Old 05-01-2011, 11:14 PM   #1
Nervous
My Ride: 01 330CI 6MT ZSP EU3
FIXED! One-touch driver window opening - doesn't work
Weird, I just found out that one-touch opening of driver's window doesn't work. Closing - works. Passenger door - works (opening and closing). Driver's - only one-touch closing works. Opening works as usual, while you are lifting the switch up.
I checked with PA Soft 1.4 - the checkbox for autoopening is set. I removed it, when set back - nothing. Changes with passenger door are instant: I can see that I am turning auto-opening/closing. Auto-closing for driver's door is also "turnoffable". But auto-opening - nah. What's wrong?
FYI, This doesn't change anything
Nervous is offline   Reply With Quote
Old 05-02-2011, 01:24 AM   #2
Nervous
I played with INPA, tested window regulator. If I send a command by INPA the window goes up and down with no problems. Moreover, I found a screen where they draw states of the switch ("open" - "close"). Thus, when auto up/down occurs on working side I see that both of these states are set (two black dots are drawn). Same happens when I roll up the driver's window by one touch - both dots become black for short period of time. But when I try to roll the driver's side window down by one touch I see only one black dot at "open". Seems to me the issue is in switch.... Thank God I can get it for just $35 from www.bmwmercedesparts.com
Old 05-02-2011, 03:30 AM   #3
blarf
My Ride: 323i, 325iT, 540iT
I believe you can use INPA to simulate the button press. Try it and see if the window responds properly?
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 05-02-2011, 04:03 AM   #4
Andy2108
My Ride: SpecE46 & E46 M3
So the issue is the switch?
I have a friend whos M3 doesnt auto down
De gustibus non est disputandum.
Old 05-02-2011, 07:57 AM   #5
Nervous
Yep, looks like it does.
Old 05-02-2011, 07:58 AM   #6
Nervous
Well, I need to get another switch to say for sure.
Old 05-02-2011, 09:48 AM   #7
BMWPartsSource
Internet Sales
BMWPartsSource's Avatar
My Ride: n/a
61-31-6-902-183 $40.26 and in stock. WWW.bmwpartssource.com
BMWPartssource.com
BMWPartsSource is offline   Reply With Quote
Old 05-02-2011, 10:00 AM   #8
MightyY
My Ride: '05 M3, '03 M5
I'm having the exact same problem with my driver's side window. I had a power glitch in the car and had to reinitialize both windows. The passenger one works up and down now, but the driver's side only does auto-down and not up. It's driving me crazy. Keep us updated if the new switch makes it work.
MightyY is offline   Reply With Quote
Old 05-02-2011, 10:30 AM   #9
Nervous
^ Mine is opposite - it rolls up but not down.
Old 05-02-2011, 10:35 AM   #10
Nervous
www.bmwmercedesparts.com - $35
And I believe it is 61316902175 for coupes.
Old 05-04-2011, 11:55 PM   #11
Nervous
FIXED. Price - $0. Just disassembled the switch and cleaned contacts. That is it.
Plus, I've done modification for one-touch vent windows closing, by using shadowcatxx87 DIY (thanks a lot, man!):
http://forum.e46fanatics.com/showthread.php?t=783164
Coding I've done by P.A.Soft 1.4.0.
Some pics:
P.S. I found out that one of the buttons is cracked (plastic). Nothing critical (yet), but would like to replace the plastic part of the button eventually. If someone has non-functioning window switch (regardless sedan or coupe, driver's or passenger's side), I'd be happy to get it from you for cheap.
Old 01-31-2015, 08:11 AM   #12
the_ace
My Ride: 325ti
My compact passenger window doesn't auto up, drivers side does and i've tried initialising them again and a new pass side window switch. I'm guessing its needing coded?
the_ace is offline   Reply With Quote
Old 05-25-2016, 12:23 PM   #13
shahbaz99
My Ride: Clean 330ci
hate to revive and ancient thread but im having htis exact same issue! My driver window switch broke, so i ordered this one off of ebay. http://www.ebay.ca/itm/261526465392?...%3AMEBIDX%3AIT
It matches the original button pretty well and seems to fit correctly. however my auto window down function doesnt work but the auto up does. i do feel the second stage "click" in the button but its a no go. Im going to attempt this fix and see if it works. Anyone else have this issue and solve it?
shahbaz99 is offline   Reply With Quote
Old 05-25-2016, 03:08 PM   #14
sk8ersublime
My Ride: 2001 330Xi
I thought I had this issue when replacing my regulators, but I realized that the auto feature only seemed to work if the door was closed. I guess that is normal. Works for me either way.
sk8ersublime is offline   Reply With Quote
Old 05-25-2016, 04:07 PM   #15
LocoCan
My Ride: 2000 323i sedan
I was working on the passenger door panel, just replacing old broken clips to get rid of a rattle noise. After, the window will go down on auto, however the auto-up isn't working.
I'm gonna take the switch apart and do a little cleaning. I already tried one method of resetting the up feature.
LocoCan is offline   Reply With Quote
Old 05-29-2016, 12:14 AM   #16
SP1200
My Ride: BMW 325i 2001
can anyone report back on this? Ive tried 2 sets of switches and find it hard to believe both of them are bad.
Passenger Rear Auto down Ok, Auto up Not working.
SP1200 is offline   Reply With Quote
Old 05-29-2016, 12:32 AM   #17
SP1200
ohh i discovered there is a wire running down the inside if the inner door weather strip. i guess its a "pinch sensor" that indacates when ther window is up.
Anyway that was unplugged. plugged it back in and now it works.
