiring harness? Thanks!
Steve330ci is offline   Reply With Quote
Old 09-25-2011, 11:24 AM   #152
shadow2132
My Ride: 330i ZHP
Not sure what kind of diagram you need. I got the DDM tuning hid ballasts and bulbs (35w 6000k). All ballast kits should be plug and play as our plugs fit directly into them. I had a flickering problem that i resolved with a error code eliminator from DDM.
I feel like an a-hole because I still don't have any pics up. Been busy with work hopefully I'll get some tonight.
shadow2132 is offline   Reply With Quote
Old 09-25-2011, 11:49 AM   #153
Steve330ci
My wiring harness has five connections: a + connection; a - ground, a connection to each ballast; and a fifth connection that I assume has to connect to one of the car's existing low beam bulb connection.
Also, to make the bi-xenon feature function, there are two leads coming from each projector - I assume these two leads tap into the + and - leads for the car's high beams.
If anyone can advise that would be greatly appreciated!
Old 09-25-2011, 04:22 PM   #154
Steve330ci
Install of the Morimoto D2S retrofit kit from TRS is complete using my best guess for the wiring connections, as stated in my prior post. Good news is full functionality. Project took 6 hours. Had to dremel the existing halogen bulb opening from one inch diameter to 1 and 5/16 inch.
Only glitches are:
(1) the wiring harness supplied by TRS has 5 connections: positive, ground, left ballast, right ballast, and the last one to connect to one of the car's low beam connectors. Because one low beam connector is now - after the install - not connected to anything, I have a bulb out light for the missing connector side.
(2) there was absolutely nothing for the E46R shroud to connect to in the projector. And, the puny little tabs on them easily break off.
Waiting for dark to see how they look.
Will post some pix on Monday.
Old 09-26-2011, 12:09 AM   #155
xi_chee
My Ride: ///M3 SMG
lol i rigged this up in my basement cause i had a few $ to spare thats why i said it was kinda ghetto lol
everything should be fine
Only glitches are:
i glued mine on as stated in the diy lol...i believe the shrouds are made to fit the oem projectors only thats why it didnt have any mounting points for the morimotos.
and you bought the d2s version i assume. i did the h1 version so im not too sure on the wirings...i have to do some researching then get back to you on that....
p.s. i did this retrofit to my friends yamaha r6 and it looks sweeeetttt will post pics soon
Old 09-26-2011, 07:26 AM   #156
maxi
thanks Mr. xi , and where did you buy your angel eye?
Old 09-26-2011, 07:50 AM   #157
maxi
I'm going to buy the Complete Retrofit Kit soon, god willing .
Old 09-26-2011, 06:21 PM   #158
Steve330ci
Went to the Indy shop today and they did a complimentary LCM reflash for the bi-xenons. The bulb out light for the unconnected low beam connector went away and the headlight flicker went away.
Went to re-aim the xenons and the outboard right side headlight adjuster (the one that moves the beam right to left) broke off.
Will post a write-up and pix tomorrow.
Old 09-26-2011, 07:36 PM   #159
///Mostarac
///Mostarac's Avatar
My Ride: Sienna Red E46
finished mine the other. Extreamly happy with the results look-wise, but dont know about the light output just yet. I dont have h1 bulbs yet, i ordered em from ddm tuning last tuesday and still nothing ill post cutoff pics when i get em. here are some pics!
///Mostarac's Official Build Thread
Eurowerkz | East Coast
-Benny
///Mostarac is offline   Reply With Quote
Old 09-26-2011, 08:26 PM   #160
mp333
My Ride: 2003 325XI
Interested in what the difference is for light output.
E46 Rocks
