ZHP Suspension Upgrade Kit - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 05-03-2011, 10:26 AM   #1
jcp_56
My Ride: 2009 Silverado 1500
I just purchased the ZHP Suspension upgrade kit from ECS tuning (Got it for a steal @ $499). It will be here by the end of the week. I've been looking on the forum and can't seem to find any DIYs for someone going from a stock regular suspension to a ZHP upgrade. Does anyone know of a write-up somewhere that I can reference while doing my upgrade this weekend???
Thanks in advance!
jcp_56 is offline   Reply With Quote
Old 05-03-2011, 02:51 PM   #2
ECSTuning
ECSTuning's Avatar
My Ride: BMW
The install process will be the same as removal!
For anyone else looking we have them available below!
http://forum.e46fanatics.com/showthread.php?t=841341
Best,
Joe
ECSTuning is online now   Reply With Quote
Old 05-03-2011, 05:47 PM   #3
jcp_56
I figured as much. I suppose I should now clarify. Does anyone have a DIY for the removal?
Old 05-03-2011, 06:06 PM   #4
mystert
My Ride: 2003 330Ci
What size is the rear sway bar in this kit??
MysterT Huntington Beach, CA
mystert is offline   Reply With Quote
Old 05-04-2011, 10:02 AM   #5
ECSTuning
ECSTuning's Avatar
My Ride: BMW
They are 24mm!
Best,
Joe
Old 05-04-2011, 02:34 PM   #6
Jkim
My Ride: needs work...
are ALL these better then the sports pkg?
Jkim is offline   Reply With Quote
Old 05-04-2011, 03:17 PM   #7
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Yes, they are slightly bigger then the standard sport package cars.
Old 05-05-2011, 10:10 AM   #8
silber92
My Ride: 2006 330CiC ZHP
Joe, if my '03 (12/02) 330CiC already has the sport package, are new springs really necessary with the ZHP kit, or can I run the ones I've got?
Thanks!
Michael
silber92 is offline   Reply With Quote
Old 05-05-2011, 10:17 AM   #9
TxZHP04
My Ride: ESS TS2+ ZHP
The kit doesn't include a rear sway bar.
Originally Posted by ECSTuningJoe View Post
They are 24mm!
Best,
Joe
To be more precise, the front sway bar is actually 23.5 mm per BMW.
Old 05-05-2011, 01:37 PM   #10
ECSTuning
ECSTuning's Avatar
My Ride: BMW
Thanks!
Michael
They are not needed, however they are designed to be match with the BMW Performance shocks within this kit. Its never a bad idea to change everything out all at one time while your in there. At these prices its hard not to just do the kit. The ZHP arms alone are $569.32...
According to our BMW ETK it is 24mm. I know realoem is showing 23.5mm however our ETK is the same as the dealer. Realoem is not 100% accurate all of the time, however it is still a great resource.
Old 05-05-2011, 02:03 PM   #11
TxZHP04
In this case, realoem happens to match the actual diameter of my ZHP's stock front sway bar as well as the dimension molded into the stock bushing itself. Perhaps the ETK isn't 100% accurate either. Presumably it's a rounding issue.
Old 05-05-2011, 02:45 PM   #12
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We measured a ZHP bar here in house and it came out to be 23.88mm which we and presumably BMW rounded up to 24mm.
So with rounding it can be taken either direction.
Thanks for all of the orders everyone!
Joe
Old 05-05-2011, 03:33 PM   #13
TxZHP04
Joe
And what does the dimension molded into the sway bar bushing say?
Old 07-24-2011, 12:46 PM   #14
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Add a BMW Sport Suspension to your E46
If you are looking to upgrade your stock suspension to increase handling and performance, this new ZHP Suspension Kit from Genuine BMW is perfect for the job, allowing you to toss that old suspension setup out onto the curb.
This kit is a replacement for the Performance Package on the BMW 330i and for those that don't own this vehicle, this kit is a great upgrade, as they feature solid ball joints and are more durable than the stock setup. These will provide improved handling, steering response and a slightly stiffer ride.
This kit works on all of the non-all-wheel-drive E46 3-Series models, including the 325i, 325Ci, 328i, 328Ci, 323i, 323Ci, 330i, 330Ci as well as 330i/Ci ZHP.
This kit includes your control arms, shocks & struts, bump stops, 24mm front sway bar & bushings, and all related hardware for an easy install.
When purchasing this new ZHP Suspension Kit for you BMW, ECS Tuning recommend getting a set of H&R Sport Springs to match.
Read more >>
Note:
This product is no longer available.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
Old 07-27-2011, 12:37 PM   #15
blkonblk
My Ride: 06/2000 330i ZSP/ZPP
Read more >>
Note:
still available at thebmwpartstore for $480. ask for mike, tell him marc told you
Life is a journey not a destination, so enjoy the ride!
blkonblk is offline   Reply With Quote
Old 08-04-2011, 05:14 PM   #16
hurls
My Ride: 2000 323iT
Happen to have the sway bar and bushings from one of these kits sitting in my garage (sports package touring already had an as-big or bigger sway bar, so did not install that part of the kit). The bushings have 23.5 molded into them.
hurls is offline   Reply With Quote
Old 08-04-2011, 05:33 PM   #17
TxZHP04
The question was rhetorical and directed at ECS as I knew the answer all along... but thanks for the independent confirmation.
Old 11-16-2011, 07:31 PM   #18
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
is it still available?
how do i search for it on the website?
nvm found the part number
recommended springs to use with the suspension upgrade kit?
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/M Performance Exhaust/Injen CAI/Dinan Shockware
XKxRome0ox is offline   Reply With Quote
Old 11-17-2011, 08:54 AM   #19
ECSTuning
ECSTuning's Avatar
My Ride: BMW
We recommend pairing the kit with H&R Sport Springs.
ECS Tuning
Old 11-17-2011, 12:27 PM   #20
XKxRome0ox
Black and Proud
ECS Tuning
cool
but why you no sell suspension kit no more???
diy, suspension, upgrade, write up, zhp
