E46 Xi Forum
Old 03-07-2012, 07:14 PM   #1
jeepo23
My Ride: 2008 X3, 6 Speed
Car sounds like a POS at slow speeds..
Alright I got some sort of issue when I'm going at parking lot speed my car makes these clunks/rattles like you wouldn't believe underneath...
Normal driving speed or faster no issues at all, don't hear a thing or feel anything. The car responds and handles fantastic. The previous owner has had completely re-done the suspension prior to selling it.
Also the front-left sway bar link was replaced about a year and a half ago by him. And this is the area where the sound almost appears most prominent.
What are some of the things I need to check? Perhaps get the car up on all 4's this weekend and take a look down there but I'm not sure what I'll be looking at exactly for this issue.
jeepo23 is offline   Reply With Quote
Old 03-07-2012, 08:23 PM   #2
SamDoe1
My Ride: 4cyl of fury
Sway bar end links, sway bar bushings, ball joints, strut mounts. Make sure everything is tight down there too.
Old 03-07-2012, 08:45 PM   #3
jeepo23
Okay makes sense.
Quick question tho, when you say sway bar end links and sway bar bushings whats the different between the two? Can you on these cars just replace the bushings instead of the entire end link?
I thought that if the bushing went the actual sway bar end link gets replaced?
Old 03-07-2012, 10:09 PM   #4
SamDoe1
The bushings are what holds the bar away from the body on the underside. They are little chunks of rubber that screw into a bracket on the underside of the car.
What you are thinking of on the end link itself is the ball joint.
Old 03-08-2012, 07:59 AM   #5
jeepo23
Alright I see what you mean.
I guess I'll have to take a peek down there on the components and see what's happening.
I have a feeling it's something to do with the control arm/ball joint I'll have to check.
Old 03-10-2012, 12:08 PM   #6
jeepo23
Well took a look under the car upfront and I think I may have found the culprit.
Does this appear to be abnormal for the swaybar? I know the other side one does not have this movement.
** Removed **
Old 03-10-2012, 01:25 PM   #7
Kubica
My Ride: 2003 325xi
Replace both sway bar endlinks.
Pelicanparts.com usually has good prices on oem parts.
T-30 torx socket and stubby 16mm wrench will get it done, iirc. They need to be tight.
Old 03-10-2012, 01:49 PM   #8
jeepo23
Why both? The other one is perfectly rigid and solid no movement.
Does the one in the video look bad tho as the joint has movement.
** Removed **
Old 03-10-2012, 09:57 PM   #9
SamDoe1
T-27 is what worked best for me, but yup.
Yes, it looks bad. You do both because if one has failed, the other is not far behind.
Old 03-10-2012, 09:59 PM   #10
jeepo23
So has the one in the VIDEO failed?
Let's not worry about the other one at this instant.
** Removed **
Old 03-11-2012, 12:57 PM   #11
jeepo23
Yup dead.. I removed it and drove the car no clunk throughout the entire lower end..
Torx 30 did it for me. Will be ordering a new end link.
